Erich
    9
    Never
Everything posted by Erich
  1. Copying and pasting objects with different layer and class info results in the objects attaining the active settings. Same with grouping objects. This is sometimes usefull, but not usually. Maybe adding the shift-key to the command key would be possible when wishing to preserve object info. Duplicating objects is the only work-around, but can be cumbersome.
  2. Symbols cut into a wall the entire width of the symbol. This constraint limits the use of, say, doors with a 180 degree swing. Similarly, windows with sills extending wider than the opening will do funny things, create holes in the wall, visible in a 3D rendering.
  3. Also, the text alignment setting gets lost upon closing the document
  4. You are right. Workgroups Referencing performs the desired action. This is a very powerful tool. The only problem: the layer names on the referenced document have to be changed in order to be imported. Not too big a deal, and for the way the system is designed, probably necessary. Thanks.
  5. Maybe so. I'm not familiar with Workgroup Referencing. From a scan of the info in the manual, it sounds like the AutoCad and Bentley Viewport and referencing systems, which are very useful. But in VW, I have often prepared floor-by-floor separate drawing files for eventual export to AutoCad (which can't print/plot to multiple pages), and then want to consolidate them into one VW drawing. The layers are the same on each sheet, or nearly so.
  6. Scenario: you want to incorporate an existing drawing with all its various layers into an already open file. Can't be done, unless you laboriously copy and paste, worry about registration, etc. An analogy would be importing one database into another. Most database applications allow this, and have a dialog box for matching fields (in our case layers). Would add a lot of functionality to VW. Realize that with Classes, this could get hairy, but screw the classes; layers are the important thing.
  7. In both animation settings and if the working plane is moved, and maybe other settings as well, these don't save with the drawing; they have to be reset each time a drawing is opened.
  8. Regenerating a rendering when selecting the print command, same for selecting an animation option, seems redundant and it is frustrating.
  9. Erich
    Blue skies
    Backgrounds aint easy. After reading your note, I decided to try to accomplish it. The result is at http://www.tiac.net/users/hfp/house/ The way it was done: A ?View? layer is created for layer linking of those to be seen in the rendering. After much fooling around finding the right viewing position, save the view. Really a time-saver. Now for the background: Flip View layer to Top Plan. Create a giant circular wall. This one was about 150? radius, 150? high. Create a texture for the wall: I robbed a sky jpg image from the internet, loaded it into Photoshop and fooled around by enlarging it to approximately full height for the VW drawing, and blurring to make it look decent. Open a new VW drawing. Import the new Sky.jpg image into the new drawing. One of the 2D tree images was used from the VW symbol library. Copy it a hundred times across the bottom of the sky. Group everything and mirror as many times in width as necessary to match the round wall circumference. Export the resulting image in .jgp format. Go to the VW View layer with the round wall and open the Resources Menu. Select New, Texture. Open the Sky.jpg image from the file, name it, and now you are only about three hours away from being done! Select the round wall, hit the texture tab on the Object Menu (check whether it?s going to be on the right, middle, or left side). Go to the Object Menu and hit Mapping, to see what it (might) look like. Now, if you have a light source, click on it. In the Object Menu, make sure it?s a Point Source, with no distance fall-off. Amazingly enough, the Directional light that defaults when you set the sun position will not work with this wall as a background, unless the sun?s elevation is above the wall height. If you create a semicircular wall to let the sun in, this will work, but the wall will have shading on it. Also, if you create animation, your world (background) will have a giant hole in it. Then go to the Saved view and let RW do it?s thing. The rendering shown in the example above took many attempts to get everything right, or as right as it shows in the picture. It only took about six hours, but this is maybe typical for a first attempt. Now, I have a stock background that can be plopped into any drawing.
