Landartma
344 -
Posts posted by Landartma
Thanks for the reply on that I will go over with Bryan. It a bit much to wrap my head around now. Thanks
I have the attached flagstone path which was created by Duplicate Along Path. I want to capture the individual pieces into a worksheet so I can estimate the amount of pieces I will need. Is there a way to do it? Somehow I see they are 3d symbols I must have created them like that. I'm not sure if that's an issue. LMK. Thanks.
Thanks.
What would the spreadsheet formula look like for volume of graded base (crusher run). I have 650 square, feet 6" deep, at 115lb/cuft. Long hand Its (650x.5)115/2000=18.7 tons. I'm in a worksheet and have my square footage worked out.
It was the scale. Thanks!
Sweet! got it thanks so much that explains a ton.
Yea I have been looking at the individual graphics in the editor and cant seem to find any difference. When I scroll down the graphics even out and become more crisp momentarily then snaps back to the muted colors. When I print it prints the muted colors on the screen.
Thanks Bryan! I put them into the resource manager drawing folder that I'm working on. When we do the training we can put them into Favorites unless I figure it out by then. I figured out how to do it through the Create Plant Style from Catalogue. Thanks!
I touched on this earlier but am still not clear. I want to create my go to plant list. If I understand correctly. I need to create a template, load a variety of generic symbols into the template, then manually edit each one as I import it via the plant style editor. The path "Get Plant Data", -find in the database, - Vectorworks tab, -Use Currently Selected Record, - manually enter sizes desired? Is there a way to have the Currently Selected Record integrate plant data "sizes" with insertion sizes. Is there a faster way or a way to create a file in a user group once so I can get it done one time and just update as needed?
I tried to create a landscape area from a nurbs. Is this possible? I ended up just tracing it as a landscape area but could not see how to close the curve so now have a jumble of weird vertices. How do I create a closed shape when creating a landscape area? It seems as if it would stare me in the face as it does when working with nurbs on the OIP. Is it just a snap function? I made it work that way but it does not seem to provide the control like in nurbs. Is there a way to manipulate the vertices in landscape area mode like there is in nurbs?
I placed VW boulders in a plan, resized using the asymmetric scaling function. I would like to save them as hybrid objects for when I start working in 3d. The boulders were in a group so I ungrouped them and have usable size boulders for the projects I typically do. I want to save them to a customized or user or work group library. I have looked at several of the tear sheets from VW but I'm not finding the answer. Where is the command to save a custom object to a user or workgroup library. I am working on populating usable symbols so I can start drawing plans in VW.
Thanks think I got it.
- 1
In the process of loading most used plants into resource manager. Everything seems to down load from the data base but the plants are getting assigned a standard height and spread of 12'8" and spacing of 11'. Whats the setting to make the uploaded plant take on the sizing of the plant in the database.
Thanks I messed around with it and have found ways to put those items in.
Viewports
in Troubleshooting
Posted
I have two view ports I want to display different data. One has plant tags one has callouts. The sheet with the plant tags Cover Sheet is to display plant tags. The other, Specification Sheet, is to display the general specs for the job. I want to show the plant symbols on the Specification Sheet but not the plant tags. The plant tags show up on both but when I go to shut them off on the OIP tag function it takes them from both. How do I unlink the two viewports?
