KristianN
    2
Everything posted by KristianN
  1. Hi, happy new year! When I export a DWG file, then the stacking order isn't correct in AutoCAD. It appears to be an issue in VW 2023 as previous versions exported DWG appearance identical to VW file. I have tried everything I could think of. I appreciate if someone could help us to find a solution 🙂 test.dwg test.vwx
  2. Hi. When I import an IFC arhitectural model (made in Archicad), then some of the walls etc are missing (see the picture on right side). When I just open the IFC file in Solibri (an IFC viewer) just to have a look on it, then everything seems to be correctly displayed (see the picture on left side). What could cause the problem??? (I had similar problem actually before also with another project). I use Vectorworks Landmark 2020 and an Imac Pro. Thank you!
