Conrad Preen
Vectorworks, Inc Employee-
1,019 -
Everything posted by Conrad Preen
ConnectCAD Check Drawing - duplicate circuits
Conrad Preen replied to Ross McLee's topic in ConnectCAD
Hi @Ross McLee I thought the Check Drawing command did that. Could you please PM me the file in question? Conrad -
Hi Thomas My 2c worth... I would not use the class system to control whether a socket is enabled for connection or not. Classes get turned on and off for all kinds of reasons. In 20 years you are the first to express the thought that duplicate sockets in duplicate devices might be allowed if we could somehow mark those sockets as disabled. Others may have thought it but they didn't say. It will take a few more votes to persuade me that the current way is wrong. Seems to me we should look at why it feels hard to reconfigure a bunch of sockets in a device. Getting Check Drawing to ignore intentionally duplicated devices while detected accidental duplicates - that could be interesting. So the question in my mind is what if that intention goes away in a subsequent iteration of the design? Suppose we did somehow mark a duplicate as being intentional then how would it get unmarked? We will think about it. Not promising anything. I still like that fact that Check Drawing has no state. Like justice it is blind. Cornad
Hi @teedd I have the feeling that this may be a case of mixed service packs 2021SP2 and SP3. If one of you upgraded and the other did not then saving back to SP2 can cause this kind of thing. Is that the case here? Thanks for sending us all the files by the way - this really speeds up diagnosis. We investigate and get back to you. Conrad
Dear @Thomas_ First of all, you are not limited to the devices we provide. You can easily create your own and you can edit the standard devices to create what you want. What you describe with a pass-thru connector is a term panel where you have a cable connector on both sides. Check out how these are configured and maybe that will be a solution for you? Conrad
Also you can set the Text Align parameter to Above. Thanks for sending the images of how you are using custom panels. Originally I had not envisaged these being used to depict standard rack mount panels. When I was a designer they never gave me enough time to draw these things in that level of detail. Now that I see what you are doing I will keep that in mind and see how we can accomodate this better. Thanks Conrad
Just to add a note here. ConnectCAD allows you to have two devices with the same name on your schematic BUT, it thinks you are talking about the same device. If these two devices have two sockets with the same name ('cos you duplicated the for example) then that's registered as an error. Why? well think how confusing the cable list will be when the installer sees the same device and socket names with two cables going to the same connector! ConnectCAD isn't a policeman. And you can break the rules if you like - just remember to fix the naming before you go. Regarding performance interesting to see if we can reproduce that. Conrad
Thanks for your input!
Hi @Thomas_ The mostly likely reason for the "not working" thing is snaps. If your sockets are off the grid and you have snap-to-grid on only then the tools miss the point. You can enable snap-to-object or align to grid using Cmd- (command or ctrl and the minus sign key) or the Align to Grid menu command. CTP connectors are a bit special because they chassis connectors. Everywhere else in ConnectCAD we only talk about the cable connector. So a chassis connector can be of two types plug or socket. The sockets have the special X orientation which allows them to accept an incoming connection on the left and source an outgoing connection to the right. So on a schematic one side of the socket has bare wire ends on the cable ( going to the back of the chassis connector) and the other has a normal cable connector. We use the types IN and OUT to distinguish these. That's the thinking. Hope I've helped. Conrad
Hi @Wade Yes Plug-ins\ConnectCAD_Data is still the place where the signal and connector types go. I am a bit puzzled by what you're seeing but I have nothing to go on yet. Could you PM me the file that has the disappearing names? and also the Signal and Connector types files that you want to add? Could be something to do with the format of those. Conrad
Hi Ean, Yes I'm seeing that and I'm filing a bug. Thanks for letting me know. Conrad
Hi @Ross McLee I checked the file. I think these arose because you renamed the device the circuits were connected to. When I select one of these circuits the source and destination device is Loudspeaker. So I suspect that you created these by accident during a duplicate-modify operation. You can tidy these using Custom Selection. We'll select for Circuit.ControlPoint03X = 0 and just delete them. Best Conrad
- 4 replies
- 2
- zero length circuit
- connectcad
(and 1 more)
Tagged with:
Hi Ross, If you see this again could you save the drawing and PM it to me? It might be something we should look into. Thanks Conrad
- 4 replies
- connectcad
(and 1 more)
Tagged with:
Hi Nick, Just to be clear. You need to start from a blank document (not the template). Import your .dwg. Set up the snap grid. Leave Unified View on. If you want your schematic on a separate layer from your floorplan create that layer at the same scale (1:50 right?). Now start using ConnectCAD tools. As you add devices / sockets etc. everything you need gets imported and scaled to match your snap grid setting. Note: changing the snap grid will not affect objects already on the drawing or anything containing symbols already imported and scaled. You need to set the snap grid at the beginning and leave it there. Any questions just let me know. Conrad
Hi Kevin Busy time of the year. This has a Marionette feel to it if I'm not wrong. You want to have a grid view of a connectivity drawing- correct? Be even cooler to do the interface to the hardware and join that to Vectorworks. Conrad
Hi Nick You can draw your schematics on the floor plan. Event planners like to do this because they can read the cable lengths directly from the perimeters of the circuits. It's quick and dirty. What you need to do is set the snap grid to a suitable value. The snap grid controls the size of all schematic objects. If your floor plan is at 1:50 grid sizes of 125mm or 6in will look nice. But you'll have to see what works for you. Set up the grid, import your DWG, then start using ConnectCAD. Symbols are automatically imported from default content as required and scaled to your grid. So don't go changing the grid halfway through! Hope that helps and I'd really be interested to see how this looks. Conrad
Hi @Ben59 Let me chime in here. I think you are jumping to conclusions. ConnectCAD is perfectly suitable for designing systems inside and outside racks. Many people use it every day for these purposes. Equipment items on floor plans and in racks are different from devices on schematics. If they were the same we would use the same object! An equipment item is the physical device. A schematic device is a container for some or all of the connectors available on a particular type of equipment. There may be more than one device on a schematic associated with the same physical equipment. For example, an audio-follow-video mixer would appear on the audio schematic AND on the video. Patch panels are divided into multiple devices so that you can place them into circuits. That way your schematic will illustrate the signal flow - its primary purpose. What this means in practice is that we cannot easily automate the creation of devices from equipment - because we do not know what is the configuration of those devices. Going from a schematic to physical equipment on the other hand is easy because each unique device name is one piece of equipment. In fact the name is the only thing we absolutely need to know in this case. The size, power and weight can be set later if need be. But let's look at how we could implement what you want for a moment. We have two cases: 1. the type of equipment / device is recorded in the Device Builder database - then we would create a device with all available sockets for that type 2. the type of equipment / device is a standard type e.g. patch panel, term panel, distribution amp etc. - then we create a standard device 3. the type of equipment / device is unknown to our database - then we create a blank device and you add sockets etc. All sounds great until you look at the details. By the time you've sorted out this mess of devices placed around the edges of your drawing, configured the blank devices, removed irrelevant sockets from Device Builder devices, you are probably looking at the same amount of work as creating the schematic from scratch. The bottom line is that there is always some work involved. I don't want to sound negative. We the ConnectCAD team are committed to working to make designers' lives easier. And these discussions are part of the way we move forward. I'm ready to work to support any workflow as soon as I can see a way through. Thank you very much for sharing these thoughts. Vectorworks 2022 will have many features that you will find interesting! I'm looking forward to working with you to make it even better. Kind regards Conrad Preen - Product Planner ConnectCAD
@tk_ Agree. The forum search engine leaves much to be desired IMO. If you search topics then you have a chance. Inside threads it becomes unreasonable. I would encourage everyone to create a topic unless you are absolutely sure. When we attach these to bug reports it's way easier if it's a short thread. I'm certainly not criticising, just trying to make the best of what we have. Just FYI and for all the others out there. Conrad
@tk_ Just a note. New topics cost nothing 🙂 and they don't allow me to move stuff for you.. So to avoid having your question buried in the noise here.... please create A NEW TOPIC 🙂 Conrad
Hi Dave All I can suggest is this. You are admin, so you can see who is the owner of the files and what permissions are set, and change them. I don't think this is a Vectorworks issue but you can contact Tech Support and they'll do their best to sort it out. Thanks for the feedback. Conrad
@DaveMvM Hi Dave There are a godzillion connectors in the world! But you aren't stuck with the ones in the application - you can add your own. Here's how https://forum.vectorworks.net/index.php?/topic/68432-did-you-know/&do=findComment&comment=351755. Feel free to add the connectors and signals that you need. They are saved in the user folder so you can use them in future projects. For bare wires we use - - > or < - - i.e 2 hyphens and a greater than or a less than sign. Bare wires is not really a connector, its like "no connector". So even - - - i.e. 3 hyphens meaning unknown connector would probably give the installers the right idea. Hear you about tutorials. May I use that as a quote? I am going to elevate this issue because I simply can't do it all. Conrad
Hi @Fig For the years we've basically either used a device or cabling to represent this kind of thing. A device has the advantage that it has a make and model, and appears in the device list so it is more likely not to be forgotten. But as you say you end up with extra circuits. Modelling this as a set of circuits is OK if it isn't a special order item and gets made on-site from general installation materials. In short this question has always been there. I've tended to err on the side of keeping ConnectCAD as a whole simple. I have a new object on my roadmap that will represent these adaptors / breakout cables. So this will be resolved in a coming version. I can't tell you exactly when because that isn't my call. Best Conrad
I've got to admit you have me worried, Ross. If ConnectCAD seems like such a mountain then I would really like to know where you are getting stuck so I can "flatten the curve" as it were... Conrad
- 8 replies
- connectcad
- devices
(and 2 more)
Tagged with:
Hi Ross We'll keep that in mind but it's probably worth re-posting it here https://forum.vectorworks.net/index.php?/forum/19-wishlist-feature-and-content-requests/ since it's more of a general request than specific to ConnectCAD Conrad
- 3 replies
- connectcad
- snap settings
(and 1 more)
Tagged with:
Guess that's something we could think about. Meanwhile it's quite easy to work around. While you've got your devices selected just type in the new prefix with a space at the end and then renumber. Conrad
Sounds like a job for a scripter...
- 8 replies
- connectcad
- viewport
(and 1 more)
Tagged with:
