Having a little problem. Light plot drawn and finished in Spotlight 2021, mostly conventional lighting units.
All units have been defined with correct fixture type for Vision 2021 transfer. All colors and templates entered both in the Spotlight color and template data field and also entered via the edit pop up window from the object info palette.
Exporting to MVR did not transfer everything I needed, so I made sure to run updates on Vision and Vectorworks. The export to MVR still did not work, so I tried the send to vision menu option. This transferred all the fixtures and 3D elements I needed for visualization into Vision.
None of the color or template info transferred, and none of the focus information. Next I allocated all color and templates to each fixture within Vision. I adjusted the focus of the entire plot in Vision as well. No worries.
I saved the vision file and it created a file with the .v3s file extension. Everything was working and I was all set to begin programming. When I opened Vision the next day and loaded the .v3s file, none of the colors or templates are still attached to any conventional fixture. The focus remains but no color or template textures.
Have I done something wrong? I am entering color for each fixture by selecting the light by its name within the scene graph window. Then using the properties window to adjust Color Wheel 1 > Slot 1 field. This data does not carry over from 1 session to the next.
