Andrew Lock
    7
Reputation
1 Neutral
Personal Information
  • Location
    United Kingdom
Recent Profile Visitors
  1. Thank you so much Raymond. This works well. Andrew
  2. Pat I know this is an old thread but is there any chance this script can be made to change all the sizes of the font as well? Many thanks Andrew
  3. Dom, thank you so much for this and taking the time to help. I will give it a go. Andrew
  4. Pat, thanks for getting back to me. I have a series of 'exhibition cases' in 3d ( they are essentially a box with another ' glass' box on top of them) that I would like to be able to make wider and shorter through the OIP. I was looking at Dom's examples of making columns and windows wider, higher and thought I could use his node to do this. His post is below. Is that sufficient information? Many thanks
  5. Hi I have been trying to use the reshape node in marionette to make an object that I can change the size of in the object info palette. . I have been following the great tutorials by DomC but can't get it to work. I have made the object I wish to change the size of as a group with the dimensions labelled with a prefix to link to the marionette node in a different group. Then grouped this all as a symbol and made it into an object node. I think I am failing to link the object to the marionette script somehow. I have made a very simple file to learn but can't understand what's not working. I am just beginning with Marionette so excuse me if its obvious. Would anyone be able to help me or point me in the direction of some more tutorials? Many thanks Reshape_attempt.vwx
  6. Dom This is fantastic, just what I need, thank you for sharing. However I am a beginner at this and can't get it working...I am just trying to rebuild what you have already done to teach myself how to do it. I am sure it is something to do with linking the dimensions to the script? Is there any chance you could give me any pointers? I have attached the file. Many thanks Andrew Reshape_attempt.vwx
  7. Hi I want to create a series of different sized rectangles using worksheet data, label them with data from the worksheet, and create symbols for each rectangle and label. I have made the script using marionette but cant get the script to input the labels names. It just returns '0.0' rather than the text in the worksheet. I have attached the file. If anyone can help that would be great? Thanks object_generator_v2019.vwx
