max123456
Content Count
8 -
Community Reputation
0 NeutralAbout max123456
Rank
Greenhorn
Personal Information
Location
Germany
Recent Profile Visitors
Hallo Pat, I have assembled some data sheets for my records in the data manager. Now I want to apply them to ALL symbols in my document. Regardless of the symbol name or the class in which the symbol is located. Currently I only know how to assign the datasheets to a certain class or symbol. Thanks for help Max
Hello together, Is it possible to create a Data Sheet/Data Set, which applies to all symbols regardless of class or system definition? Thanks Max
Hello, is there a vectorscript procedur/function to connect a object with the (ODBC) database? I only find the function VS:DBShowObjConnDlg, but i like to create complete the dialog via script How can I do this? Thanks for your support Max
Hello I am trying to import connections to an MySQL/ODBC database The export of the connection works fine. But when i try to import the just exported file again i get the following error message: Unable to access database. ODBC Log: [1064] Driver error: 37000 [MySQL][ODBC 8.0(w) Driver][mysqld-8.0.20]You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '[000_u_fixture_configuration]' at line 1 Thanks in advance Max VWX 2020 SP3.1 Build 537701 (64bit) DBConnections.xml
Hello Three years later, someone knows if something has changed in the meantime? Ispossible to encrypt or lock a marionette object so it can't be broken by other users? Thanks Max
Is it posible to change the connectors on all devices of the same type by Marionette?
Hello, If I have several devices of the same model in one drawing, I would like if I change one device (e.g. color, image, ...) that the change is applied to all devices and I do not have to make the change for each device individually Is there a way to update existing devices in the Resource Manager so I don't have to edit each one individually? Thanks for assistance Max
Hi In the SignalTypes Dokument, what does Prefix stand for?
