Content Count
7 -
Community Reputation
3 NeutralAbout Sebastian Vidales
Rank
Greenhorn
Personal Information
Occupation
Stage Manager/Tech producer/Sound Engineer
Location
Colombia
Contact Info
Skype
luruaco
Recent Profile Visitors
273 profile views
marioandrescano started following Sebastian Vidales
VW Cloud Publish Not rendering lighting
Sebastian Vidales replied to Matthew Byrne's question in Troubleshooting
Hi @Ben Atwood Thanks for your reply. Actually it happened on just some of them.- 13 replies
- cloud services
- renders
(and 1 more)
Tagged with:
And it keeps on going.....- 13 replies
- cloud services
- renders
(and 1 more)
Tagged with:
I ran into the same issue, when trying to render through cloud publishing using VW cloud services option, none of the lights rendered. While troubleshooting I tried cloud publishing a single sheet layer through Dropbox Integration, and it worked! Only in a couple of minutes I had my PDF with lights rendered. Then I tried for a second time, and the status circle appeared to be complete but the syncing to dropbox took more than 8 hours. Im currently trying it again and same issue happens, the cloud services app shoes the complete circle on the status column and the on the bottom left corner it shows the syncing is in process.- 13 replies
- cloud services
- renders
(and 1 more)
Tagged with:
javier espitia ortiz started following Sebastian Vidales
Franco-Müller started following Sebastian Vidales
EDGAR GRANADOS started following Sebastian Vidales
Deivid started following Sebastian Vidales
Lanigo started following Sebastian Vidales
Oscar Gracia started following Sebastian Vidales
tostalight started following Sebastian Vidales
adoarias started following Sebastian Vidales
Thanks! @JuanP I had another file open at the same time, which didn't have this issue, once I closed the second file, everything went back to normal.
Has anyone had this issue? Most of the options in the menus are grayed out!
