Uli
172 -
Everything posted by Uli
Does anybody had luck exporting a shapefile. Import works fine but not the export. If I export as dwg file the geometry is correct but I can't export the database of the shapefile of course. I tried any settings of import and export even different documents scales, different units and different prj files. It seems to be a problem with the decimal points. Thanks for any advice. VW 2013 Landmark Win 7 64 bit
Edit: "When the Preview pane is enabled" in Explorer I get a quite good preview. Sometimes it's good to have a closer look inside the manual :-) Sorry for this post, maybe it helps s.o. else. "Is it possible to prieview / browse VW files (e.g. bigger view than the extra large thumbnail, provided by the windows explorer) before opening? The registry tweaking options I found don't work in Windows 7 64 bit and in Adobe Bridge I don't get any preview. Any suggestions for third party preview plugins, working with VW files, are appreciated." VW 2013 Landmark Win 7 64 bit
Is there a command "Send object behind a referenced object?" E.g. I select an object and that is send behind the object which I will select next. VW Landmark 2013 Win7 - 64bit
If s.o. is interested I got a solution when I cut out the selction in PS and paste the selection into VW. The artefacts are gone. Maybe there is a different handling of the edge selection, import vs copy-paste.
How can I get rid of white artefacts/pixels around the edge of an non rectangular image content? 1. I made an accurate selection along the edges of an image content (mask) which I want to import into VW and deleted the content outside of the selection in PS. 2. When I import the image into VW 2013 I get white artefacts around the image edges although I set solid colour to none. Thanks for any advice
Hello Dave, thank you for your clear answer. So I forget about the rumours.
My latest information from 2 CAD retailers is completely different according to the exchange of data between VW Landmark 2013 and Cinema 14. 1. "You need Renderworks to exchange data." 2. "From VW 2013 you don't need Renderworks." Thanks for any real help with real experience. VW Landmark 2010 Win7 64 bit
Thank you, I will try the workaround.
Thank you for your help. The problem is that it is not always sure that I have all selected objects on the same class/layer. Maybe it is not too difficult to program the option show only selected. Regards Uli
Is it possible to show quickly, only the selcted objects which I get with the custom selection tool? Like classes and layers show active only? VW Landmark 2010
Hi JShardlow, I use VW 2010 Landmark and only found the possibility to import a georeferenced image, but not to georeference it in VW. Maybe that changed in 2012 or I missed sth.
I thought you have also the option to print to pdf. "Instead of printing straight from VW we export to PDF". I was not so lucky with the export option, so I experimented with the print pdf option, there you can find the rasterize option. But even that option sometimes has problems with transperency on my system. Hope that helps I don't know maybe it is also a Landmark feature and not inside the Fundamental Version.
Hi Steph, I have problems with transparency in pdf sometimes, I get white rectangles around a transparent symbol. The best results I get when I print a pdf with the option "Rasterize print output" VW 2010 Landmark
Hi Tamsin, thank you, I think I have to look into the case "edit the worksheet criteria so that it only looks at that specific class" tomorow morning :-). I think I have to take a closer look into the handling of worksheets.
Hi Pat, thanks for your help. It seems to me, that all the Plants of the Landscape Areas inside the project are mixed into one worksheet. But maybe I missed something. So is it also possible to export the plants of only one Landscape Area.
Hi, is it possible to export all the Landscape Area Plants with their information to a txt file or any other format? Thanks for any help. Up to now I only found the possibility to ungroup the Landscape Area Plant list. VW 2010 Landmark Win 7 64 bit
Thank you bcd. I think I have to take a closer look at the advantages of world or page units with hatches.
I am not able to change the hatch according to the different scale I set in the viewport, different from the scale in the design layer. The advanced setting of the viewport do not have any effect on the hatch. The hatch stays the same, if I draw in 1:1000 and set the viewport to 1 : 100, so the hatch becomes very large. Hope you understand. Thanks for any help I think I just missed something simple. Edited. Up to now I only found the workaround to make a smaller hatch and apply it, but that can not be the solution. VW Landmark 2010 Win7 64 bit
Hi mleitner, for me it works only, when I import the image with the tfw associated. Geotiffs are not recognized. The imported image is limited to a certain size ~5.000x5.000 I think. VW 2010 Landmark
When I want to reshape my poly vertices plants, the vertices are mostly far away from my plant symbols. I looked for spacing and other data entries, but that is not the problem. The symbols have different distances to the vertices, but I can't find different data entries. Some vertices are correct directly above the symbol. Is it also possible to set the behavior that imported plants should have. I export them with "Snap to plant center" off and "Random plant rotation" off (unclicked) but they always import trom the resource file with both clicked (on). Any help appreciated. (edited) VW 2010 Landmark Win7 64 bit home premium
It seems to me that this discussion deals with a similar problem. I had also the strange behaviour with the marker and I also deselect everything an then set the marker in the attribute palette to on and off. http://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=153127#Post153127
Maybe I misunderstand you but anyway: If you extend the VW main programm window across both screens and than open two files, use window -> Tile and than resize each drawing window for each monitor now you have two different drawings open on two screens. Toggle with Strg +F6."
If you extend the VW main programm window across both screens and than open two files, tile and resize the drawing windows you have two different drawings open on two screens. Toggle with Strg +F6. Is there a shortcut to close all palettes and reopen them like in Photoshop Illustrater etc? I have not found a possibility to open the same file with different views, VW LM 2010 Windows 7 64 bit
Thanks for your suggestions. Do you have different organasations for 2d and 3d? So you have two different surfaces for 2d and 3d Presentation? How do you keep the track, if you change 2d or 3d surfaces? Or do you work only in 3d with textures and present them also in 2d? Hope its not too confusing :-) VW Landmark 2010 (no Renderworks) Cinema 11 Win 7 64
Thank you Kizza, the problem I see is that I have always more than one geometry and a lot of work. 1. Drawing in 3d, 2. Extract, 3. Convert to 2d polygon, 4. Hatch (or the other way round) So if I draw in 3d geometry and change something, I have to do the same procedure again and I always have more than one geometry for the same thing. Maybe I missed sth.
