MartinBlomberg
    196
Everything posted by MartinBlomberg
  1. Can't get it to work, I must've missed something really basic I guess... Attached the file here. Many thanks @Pat Stanford! Tables.vwx
  2. Hi, I feel like a complete moron when I can't get the IMAGE and COUNT-function to do what I want. All I'm after is to get the total amount of tables (exactly the same table and symbol) I have on the drawing and sum the total. I have 44 tables on a drawing and cant' get it to work. What I want: Column A: The table symbol Column B: 44 But, what I get is either: Column A: 44 rows, with the same symbol Column B: The number "1" or Column A: 1 row with the symbol Column B: The number "1" I've tried all combinations of "Summarise items" and "Sum values" but can't get it to work. What will do the trick? Many thanks! Martin
  3. Hi, I'm using a venue as reference on my set drawings. Even if classes are hidden in the view I'm in VW keeps snapping to objects that are hidden. How do I adjust that? I want to keep the "Show/Snap others" since I'm snapping to different visible objects, but not the hidden ones. Many thanks!
  4. MANY thanks! Worked like a charm! VW-forum, is always the best! Martin
  5. Nice, thank you! I've never worked in this manner before, how do I change a referenced file to Layer import referencing? Many thanks!
  6. Long title, but hopefully it make sense. I've got a drawing of a venue with several layers and classes, like audio, rigging, lights and so on. I also have another file with the set design. I've referenced the venue drawing file in the set design drawing, so I can make several set designs without the actual venue included in the file. Now to the question: I want to print different sheet layers with the set design, but different content from the referenced drawing. I.e, on some sheets I want to hide the lighting, rigging or audio, but I can't find where to hide/unhide classes/layers on the referenced file per sheet layer. Thanks!
  7. Haha, nice one! I thought I did something wrong all the time, nice to hear 😃 I'll make the rows a bit short then, works fine as well 😃 Many many thanks! Martin
  8. Thank you so much! I'll try to dig in deeper and try again. Also, thank you for doing such an awesome plugin! Do you know why I get a gap from the first chair? The distancing between the chairs is good, I only need to adjust the first seat to get them to line up. I'll attach a video for clarity 😃 Screen Recording 2024-02-14 at 08.55.37.mov Thanks!!
  9. Hi, What's the best praxis to change the trim height of a speaker array when I have attached hoists? If I change the trim height of the hoist, the array stays. If I change the speakers, the hoist stay. Is there a good way of doing this? Thanks!
  10. Hi I guess this is a somewhat Catch 22 question, since I can't find if this have been asked before 😃 I just want to understand how I can search the forum better, since I find it hard to find relevant information quite often, and also get several hundreds of results where some aren't even relevant. Would be great to search this forum better. Many thanks! Martin
  11. Thank you! Didn't see that option, I guess I was to eager 😃 I think I'm almost there, just another question: Please look at this picture. On (A) I've drawn as the upper black line shows, and I get the result as shown. On (B) I've done the same, but tried another length of line for the section. In both cases I get a gap in the beginning of the section. I'm not sure how make the tool work so that the seats line up perfectly. Many thanks!!
  12. Fantastic! I just realised I asked about this several years ago and I think we talked at that time as well. At least I recall the plugin. Just a question @michaelk, is there a way to set a default mode on spacing, symbol so that I just can draw lines and later on adjust the numbering? Many thanks!
  13. Hi, I'm drawing a 12.000 cap arena from scratch. The only thing I got is a 2D dwg with the structure along with chairs, row, and chair number. I've created a simple chair and attached a record to the symbol. I've also linked text to the record so that when I fill in the chair number in the record it appears on the symbol. Now, do I actually have to do that 12.000 times? There's gotta be an easier way to do this than to manually enter the chair number for each chair, right? Please let me know your thoughts on this. Warm regards and thanks!
  14. Thanks! I'll send the report as soon as it happens again.
  15. I'm not sure how to do that, VW doesn't crash or anything, only the mouse disappears. Sorry for my ignorance.
  16. Yeah, I did that a couple of times already actually 😃
  17. Still happening for me, anyone else still experience this?
  18. Thanks, feels "good" that I'm not alone. I need to restart VW to get this to work, does anyone know of any other way to get back the cursor without restarting? Thanks!
  19. Hi, My mouse cursor keeps disappearing in VW24 with macOS Sonoma. I updated today to the latest version which unfortunately didn't make any difference. Earlier, I was able to go to the Dock and the pointer would appear again, but since the last update, even this workaround doesn't work. Any clues on how to fix this? Many thanks! Martin
  20. That sounds great! I was just thinking of a streamdeck integration where I list the most used layers and classes on the bottom rows and then the most used tools above. That’ll make it easy to write and create on specific layers and classes more easily. It would also be super nice to assign specific tools and objects to specific, pre-defined, classes and layers so that when I add a truss for instance, it automatically goes to the Rigging layer. And so on. Is this even doable? many thanks!
  21. Thanks @bjoerka for the response! Ah, the RW Background did the trick (for now) 😃 Many thanks!
  22. Hi, I have had an issue with this rendering since the start of the drawing. Same problem with VW22, 23, and now 24. The lamp doesn't light up but there is still light somehow. It works sometimes, but mostly the lamp is black. Any suggestions? Thanks! 😃
  23. Hi, I'm working on a suggestion for a stage build and would like to draw some kind of tent/roof with poles and ballasts. I don't know how to start with the concrete ballasts, poles, and fabric. Does anyone have a good tutorial or tips regarding this? Image for reference. Thanks! Martin
