Ok thanks for clarifying this. From my perspective its very rarely crashing now as opposed to an almost a daily occurrence.
I was simply pointing out that, even if I am technically not correct about the HBM2 memory, that it is a very good card for stability and a large amount of VRAM without having to spend the money on a professional card, if you can still get hold of one that is. Performance wise it sits between a 1080 and a 1080ti. Not amazing, but absolutely fine for Vectorworks Open GL use.
I have ended up settling on a setup after messing about with various setups including a second hand 2970wx, which although has been great for Renderworks it's not so good for day to day work in Vectorworks as its single core performance is weak.
A DIY build I am using now and I would recommend for a do it all machine for a start up firm:
AMD 3950x with 16 cores on the X570 platform, (this is best of both high core count for Renderworks and market leading single core performance). Could equally use X470 MB as well.
64gb of 3200mhz C16 Ram (the AMD 3000 multiple chiplet design works best with fast ram upto 3600 for high performance),
Radeon Vii with 16gb of Vram.
Storage Corsair M.2 NVME SSD MP510 2TB.
