patman
33 -
Reputation
0 NeutralPersonal Information
Occupation
Architecture
Location
Santa Fe, NM
Include this line of code in your script and it will enable the font menu. SetObjectVariableBoolean(gObjHd, 800, TRUE); where gObjHd is the handle to the PIO. Patrick
New objects are created in the active class. A group is a container object. Making a group is making a new object, so it will (and should) be assigned to the active class. HTH Patrick
What you are describing sounds like a PIO. Why not make it a custom object? You can have it regen (or run the creation code) when it is move, resized or rotated. If you place parameters in the OIP you can then make it totally flexible. Patrick
Sounds like a interesting script. How does it differ from just using the split tool? Part of a larger script? Using built in tools in the way you describe is not easy. The selection state of object can change and the list of objects shrinks and grows as you modify the list. I have ended up in infinite loops using this method. I would walk through it in a very methodical way to be sure you are not trapping yourself. Patrick
Well, changing the visibility of layers and classes with the script in a View seams conflicted and redundant, however, you could do it if you want. A more useful task for this would be to change the attributes of a class. For example, objects using the class attributes for a class set to a solid red line can be changed to a dashed green line. You may also want to reorder the stacking of your layers. If you are familiar with VS then try putting in a script that changes a classes' attribute in there and then build from there... Patrick
the VRam for a video card is where it stores each pixels value. 32M is more than enough for a full color 19 monitor. Having more VRAM allows games to store frames within the card for faster frame rates during animation. I do not think VW uses this technology and so I would say you are not going to notice any different between the 2 cards when using VW. The other part of this is the speed of the processor on the card. If you can get one that has a faster processor then you will notice an improvement. HTH Patrick
Are you familliar with VectorScript? It a doable thing from there. I can give you a hand with it if I can get a more clear idea of exactly what it needs to do. Can you send me a file off list that kinda outlines what you need. Maybe an example that is done by hand so I can just copy the process? In short, colors are stored as 3 numbers or a color pallet index number. the 3 number system is RBG 0 to 255 for each one. The pallet index is one number from 0 to 255. I could generate a worksheet with the numbers for each class in it along with the name. I suppose it also could look at symbols but how does assigning a color to a symbol affect its appearance. Guess that is where I am getting confused. Anyway, more words will dispell confusion... Feel free to send me your idea off list Patrick patman@cybermesa.com
Yea, that works. If it is a survey I will draw a line over a long boundry and get the length. Then use the scale objects command and put in for the scale factor the length it should be divided by the length it is. Patrick
You can create a schedule of any object that has a record attached or is a PIO (tool). Are you familiar with the database features of worksheets? Patrick
Are you looking for a text file or worksheet listing all the colors you have assigned to each class? Patrick
Check your font mapping. You may have it mapped to something odd. You can fix all your text by turning all layers and classes on and do a custom selection for text. Then change the font of them all at once. Patrick
It will render only one layer at a time. So you'll have to use Peters suggestion to get it all on one layer. Patrick
I just select the bitmap and drag the handles at the corner or edge. Is this not working for you? Patrick
1. Open one of the scripts you like. 2. Copy the text of the script into the clip board: select all and command+c 3. Goto Organize > Scripts > VectorScript Plug-in Editor. 4. Click on the New button. 5. Select Command. 6. Give it a name and hit ok 7. Click on the Script button. 8. Paste in your code. 9. Click the compile button to be sure it works 10. Exit the VS Editor 11. Exit that dialog. 12. Goto the Workspace Editor and add your new menu command to your workspace. 13. Give it a keyboard short cut. 14. Exit the Workspace Editor. There you go. Now you can use your script as if it was built in. Repeat as necessary. HTH Patrick
Use the Object Info Pallet Patrick
