Uli
172 -
Everything posted by Uli
With SP 3 it works again. With SP 2 installed I got the message that a newer version of Microsoft Visual C++ 2010 Redistributable Package is already installed. Anyway the problem is solved with Sp 3 Thanks
Since VW 2014 I have no vwx file preview in the windows file explorer. Does anybody have the same problem or a solution? VW 2014 Landmark Win 7 64 bit
I made a complex line with the line type tool. In a certain screen zoom I got the line I wanted with a smooth curve (Complex-line.jpg) when I print it I get only (Complex-line print.jpg). Is it possible to get smooth curves or edges with the complex line tool?
Hi JimW, thanks for your info. I saved the file every time after each geotiff Import. I had the grey rectangle after the Import of a the merged geotiff smaler than 32.000x32.000, so I will look into that Problem again. However I would suggest to take of or strongly expand that limitation if possible, because a lot of people working with georeferenced areal images in regional planning needs more space and you have the exchange with GIS in your product advertising. Best regards Uli
Every time the import, referenced or not, freezes VW 2013 or 2014, after the third file. Up to the third file everything is ok. It seems that the file size in MB does not matter because I used Georaster in tiff, png or jpg. The file size of the jpg file is very small but the dimension of the aerial image is in all three versions the same 10000x10000 24 bit. I know that there was a limitation in former Versions of VW but I thought I can use it now for cartographic work in townplanning projects. If there is a limitation it would be nice to now it, because GIS programs import nearly as many geotiffs as you like. Sorry for my English. Edit: I made one Raster out of the four raster files as geotiff and geojpg. The import worked fine for both files although the tif file was ten times bigger than the jpg file but I ended up with a greyed rectangle with no image. So I thing that there must be a limit in the dimensions when you want to import georeferenced images. Edit: Hi monkey, it seems to be as you mentioned before "VW used to have a 15000 x 15000 pixel limit as well but not sure if it is the same in 14". I cut the image after mergeing the files to 14474x14474 and it works although the file size is nearly 600 MB. It would be very nice if known limitations were published so I can save a lot of work or is it written somewhere?
Thanks for your quick reply. It is a geotiff with a tfw file. It would be fine if I do not have to change the format, because I use these files in different programs as reference files. The import of the fourth file does not come to an end even after some hours. If there is no other possibility I try to convert the geotiff into another format.
Does anybody know if there are restrictions in the image file size that I can import. I have imorted 3 tiff files with 300 GB each but the fourth file VW 2014 does not want to import and VW freezes. I tried this with differnt files of the same size. I had problems in earlier Versions of VW with the limit of pixels if the image was very large. Or can it be a RAM problem? Thanks for any help VW 2014 Landmark Windows 7 Pro 64 bit 16 GB Ram
I found the solution. Although I am administrator, I have to set VW 2014 to start in adminstrator mode under the compatibility tab of the program properties. Some programs need that in Win7pro. Thanks for all your replies. Regards Uli
Partition C 344GB
70775ce76a96ac832def01cc41b29604 FundamentalsLibraries-2014-202999 9c022b8d5208fbb6223c03fd9b068345 Landmark-LandscapeSiteObjects-2014-202999 09dea893b3ce3a314a1bfdae05572ed1 Landmark-XfrogPlants-2dPhotorealistic-2014-202999 50671a0db1161ca721d143b85cde0ebd Landmark-XfrogPlants-3dPhotorealistic-2014-202999 a633299090a82220318dab6daccabf5c Landmark-XfrogPlants-ArtisticGrayscaleSilhouette-2014-202999
I understand IE 10 Maybe I try Firefox and download the whole package PS If I go into the details tab of the files I get the same size as you specify on the content download page.
I downloaded them all from the link download content in VW 2014 and did not get any error message. In nearly 100% of my downloads I do not have any problems with file size or anything else. VW 2014 Landmark Win 7pro 64 Intel Core i5 2500K 16 GB RAM 2 TB disk
Thanks for the reply FundamentalsLibraries-2014-202999.vpkg no install (161010) Landmark-LandscapeSiteObjects-2014-202999.vpkg 10% green bar no install (275840) Landmark-XfrogPlants-2dPhotorealistic-2014-202999.vpkg no install (608300) Landmark-XfrogPlants-3dPhotorealistic-2014-202999.vpkg no install (1836950) Landmark-XfrogPlants-ArtisticGrayscaleSilhouette-2014-202999.vpkg no install (492670) Regards Uli
Does anybody have also problems to install the Vectorworks library content? I did anything as described in the Download Instructions but Vectorworks is not displaying any progress in the lower right bar even after hours. Win7 pro 64 bit
SP4 no change Polyline in Corner Vertex mode with connect combine for me useless. Even the Single object connect mode is not working, works with lines.
SP3 no change, bugreport twice. Works perfect in VW 2010
SP2 for me no change :-(
Is it possible to get a list/preview (pull down e.g.) of existing field values so I can select one value for the search?
In my case the numerics seems to be right, but not the decimal point. Either there were three numerics to much or 3 numerics too little. Any settings in projection made it worse or did not have any effect. In one case the reimport of its own export into VW was slightly incorrect. In other cases it was a problem with comma and point used as decimal seperator but editing the prj file had also no effects. Maybe I find any solution by gambling :-)
Thanks for your help, I submitted the problem as a bug report. First I'm always thinking I can't see the forest for the trees.
I have done different attempts, but the polylines, drawn in corner vertex mode are failing in any case. If I convert them to polygons no problem. All other geometry shown in the attached file are working. Thanks for your help.
No connect / combine tool is working with Polylines. 1. Open blank document 2. Draw normal line, everthing ok. 3. Draw polylines (open) not working. 4. Class none, Design layer, Plane layer If I draw polygons (open) in vertex mode I have no problems. So line ok, polygon ok, polyline no
Thank you mike, I was also thinking about that, because I had that problem in VW 2010 sometimes. But here it is different. I open a blank document, draw two lines and combine them, no problem. I draw two polylines and can't combine them and get the red messsage, bottom right Connect/Combine failed. If you have no problem in VW 2013 Win 7 I have to look further.
Does anybody has problems with the Combining and Connecting of Polylines? In VW Landmark 2010 I had no problems, in VW 2013 I can't combine or connect Polylines, I get the message Combine/Connect failed and I don't get the dialogbox as described in the manual: "In this situation, the Connect/Combine Options dialog box opens." Maybe I missed a setting, I'm coming from VW 2010 Landmark. VW 2013 Landmark Win 7 64 bit
