bohlr
    129
Posts posted by bohlr
  1. There is a drop down menu at the bottom on the attributes pallet that give a choice to make an object " make all attributes by class" or if no object is selected it makes the the default "Make all attributes by class". I was looking for a faster way than having to navigate down the attributes menu and then select an option in a drop down menu.
  2. Ok, so i signed up for "Bimobject" entered my user identification key. set user settings "download symbol to active drawings only"
    Clicked on an object on the Bimobject site (thru vectorworks via the Bimobject tool) got to the download window and tried to down load both an IFC and a Rivit model.
    When I tried to place the object in a new drawing I get an "X" with a dotted box around it. But no object is placed, nor is one downloaded into the Resource Browser.
    Any advice
    After further research (I should have continued reading the help section) sketch up file type worked just fine.
    1. Select the file format to download (either  .vwx, or a compatible format such as  .dwg,  .skp, or  .3ds), and click to download the file.
  3. In the "create interior elevations" tool, what is the function of the "Detail Number". Can it be displayed automatically in the interior elevation view port title. I was thinking it might be used to display the room number of a space associating multiple interior elevations to their specific space.
  4. I can make the Double profile eave work - see example set at 6" vert.; however when I add a fascia it projects above the roof line. Also - when using a roof style the Structural Wood Component renders without a fill. It appears that I must manually add a rake trim piece. In previous versions I was able to "fake" the rake by setting the roof thickness to the dimension of the rake and adjusting the roof bearing height accordingly. Any suggestions for 2016?
  5. Good afternoon Wes,
    I am having trouble replicating the Hillside EL White
    First problem seems to be creating HDRI Black background. I attempted to edit HDRI White to black, but when asked to select a different image no image are selectable (grayed out - JPEG file type) What is VW looking for in an image?
  6. Wes
    Thanks for the Worksheet - Helps to explain the nomenclature of the level settings embedded in VW! I have been confused as to what exactly the top and bottom of the structure was intended to define. Worksheet makes it pretty clear - the top and bottom of the structural framing associated with the with story.
    Could you post the file that created the building shown in the two *.png files.
    It might answer a couple of questions that I have i.e.:
    How was the stepped footing and foundation wall created?
    How are the components of the slab styles defined
    How much of the section is created from the underlying components?
    - specifically how was the brick ledge created in the poured concrete wall
    - were the roof sheathing and ceiling material associated with the roof face or added manually to the section,
    Thanks
    Rick Bohl
  7. Is there a way to show added data with a window tag (In plan or elevation) such as the window size. It common custom in my area on residential jobs to show window sizes and operation on the plan rather than creating a window schedule.
    As a work around I have been entering the data manually in the window tag fields. This method works ok - other than taking time - however I have been caught several times changing the window size and not updating the tag info.
    The data is there associate with the window it would be great to get at it and display it in the tag.
  8. When creating an elevation of a roof created using the "create roof" tool with the insert soffit function option, I can not seem to get rid of the line between the roof and the soffit. (see attached file). So far i have tried
    - Ungrouping and trying to group roof face with soffit as a generic solid.
    For construction drawing line elevations I can mask away the unwanted line with a filled shape at each instance but this seems a bit cumbersom and time consuming. Does anyone have any ideas?
  9. I am working on my custom Title blocking trying to get the "Drawing Mumber" and "Sheet Title" to back fill from Sheet layer names as noted in the Navigation-Sheet Layers Box. Does anyone know the field names that I might add to my custom title block Record format.
    Thanks
  10. I have always been mystified by the Framing member tool. The first time I used it the Open web steel joist mode the default settings forced me to place a minimum length truss of 41'4.8". I gave up for a couple of months. After another try and adjusting all of the parameters I was able to get a reasonable looking truss. It seems the panel spacing controls the minimum length of the truss rather than the length being specified and the panels adjusting accordingly to some reasonable setting.
    Has anyone built a truss library containg truss PIO's?
