Hello Everyone,
I have followed the thread and although the answers provided work to change the parts of a drawing they don't however provide a workflow solution like a "view template" in revit which works as one action to turn a drawing's features as the template has specified.
For example - In Revit, if I had 10 building section drawings with hatches and I wanted to change the visual presentation so the section cuts all read as black I have to go to each drawing and apply the view template, done - it changes everything in the drawing with how I have set up the template(changing hatches and lines) in one click. The answers above suggest that in Vectorworks you need to go to each drawing individually and adjust the classes accordingly, which means going through my class list turning the appropriate classes on, off, and adjusting for each drawing. You can imagine if you have many drawings to change for a particular presentation this could be quite time consuming. Even more time consuming if one needed to revert back to the original hatch/line types for a different presentation. So back to the original question, is there some sort of "template" that can be applied to a view that can change all the specified classes in one click similar to Revit's "view templates"?
