Eric Marin
    19
Everything posted by Eric Marin
  1. Thank you very much Tamsin, you were right, I had made modifications to the workspace and it was saved as a new one. I already managed to install it. Thank you so much!
  2. I am trying to get radial vertical contours and my network made it, but despite the contours are created, I am not able to do anything with them because the contour node shows 0 as output... modelo-2.vwx
  3. Does this mean that the AI Visualizer isn´t available? Ia have been unable to get the command line, even doing everything that has been mentioned here
  4. Major architecture and design software are moving towards incorporating new AI-based tools and processes. Will we see new tools inside vectorworks in the near future?
  5. Thank you very much. by now, I am doing the extrusion through the menu commands, but I will still trying to find the issue in the network
  6. How can it be? I'm pretty sure I've done those extrusions before. Anyway, how could I shape that piece of the structure? Please, give me any suggestions.
  7. I am working on a roof structure but the final step does not work. I do not understand why, got the 3d poly but it disappears after trying the path extrude. I will be very grateful if someone can help me with this 2204-DI-DE-v03.vwx
  8. Hi, I am trying to do a solid truss, Although the solid boolean node was working fine during my first steps, it suddenly stops to work properly. It continues to work for subtract and intersect, but not for addition. cerchas v03.vwx
  9. Thanks Andrew, I was thinking the same, but I wanted to confirm by listening to other experiences.
  10. Should I upgrade to Mac osx Monterrey? Will there be a problem with the performance of Vectorworks and Twinmotion?
  11. Hello Marissa,
    I have a series of columns created by linear extrusion at different angles. Since I need to scale them after being generated, I added a scale node but it doesn't work, although it doesn't give an error either. Is there any other way to do it? I wonder if the extrusions can be turned into a different type of object to scale them all at once, keeping their location .. Thanks!
  12. I need to install these Phyton libraries, It is supposed to be a one step that VW should do when needed, buy I am getting a “Module Pil cannot be installed” pop up window. How can I manually install these modules? Mac OS X 10.15.7
  13. Thank you, Wes, your temporary solution works fine! The only thing is that you have to go window by window changing the panel fill... Thanks again!
  14. Ah, ok, Thanks! I will address it in annotations...
  15. I have fill in the Glazing class and the class is on in the viewport. These are curtain walls made as symbols (in order to be inserted in the walls) Maybe that has something to do? I also checked for fill in the curtain wall panel attributes but still having transparency
  16. I have tried some things, but can´t solve the issue
  17. Thanks Wes, this is my elevation viewport. As you can see, the glass has transparency, that is why it shows the stairs, among other things
  18. I just need to know how to make the glass surfaces not to be transparent in elevation viewports. Thanks in advance
