cacamote
    11
    Never
Reputation
0 Neutral
Personal Information
  • Occupation
    Architect
  • Location
    Bogota
  1. http://techboard.nemetschek.net/ubb/ultimatebb.php?ubb=get_topic;f=16;t=001541
  2. The link its working fine http://www.azimuthmapper.com/ Carlos
  3. Hi, Holsteinson. I was having the same problem here in Bogot?. I have tried both scprits and the work great. If you have any trouble let me known and I'll guide you though. Carlos
  4. Have you tried this? http://www.azimuthmapper.com/ I'm not sure if this is whta you need. Check it out!
  5. Works like a charm.... Thanks a lot. Carlos
  6. Hi, I'm woundering if there is something like this tool for VW11. I need to list lots of coordinates from a very big drawing and found this tool on VectorDepot: "Coordinate Markers:This tool will place a symbol at a selected point. The symbol will include the X & Y coordinates of the point it is placed at. These coordinates will be based on a user selected origin." Unfortunatly it only works with VW9. Does anybody knows wich tool can I use on VW11 an get similar results? Thanks
  7. Hi, I'm woundering if there is something like this tool for VW11. I need to list lots of coordinates from a very big drawing and found this tool on VectorDepot: "Coordinate Markers:This tool will place a symbol at a selected point. The symbol will include the X & Y coordinates of the point it is placed at. These coordinates will be based on a user selected origin." Unfortunatly it only works with VW9. Does anybody knows wich tool can I use on VW11 an get similar results? Thanks
  8. There is a free plugin from VectorBits (http://www.vectorbits.com/) called Rotate Drawing wich lets you rotate the paper, like rotating the UCS in Acad.
  9. took the words right out of my mouth....
  10. Katie, under OSX the HPDJ100 works fine, but I found out its drivers can cause some kind of conflict wit VW10. After I print the application quits and it damages the file. When I try to open it again I get a message saing that the file is damage and the application quits again. Since VW is the only application that does this I guess there is some problem with it. Do you think updating the firmware on the plotter may fix this problem? I have had the plotter for a few weeks now and I didn't understand why the files I was working on where all damage. Now every time I want to print something I have to do a copy of the file and print the copy because I know it is going to get damage.
  11. I have the same problem when plotting from VW10 under OS9. Try plotting from OSX, it seams to work fine.
