konst
27 -
Reputation
4 NeutralPersonal Information
Occupation
Landscape Architect
Homepage
https://ktla-ltd.myportfolio.com
Location
Greece
Recent Profile Visitors
459 profile views
Hi is there a way to freeze or hide the automatic jump lines in irrigation design...??????????
@jmichael... In your plant list Simple ..you should go to File....and check the worksheet on drawing..
Hi Wes ..i was wondering how is this possible to do dimensioning in a VP as this sheet is always in 1:1 ....when i try to dimension in a 1:50 detail in my VP the dim i get is not related to the 1:50 detail but to the 1:1 sheet layer of my viewport --- so a 0.30cm is shown as 0.01...is there something that i am missing..?
Landscape Areas - Fill and Pen Opacity
konst replied to loretta.at.large's question in Wishlist - Feature and Content Requests
Yes...!!!!!!!!!!!!!!!!........its really annoying for me as well....i wish they could fix that...!!!!- 3 replies
- site design
- landmark
(and 3 more)
Tagged with:
i finally found out the bug in the criteria...i assigned the layers to be a specific landscape area and that works perfectly....thank very much for your time Konstantinos
Jeff thanks for your interest...the only way to send you the file is by wetransfer as its a quite large file(75mb).........other wise i have to change quite a few things before posting on this site
Thanks Pat that works...!!!!
@jeff prince ....thanks a lot Jeff...thats the best solution but for some unknown reason to me the table comes out as i am showing in the attached file , although i ve separated my planting areas in three different landscape areas with different name and on a different layer....i ll try to find the bug ....
Thanks a lot Pat...I wish there was a simpler way to do that but apparently not.....I have already tried the excel export but it's really annoying if you have to change something and then you have to restart the whole process again....the corp thing isn t functioning as it VW don't allow me to do so....or am I mistaken ?....I Ve tried splitting in different view ports of the table but it's also complicated.....thanks a lot for your time ....maybe VW creators should look at that more carefully Regards Konstantinos
Hi everybody any idea how to split a landscape mass planting table -worksheet that is too long - to fit in my page layout...???...scaling is not the solution as will scale the text.... Thanks in advance
@Pat Stanford ...hI...I finally found the solution to my problem......i open a new drawing and i insert a tag symbol component that i can edit geometry and text. Then i export this to libraries and use it in my future drawings....it took me sometime but its done....
I found this topic in vector works help ....but I can't figure it out....it looks like it's not very correct...something is missing...it's very weird though that there is no way to change the geometry https://app-help.vectorworks.net/2017/eng/VW2017_Guide/Irrigation/Editing_Tag_Label_Symbol_Definitions.htm thanks a lot Pat
@Pat Stanford hi....well I couldn't know that...isn't it a part of the software...????...why localization could matter...????....I am from Greece working in Saudi Arabia and Middle East...i can't imagine how localization interferes in the software....apparently there is no way to change the geometry or the text size of this tag.... thanks anyway Pat.. Konstantinos
@Boh thanks for your time anyway...
