B-A-R
    2
    Never
Reputation
0 Neutral
Personal Information
  • Occupation
    3D producer
  • Homepage
    www.archatelier.nl
  • Location
    Netherlands
  1. quote: There's no such thing as scale in ANY 3d animation solution (Maya - XSI - LW - Max - C4D - Houdini - ...). The future version of the VW-C4D plugin should give you, amongst other things, the option to rescale the model automatically on import. Currently the best solution is, in VectorWorks, to switch to centimeters before exporting. That way objects made in C4D will at least have the same "scale" as the objects in VW. Hey Bara,.. You do not need to set the units to cm.... just make sure that Cinema uses the same basic units..(general settings) and make sure that your import setting has a scale factor of 1 ... The scale will always be 1:1....
  2. To go back to the top of this thread,.. Is there a viewer available that can read VW 8 files ?? Or are we expected to upgrade VW 8 to VW 9 or even 10 ?
