RainCity
    5
Everything posted by RainCity
  1. Thanks for you feedback. I've attached the file but it is a project sharing file so unsure if this will be an issue? Let me know if you come up with any good ideas. There are probably a couple of hundred tags so finding and manually changing them all would be pretty arduous. Cheers, R XXX Project Set.vwxw
  2. Hi, I'm having this problem in SP7 in a shared/server based file. Video attached. If I edit the data tag style (change the diameter of the data tag for example). Every tag defaults to A20. I've seen this asked before but most people say it has been resolved in previous service packs Any work-arounds or fixes to this? Screen Recording 2023-09-22 at 2.32.54 PM.mov
  3. That's right. It happens on a few. I'm trying to figure it out myself, I think it's a glitch when the wall in elevation joins a higher wall which is perpendicular to the view: https://drive.google.com/file/d/1MVzgN8D1TQWnsTURfaJjfQOnFLnwfkrG/view?usp=sharing
  4. Thanks Matt, They're not perfect but I can clean the the views up in annotations. 1. Altered height extents: 2. Cropped:
  5. Hi There, I'm having some trouble generating the internal elevations which face my external walls. As most of my internal walls meet the slab above at finished ceiling height they look good. However my external walls continue passed the slab as it hangs off them. See screenshot below for how the space works in elevation: https://www.dropbox.com/s/o3xuaiuvx3716li/Screen Shot 2019-11-12 at 3.29.54 PM.png?dl=0 But when I turn off the slab layers the wall appears higher than is actually is: https://www.dropbox.com/s/ry4ukoyemc97lbj/Screen Shot 2019-11-12 at 3.30.09 PM.png?dl=0 Any idea on how to get this to work correctly? Cheers,
