matteoluigi
444 -
Posts posted by matteoluigi
i actually can't send you the model that'x a video with a simple handrail-modelling attempt, works better than i thought
- 1
not sure, but there seems to be a significant improvement from sp1 to sp2, could i be right?
well, until now i haven't been able to make it working, otherwise I wouldn't ask a question like that. I will try again, asap today 🙂
well, yes, I TRIED 😉
afaik, the new railing tool only works with PIO stairs. Sometimes the stair-plugin isn't flexible enough, so I model stairs by myself, however I can't align the new railing to non PIO-stairs. that's a pity, what do you think?
@gester and of course BSDD should be implemented as well for an integral workflow sth like a BSDD -interface for the datamanager
i don't have a clue and I am eager to know myself, when there will be first infos. In fact, I can imagine, that IDS could be a great tool for information handling in OpenBIM projects.
I think, there will come sth in the future, but I actually don't know.
Hi,
since it's possible to check out single objects in VW Project Sharing, it can happen, that more than one users want to check out/modify the same object.
Now, we can write an email but, it's not always that easy, to describe "which object" someone is talking about. A system to REQUEST an object would be great (and neccessary) for a fluent Project Sharing workflow)
Sending a screenshot, sending a mail, asking the other person to look on my screen,... is of course possible, but a bit to complicated, somehow...
- 3
A great feature from vectorworks are worksheets with database-rows. However sometimes database-collums could be an interesting tool, as well.
What do you think?
Hi,
is there any possible way to read out the stylename from a wall in which I did insert a symbol?
A WindowCW-Object does know, in which wall it is, how can I access that info for a symbol in a wall from a worksheet?
any ideas?
ah ok, now the constraints work fine
but, everytime I change sth in the space or the data tag the data tag tool adds antoher two lines with height and area to the stamp 😄
I will send the file to our local helpdesk ASAP... 😕
well, I tried to use the constrain-tools in Vectorworks first... you can access them from anywhere, of course, also outside a data tag layout
... inside the data tag instead constrains are visible! (in the US Version at least)
it's aligned left 🙂 however, there are now constrain-settings in my OIP for example (using VW architect)
which constrain type did you choose? I still do not manage to connect the right border of the rectangle to the text 😕
I bet users won't be able to commit changes simultaneously 😉 however, it's going forward for sure
are there any plans for a rock solid project sharing server? Sth based on a database, mysql would be an idea?
(just thinking about it) - but sending and committing simultaneously and MORE security in project sharing would be great, specially when projects are growing and there are more users in a project file... just thinking about it...
@Pat Stanford works in Vectorscript 😉
7 minutes ago, Tom W. said:
Setpref(49, not getpref(49)) will set preference 49 to whatever it is currently not I.e. the opposite of true or the opposite of false.
well, at least now I understand, what you ment 🙂
however, I'm sure @PatStanford does know, how it works
so, setpref(49,NOT... ) sets the pref to not, when it's not already set to "not"?!?
4 hours ago, Tom W. said:
SetPref(1055, NOT GetPref(1055));
so, 1055 is:
QuoteShow Others in Group Gray 1055 TRUE or FALSE
(you can see here on the developer page)
but why
QuoteNOT GetPref(1055)
To do this you can use a script + make a menu command then give it a keyboard shortcut.
which vectorscript command does toggle the "show other objects mode" on/off? 🙂
Hi,
the wall closure i modelled in the attached file works fine in VW 2023 SP6. However the same wall closue is missing in the ifc-file.
(both files attached) WHY?
new railing-tool
in Architecture
Posted
I still am not that convinced, the work is not precise enough imo
