I am revisiting cable suite in VW2022, unfortunately I’m encountering a number of hurdles which I’m not sure are operator related or otherwise.
Customised Distribution and cables
Working with the files within ‘Applications / Vectorworks 2022 / Libraries / Defaults / Cable Tools’ I note that for whatever reason there are no dimmers in the Distrobution EU file. As such I’ve added one, that said if I import directly from that file (normal route not working and I’ll come back to this) it still thinks it is a distro (it was copied from one with an edit to the data to make necessary changes, type, input and output connections). What is the required syntax for these changes, given it would appear editing the data doesn’t cut it?
I also edited some of the cable files in order to add a 1.5m length to jumpers and data options. However when I open a new file and look for either of these 1.5m cable lengths or the aforementioned Dimmer, there is no sign of them. It would appear that an alternate set of files are being referenced.
I have also noted that customising the cable parts does not appear to alter the global value. What I mean is if I remove (untick use) for say imperial lengths and US only cables these changes are only valid for that file, leading to my having to do the same for each file or save as template. It would be handy to do so once and for the changes to be recorded in the associated XML file.
Lastly, more of a feature request. Given the methodology (if I understand it right) it would be great to have ‘Cable sets’ that can be loaded into a project, similar to the way Sam Jones’s Cable Tools can so that if you change suppliers you can ‘load in’ their cable lengths (as we know, not all suppliers carry the same lengths of each cables and that’s before you look at different geographic territories). If you were to detail the respective lengths and cable types in an XML file which you then choose through the cable preferences before recalculating the cables used.
Thank you in advance.
