tdjsperrazza
    5
Reputation
1 Neutral
Personal Information
  • Occupation
    Lighting Designer
  • Homepage
    tylersperrazza.com
  • Location
    United States
Recent Profile Visitors
  1. @PeterYip Thanks! Haven't gotten into the recess tool much, but I'll check it out!
  2. @CipesDesign thank you! I was getting tripped up by the opening height, but duh! Add the depth you're sinking into the floor to the total height to reflect it accurately. Thanks for making that easy!
  3. Hi all, I'm working on a theatrical venue where everything in the building is raked (the balcony, the stage, the auditorium floor). Most of the doors in the building are in walls at either the top or bottom of the rake, but there are two openings on the stage where the bottom of the cased opening needs to follow the rake of the floor. Does anyone have any tips or tricks to accomplish this? Screenshot attached for clarity.Thanks in advance!
  4. @C. Andrew Dunning thanks so much! Got it to look somewhat decent by creating my own clamp component to snap onto a locus placed on the pipe. It'll do for now until the bug gets worked out.
  5. Quick question. I'm running into a visualization issue when I attach a speaker to a rigging object. The speaker shows as attached, but when I switch its Support to "Yoked" the clamp does not show as attached to the pipe. Instead, the rigging object bisects the speaker. Is there a way to make this look cleaner when rendering? I've attached some screenshots here for illustration.
