louisesamsin
    7
Everything posted by louisesamsin
  1. @DanT thanks DanT. We have vectorworks 2020 landmark edition in the office. I investigated it's SCI function yesterday and it looks like it hasn't progressed any since you looked at it. The SCI fun croon seems to be just a simple vectorscript which inserted a light source at a nominated height. For some reason, when I placed it on a test terrain, it also shone "through" the terrain to hit other facing terrain planes...!?! This isn't something substantial enough to add to a report and be able to quantify effects in any meaningful way. I appreciate that you got back to me and wish you all the best.
  2. I don't suppose you ever got a response to this? I'm currently investigating same. Thanks
  3. I had another file which wouldn't export to a dwg. Saving a copy of the file with a simpler name then using it to generate the .dwg got around this. Thanks for the tip.
  4. Aha, a good old fashioned purge solved this one. Purged then tried again and it exported successfully
  5. I'm trying to export a file to dwg format and get an error message advising that there is an ODA Platform error and a dwg is not produced. We are just switching over to VectorWorks from AutoCAD so the original drawing was generated in CAD then imported into VectorWorks. Now I have to export as DWG again so as to share it with other consultants. I tried exporting as older DWG files and including referenced files as separate layers instead of separate files. I still get the same error message. Any solves would be appreciated. Thanks.
  6. Looking to buy a license for Vectorworks Landmark 2016 or newer. Email me on innerwellnesswithlouise@gmail.com Thanks
