Hi all,
I wrote a script, which get a Text input and makes a 3D Text out of it. It's similar to the 3D Text along path command.
The output are a group of Extrusions of Polygons. When I scale this group via the menu command I get the result I wish to have. Maybe get it half the size.
When I put the scale command inside the Script, the output is not the expected but it looks that the Y-scale of the group stays the same as before, only the extrusions are sacled.
I tried to ungroup the text before I scale with no change of the result. I had the idea, to merge the extrusions to one volume, but cannot find a marionette node which is doing this.
Any ideas from your side? I added the script, maybe someone of you have an inspiration 🙂
3D-Text.vwx
