SimA
    106
Everything posted by SimA
  1. Hello KingChaos I was almost able to turn the network into an object. During the conversion process, the furniture selection opens by itself a maximum of twice before the crash (picture). I think that this leads to the crash. So I suspect that the Get Symbol from Folder node is causing a problem, or at least is beyond the capabilities of the computer. This node may open so many times during the conversion process that VW will exit. Your file with "black symbols" is contained in the attachment as an object. The problem is, that way the symbols can't really be edited. Have you already tried to start the script with another input? Have a nice day. Hallo KingChaos Ich konnte das Netzwerk beinahe in ein Objekt umwandeln. Beim Umwandlungsprozess öffnet sich vor dem Absturtz immer maximal zweimal die Möbelauswahl von selbst (Bild). Ich denke, dass dies zum absturtz führt. Daher vermute ich, dass der Knoten 'Get Symbol from Folder' ein Problem verursacht oder zumindest die Leistungsfähigkeit des Rechners übersteigt. Möglicherweise öffnet sich dieser Knoten beim Umwandlungsprozess so oft, dass VW beendet wird. Im Anhnag ist deine Datei mit "schwarzen Symbolen" als Objekt enthalten. Das Problem ist, dass so die Symbole nicht wirklich bearbeitet werden können. Hast du das Script schon mit einem Standart Input versucht zu starten? Einen schönen Tag. 21058 07 Testschränke-3.vwx 21058 07 Test Cabinets-3 Kopie.vwx
  2. I once had the problem that the assigned names were not written into the database. The problem was on the one hand with double naming and the fact that I only caught the group with the marionette, but not the objects contained in it. So far I have been able to work around the problem of inserting an element designation for the part designation. Example: W EG 03 frame left W EG 03 frame right I also divide the whole thing into its own class structure. If I had to do the whole thing the other way around, I would probably experiment with "If In String" with the position description and a consecutive number. Now there is apparently the problem that DomC described. According to which the "name" of the piece of furniture cannot be assigned by Marionette. I wonder if the second "name" might not be useful right away. See information pallet. Ich hatte einmal das Problem, dass die vergebenen Namen nicht in die Datenbank geschrieben wurden. Das Problem lag einerseits bei einer Doppelbenennung als auch daran, dass ich mit der Marionette jeweils nur die Gruppe erwischt habe, jedoch nicht die darin erhalteten Objekte. Bisher konnte ich das Problem mit dem einfügen einer Elementbezeichnunge zur Teilebezeichnung umgehen. Beispiel: W EG 03-Rahmen Links W EG 03-Rahmen Rechts Ausserdem unterteile ich das ganze in eine eigene Klassenstruktur. Wenn ich nun das ganze den umgekehrten Weg machen müsste, würde ich warscheinlich mit "If In String" mit der Positionsbezeichnung und einer fortlaufenden Nummer experimentieren. Nun gibt es anscheinend noch das Problem welches DomC beschrieben hat. Wonach der "Name" des Möbels nicht von Marionette vergeben werden kann. Ich frage mich, ob der zweite "Name" nicht gleich nützlich sein könnte. Siehe Infopalette.
  3. @KingChaos Ich kann den Knoten auch nicht in ein Objekt umwandeln --> Absturz. Ist es möglich, dass die Kontrollgeometrie Schwierigkeiten macht? Habe vor Kurzem eine Kontur in eine Gruppe verfrachtet und anschliessend den Gruppennamen für die Erzeugung des Objekts verwendet. So kannst du übrigens auch mehrere Geometrie gleichzeitig (in der Gruppe) verarbeiten. Gruss
  4. I am currently writing the data to a database. The objects get the input from this database and change accordingly after the update. ...Google translater....
  5. Hello everyone After spending some time searching, I think I've found a workable solution. Everything is trial and error. I can now align an object at a 90 ° angle on any surface. The attached file works with a NURBS surface and a 3D object (example). I found the special node "PtArrayStartEnd v002" in a network of @DomC. Thank you. Is there a way to calculate the workflow and do without the graphic elements? Many thanks for your help Test.vwx
  6. Is it possible with "Get Degree" to get the curvature of a NURBS surface (not a curve) at a certain point, for example at the locus? Alternatively, I would have to create objects and read their rotation with "Get 3D Orientation". Thank you for your help.
  7. Hello everyone I find this workaround interesting. If the Nurbs curve is bent in XYZ then I would need to duplicate the Locus points along the path. correct? @sbarrett Is there some way to get the alignment of a Nurbs surface at point XY --> Get Z at XY "Get Degree"? Have a nice day Greetings from switzerland
  8. Hello Maybe the Get Segment Type node will help you. However, you may have to split the line first. Are you building a g-code converter? Wishing you a nice day
  9. Hello Antonio If only it was always so easy to solve problems. I used the Parent PIO node because it can be found in most of the functioning networks in the forum. As a beginner, I can just leave the knot off. Another theme ... As a professional, how would you import an external database or CSV file? I would filter the values with Marionette and continue working with the filtered values. Thank you
  10. Hi Antonio The problem remains the same. I have unique names or labels for every single bar in the marionette object. These names or labels do not appear correctly in the table. The dimensions, however, are correct. I have noticed that this problem only exists with the marionette object. The list serves as a material list. I have a piece of each ingredient. It is also wrong if "frame below" is displayed twice. Thank you for your help.
  11. Hello Pat Basically everything works until I wrap the network and turn it into a marionette object. 1. As a script network, i can name the bars and read them of correctly in the table ("Item" A, B, C, D). 2. If I run the tool as a marionette object, the names are no longer correct ("Item" A, A, C, D)....? You can find .1 and 2. on a separate work plane as an example. The script and the object contain the same network. I think that the problem is to be found in the creation of the names or in the DB connection. Thank you for your help
  12. Hello Pat I have a proper name for the DB object. For comparison you will find the whole thing as a normal script in the file. Do you know how to solve the problem? Thank you very much for your help Greetings from switzerland (Google translater) DB_2.vwx
  13. Hello Gregi Can Solid Boolean V3 1.0.0 recognize and process individual classes? thanks
  14. Hello everybody I have the same problem. Could there be an outdated, pre-installed version of Phyton on the Mac that is hindering the script? Thanks for your feedback. Greetings from switzerland
  15. Das was ich brauche funktioniert. Leider benötige ich zwei Symbole (balu und schwarz). Ich möchte lediglich eines. Wer kann helfen? Danke Google What I need works. Unfortunately I need two symbols (blue and black). I just want one. Who can help? thanks Symbol DB.vwx
  16. Hallo Zusammen Ich möchte diesen Knoten als Steuer-Element benützen. Das Symbol im Zubehör-Bibliothek ist mit einer Datenbank verknüpft und soll nicht in die Zeichnung eingefügt werden. Die Werte in der Datenbank werden nicht angezeigt... "sFldValue" Wie bekomme ich die Werte? Danke für eure Hilfe Google Hello everybody I want to use this node as a control element. The symbol in the accessories library is linked to a database and should not be inserted into the drawing. The values in the database are not displayed ... "sFldValue" How do I get the values? Thank you for your help Symbol DB.vwx
  17. Hello Jim Is there a way to shorten a nurbs surface with a marionette node (negativ "extend Surface")? Thank you for your feedback. Have a nice day
  18. SimA
    Nurbs Surface
    Hello everybody Is there a node that does the opposite of Extend Surface? Have a nice day
  19. SimA
    rotate list
    Hello The path is defined ... Now I have to create a parallel with a certain edge distance to the nurbs surface. What will such a marionette network look like? Thanks for your ideas and comments.
  20. SimA
    rotate list
    Hello AlHanson Yes, I think the Idde is good. maybe you look at the file. I don't want the red lines. I want a connection from brown to green (blue). the colors are used for explanation. I need the path. Do you have any idea? Thank you!
  21. SimA
    rotate list
    Hello everyone my marionette generates 3d points and puts them in a list. I convert the points into a 3d polygon. I would now like to change the direction to end-start. ideally, the list is sorted first (z-a) and then the polygon is generated. can you help me? Thank you
  22. Hallo Patrick Ich finde die Helix ein Super Werkzeug. Gibt es eine Möglichkeit das Script auf eine beliebige Nurbs Fläche (Namen) anzuwenden? Als Startpunkt würde mir "Get Gravity Center" hilfreich erscheinen. Danke für deine Rückmeldung. Ein schönes Wochenende.
  23. SimA
    Nurbs Surface
  24. SimA
    Nurbs Surface
    Hello Claes Thank you for your help! I think of a puppet node when solving it. Do you know your way around there too? Have a nice evening.
