Uli
172 -
Everything posted by Uli
If I rotate the plan and after drawing something get back to Top/Plan view the underlying imported image is no more congruent with the drawing on top. Does anybody had the same problem or a solution? When I reimport the image it is in the right place again.
Class structure: More than 2 subclasses
Uli replied to Christiaan's question in Wishlist - Feature and Content Requests
I was looking for a better organisation and found this discussion. So do you find a solution to organize the list in the navigation palette? I also find that in a big project the alphabetical ungrouped order is not very helpfull. -
Is it possible to view the content of the undo steps because in some cases I would like to see what I want to undo before I do it?
Hi, how do you update a plant symbol when you made some corrections in the plant definition. I did not get an update in the drawing at once and I always have to take the corrected plant from the recource browser again so that I can see the changes I made in the plant definition or in the plant tag. I hope you can understand what I am trying to do, I want to make changes in the plant definition and see it at one in all plants of the same definition in the drawing. Regards Uli
Hi mike thank you very much, that is what I was looking for. Uli
Does anybody know a simple way to draw a grid or send the existing grid to the front of the drawing? Uli
Hi, do you know if the plugin for VW 2009 is running in 2010. I bought the plugin when it came out some years ago and the hotline of cinema told me that they don't sell it seperatly anymore. So do you know if the VW 2009 plugin update is free and if it works with VW 2010 and Cinema 4d R11. Regards Uli
Hi, does anybody know when there will be a new Vectorworks 2010 Exchange Plugin f?r CINEMA 4D R11, or is the Vectorworks 2009 Exchange Plugin f?r CINEMA 4D R11 working in VW 2010. Regards Uli
Hi Carl, the problem is, that VW can not import georeferenced files without a world file (lat,long). So if you edit that file, regardless the format, in PS, it will loose the placement in geography. Anyway I tried to open a gif file in VW, with a transparent background in PS, but the background was black in VW. I think I have to experiment a little bit with the settings and the format to find a way. Thanks again for every help. Uli
Hi Carl, thank you again for your help, but I think I don't have these options, because I do not have Renderworks. So maybe I have to search for a different way to get a solution. Regards Uli
Hi Carl, I am working with VW 2008 Landmark, no Renderworks.
Hi Carl, thank you, I think that is what I am looking for, but I can?t find the commands you posted. I only found the right click edit menu but there I can't find: Select image as color alo I can't find mask transperency and the manual, in that case, is no big help for me. Maybe I overlooked something or I don't understand the procedure. Up to now I only know the procedure from other programs: select pixel colour -> set transparent. Thanks Uli
Hi monkey, thank you very much for the reply, but as I wrote, I have a georeferenced file and if you save that in Photoshop you loose the settings. So if anybody knows a way inside VW, I would be happy. I think that must be a standard tool for any better CAD program. Uli
Hi, can anybody show me a simple way to make the background colour of an image transparent. I can't find a solution or I missed it. I have a white background of an imported georeferenced file and I just search a box to set i.e. pixel with colour 1 to be transparent or something like that. Uli
Thank you Doug L I will try that out.
Hi, is it also possible to collect plants from different search inputs. I.e. I first search the database for white daylilys, second I want to add white phlox to that list. Is that possible to save that plantlist out of different search enquiries to one plant list VW so that I have my special list for a special project and not ten different plantlists of all the different enquiries? I hope my question is understandable. Regards Uli
I am using VW Landmark 2008 and if I want to import georeferenced aerial image they come in high resolution and large size. So for me these limits are very serious if VW wants to work in the GIS field.
Hi Ray Libby, I found your hint with the 4000 pixels high and wide limit in the search box of the forum. Do you know if this has changed since VW 2008? I did not find this very imported message in any manual. Regards Uli
Hi, I think I found what I was searching for. File -> Explore PlantList. Thanks for the support. Regards Uli
Hi, what I understand up to now, is that VW creates a new Plant database and new Plant Lists inside the User Folder, so I better leave the VW Installation Folder with the defaults alone. Can someone show me a simple way to select different databases which I have made from plant data i.E. Uli.USR out of a VW drawing file, or do I always have to rename the datatbase to VW Plants.USR, before I can use it. I just want to open different Plant databases out of the drawing document and make Plantlists from selected features, because I do not want one big Plant database. Regards Uli Maybe I understand the process sometime.
Hi, thanks again. Up to now, for me it is difficult to understand what VW is doing with databases and plant lists and where it is saving and what it is saving. I.e. I saved a new Plant List in a directory and than Chose VW Plants and lead VW to that directory but what I get is the old list. Up to now I do not understand the systematics of VW data handling of Plant database and Plant list. I read the manual, knowledgebase but it is only a sort of trial and error for me. Regards Uli
Hi, thanks to everybody. After viewing two movies of the knowledgebase I realised that I have to update my Plant database. I find the process a little uncomfortable. Maybe that will be more simple in VW 2010. What I realised, it is nearly impossible to work with one big database, thats right Ian. Thank you for the hint to make some lean Plantlist, Ozzie. Regards Uli
Hi, I imported a xls plantlist to the plant database. I can see the plants there. But if I want to place the plants with the option get plant data there are only some listed in the categories. I don't know why only some plants from the Plant database are listed with the place plant tool inside the document. Regards Uli VW 2008 Landmark SP3 XP Pro SP3
Thank you for the input I will keep my hands off these classes.
