Landartma
344 -
Everything posted by Landartma
There is a training in the University about batch publishing that might help. Batch Publishing
Yea I was putting them in a modifier layer. It seems to work better when I copy it and paste in place into my modeling layer. I'm thinking of keeping a copy of those layers when the layers go squirrely and create an layer tornado by sending a bunch of elevations a few hundred feet down the on the Z layer. Do you put all modifiers on one layer or keep them separate?
I'm working to get site modifiers working on this site. I have a stepped series of walls. I've tried doing individual Retaining Wall Site Modifiers and the entire connected large section of wall with various levels of success...between crashes. I feel like a new driver burning up the clutch. One thing I'm seeing is in my site model each time I manipulate the modifiers the modifier line grows...Its almost like its making a copy. I've deleted and start over several times as I work through it. Do they reproduce as you work with them or do I have a setting incorrect. I'm also having trouble getting the cursor to recognize the site modifier. It snaps to everything around it but the modifier is tough to get ahold of. After the past two days of modifier fun I'm thinking that from a graphic representation standpoint it may be more expedient to build the whole project from graded pads, hardscapes and landscapes and not bother with modifiers taking advantage of the alignment feature when available. It seems as if there are several ways to tackle the problem.
The help
Are you applying this to hardscape objects, pads, extrudes. I'm struggling to understand how the grade tool works. I read and watch about it but it still escapes me. Likely right there.....The 3d is bending my mind half at least for now. I'll be satisfied on this one if I can get a model together where all my surfaces match up. Got the hardscapes to do it now looking at getting the landscape tool to do it too. It would be great to see continuity between the tools. If hardscape enables an aligned surface with a check of a box and a menu of aligning elements it would be great if all the tools had familiar interfaces. Thanks for
I shut down my machine each night clear cache etc. Still happens. This morning it was on but did not back up for almost an hour....lost work again.
For the second time in the past week my auto save has simply shut itself off. First time I lost a days work. Now at least I check. I just discovered for the second time it was off. Use caution. I'm using VW 2022.
I was clicking around and it went all nuts on me and what I realized that the patio just changed pitch toward the house when I aligned it to the walk. Then I realized I was aligning the wrong things. Upon redo I realized my top step is a 2d3d symbol. It appears as if the Align tool either does not align to those symbols or it only aligns to what I'm guessing was the insertion point on the step so it was kicking the walkway down about 3.5". I created a hardscape with no fill on over the top step and aligned to that...Bingo then I just turned the layer off and it appears to stay in place. I did end up with this little kink in the end of the walk which was much worse when interpolate was unchecked.
Yea I looked all over the course but can't find them. NBD I took this one before so I'm refreshing. I'm looking to figure out how to make my site modifiers update existing grade. I'm doing something wrong...I keep getting wonky results.
Advanced Site Modeling is the tutorial I'm looking at. There aren't any docs attached to it. There's one for the VW to do list. Attach relevant files to instructional media. I'll contact training.
Yes I need to get a handle on all the tools. You simply use the grade tool along the outer limit of your walk. Does that affect the walk or the site model. I have everything laid out pretty much how I want it with tweaks to textures needed and finished planting ETC. Where I'm stuck is the process to get the existing grade to meet with proposed grade hardscapes and landscape areas. My retaining wall modifier is doing weird stuff too. It all boils down to skill so I'll drill for skill today with a bunch of tutorials on that. Any links or advice on the A-Z of site grading in VW are appreciated. The question for the walls is that they won't join. I suspect its because they are stepping up and can't join from top to bottom. But stepping up an SRW is the way its built. Do I need a Retaining Wall Modifier for each wall or is there a way to do one for all the walls?
I going to run through a few old webinars. Are the files given for the courses still available? If so where do I get them. I'm going through advanced site modeling.
Yea I did that with little luck then like magic on my 75th try I got it to work. It still didn't line up perfectly with the patio so I left it level and it looked ok...as a sales tool. Then I put my 2% grade on it and selected the patio to align surface. It did so but aligned with some site model existing grading and bent in two. The menu wouldn't allow me to select layers. When I selected that option the screen just blinked. So I shut off all other layers chose Align to Visible Layers Only and then aligned and it worked. I still have some wonky stuff going on with other site modifiers which I'm guessing is user error.
Is Vectorworks able to do professional grading?
Landartma replied to Anders Blomberg's topic in Site Design
A few questions. I have read through what your all doing here. My solutions are normally less complex than what I see here. What I was getting with align surfaces was one surface or the other but not both. As if you want to align one hardscape surface with two on either side especially is there is a twist. I've been working on that for a while now. I see how @Benson Shaw did it. It makes sense. How did you render it. I have four known corners and I simply need to connect them on a slope that runs along a curve...literally 10'. I have messed with everything. There seems to be no easy solution. -
Gave this a shot and got it to align to my steps but will not align to both the steps and patio. I'm looking at some of the posts on the grading thread you sent. Thanks for relaying that. I'll keep pushing on. It would be great to see a youtube or VW video on just how to accomplish the complex grading...I have a 10' length of sidewalk that wants just the slightest of twist. Anyone who knows of a Video that explains how to do that it would be helpful. I'd hate to think I'd have to model it...This is basic stuff we do in the field with rake and shovel on a daily basis. Although @Benson Shaw seems to have it down.
I'm laying out a fence/railing above a retaining wall and all settings between the two fences are the same but on one side I am not getting the option to Place Post at Corner so I am missing two sections of fence in isometric. Why is that? The odd thing is that I switched to another style I created and now I have the whole fence and looks as drawn in 2d when put into isometric.
Thanks I will definitely give that a try. Everything is connected to a known elevation so as with most things here is much to do with massaging the settings.
Yes Jeff I spend inordinate amounts of time looking for answers that I know are simple. My hair is falling out on my desk. We can discuss privately. I'm in a meeting so I'll be in touch so we can talk about you do.
I did the core certification very helpful but its really just a start. VXU is really the same. I get into situations where I get stuck just don't know what to do. I go back to the videos frequently but its time consuming. I imagine its not everyone but its a steep learning curve for me as I can't be on the machine everyday. Here is what I just posted.
I've been using VW for about 2 years. I have the 2d components down pretty well but have gaping holes in my 3d knowledge base. I got VW certified this year and have about 9-10 hours of 121 training, watched a ton of videos and there are a ton of very generous people on the forum. I'm going to fill in those holes so I can become proficient in the 3d realm. So far I see a few training sessions coming up for about $700.00 but they look basic. The 121 is effective as well especially when specific issues arise. My issue is timing. When I'm stuck on something I need answers as fast as possible so I can get the work out. I can't afford to muddle through multiple videos and maybe figure out the answer. My question to the community is what training systems are they using for general skill development? Does anyone have a solution for the quick turnaround on specific questions? My guess is that to become expert time in is in the hundreds of hours if not more. I'm all in but I need a point A-B training solution and some sort of tech support when I hit a roadblock. What have you VW pros done to get to your level of proficiency? What do you do when your down due to a knowledge gap?
Check this one out. It looks like you are already using your i phone. But these guys are bringing it to a new level. I'm not sure if there is a way to get that kind of accuracy except with a tape measure. I have the same question I still measure manually and shoot grades with a laser although I know there are better ways.
Jeff I struggle with a ton of stuff and it seems as if you can get bits and pieces VWU and help but its tough to get the full picture on any one thing. The various functions of VW are complex. I always search you tube too. The thing that's helped me the most is one on one training. VW has some good trainers that can walk you through the nuance. This is coming from a technological novice so none of this is intuitive to me. I use novice generously. I bought a block of ten hours and will likely buy another block soon. There are also a few trainings coming up...of course it all costs $$$.
So you can scan 100 acres in 30 minutes with an I Phone? Using the 3d modeling functionality? It gives elevations? Locate individual trees and I imagine rock house corners? How accurate is it?
I have a hardscape coming down hill at a 2% grade. It meets up with the steps but maintains a consistent slope plane. When it meets the steps, which are level across, and are connected to the lower walk it is raised to one side. I was able to just use the reshape tool to join the lower walk and step. When I tried that with this hardscape it deleted the image from the screen. I'm not sure if it actually deleted it or what happened but it appeared to be gone. What's the function to get the walk to bend and fit the steps and still meet the patio. Do I need to start over with two hardscapes one for the patio and one for the walk? Is there a way to split the two and create a new hardscape? I tried to Enable Aligned Surface but it just changed the elevation of the entire hardscape. I've been messing with this for a bit and know its likely pretty simple but I'm stumped.
