Robert J
    16
Everything posted by Robert J
  1. For me Log Out user in Vectorworks 2020 resolved the problem. It looks like 2020 cause conflict at new 2023 login procedure at startup. No crash enymore.
  2. Hi, Is Enttec DMX USB PRO Mk2 or Enttec Open DMX Ethernet Mk2 compatibile with Vision 2022? I have specific instalation where I need DMX input from that device.
  3. Thanks, I workaround this by attached record to marionette object. This was a suggestion in similar problem on forum. I agree. Text, StaticText, StaticTextParam should be updated during updating Marionette object and should be visible in OIP.
  4. Hi, @Alessio Did you resolved this problem? May be this is a bug. I am trying to do something similar. I figured out that StaticText in wrapped object works only if node have no input. Output only. Inputs disabling text in OIP. This is strange. I have no idea how SetValue without inputs. Is any different way to take value and put in somewhere in code without nodes? Who can help us to resolve this magic static text behaviour? Edit: It looks like OIP is generated ones during startup and edit code. No way to refresh OIP during object working or I do not know how. Anybody known any tips for this? One way I know is using Text object or record Database with Worksheets.
  5. @Boh I noticed that Active layer have to be Visible. Invisible or Grayed do not works even if are Active. @Sam Jones I found that GetLVis procedure cause this problem. I analyzed this script and I think this is it. Do you known how fix it?
  6. @Pat Stanford I know this is a old topic but I have tested script in 2020 and I noticed that VSEL criteria works better than SEL. Do you agree?
  7. Hi @fuberator You can use Vision without GrandMa hardware. You need Vision usb dongle licence and MaLighting drivers instaled. I tested it with GrandMa2 OnPc on two PC. Works great. All dmx parameters unlocked without console. For ArtNet or sACN you need console connected, I think. Look at here:
  8. Hi, How change curved geometry quality in MVR export? Look at front stage edge. This is a simple poligon extrusion.
  9. Hi, Why my texture difference beetwen Spotlight and Vision? This is a simple extruded rectangle and MVR export in 2020 SP2
