bgoff
Vectorworks, Inc Employee
    284
Everything posted by bgoff
  1. @hollister design Studio yep Eric is correct. De-Select the check box and the dialog will not come back. With the check selected every time you change a value of a plant it will change the database. This is not necessary and often leads to inappropriate data. Leave it unchecked and continue with design.
  2. Here is a video explaining zoom_0.mp4
  3. do not relocate the origin
  4. Give me a min and I will post a quick video about this. Still drinking my morning coffee! 😀
  5. The initial image you see is for site reference and is only temporary. This is why it disappears. You are still Georeferenced you just need to use the Geo Image tool to draw a rectangle around your area (make it a decent size) and that image will be better quality and stationary for your site.
  6. you most likely used WGS84 as a coordinate system this can skew the image due to regional location. It would be better to use a specific local coordinate system such as in the US (state)NAD 83 HARN. Just find your local system and change to that.
  7. In the case that @Rossford is refering to a hole like you are suggesting will work also but in this case it is faster to duplicate and crop the second model and lay over the top. But yes this is also a great solution.
  8. Try copying the new poly line to your clip board, then after you delete the original crop, paste in the new crop.
  9. This is a GOBO for Spotlight lighting design not a fire as you are thinking.
  10. Give it a fill in the attributes palette.
  11. Just change the pricing in the worksheet you are using.
  12. Right click and edit or double click. The worksheet on both.
  13. You can update directly in the worksheet.
  14. not sure what you are doing but it always works fine for me. Use the second mode in the flyover tool and set the rotation axis to your site model with one click and then rotate. then next time you need to rotate use shift-C and you will be back to that point. You could also set a saved view for the rotation and zoom that you like and use that.
  15. yes it could. either will work.
  16. could you load a sample file and I could take a look. Just 2-3 plants in a blank file would suffice.
  17. Just use the hardscape and set a border. set the border height to be what you want and done. As for the plant beds you could use a modifier or sets of modifiers to create your grade or berm. This will help you control your site appropriately.
  18. send me the file and ill see and post here what the issues are.
  19. Looks like you have an object at zero. Depends on what that object is and how it was placed. let me know what that object is.
  20. Use "Change Plant Grouping" in the Landmark Menu
  21. @michaelk I guess yes I do it every day! I also prepare food in ice counters (you know how the frozen tundra works!!! ) 🙂 @hollister design Studio figured you would like that!
  22. Also I am not a fan of using floors for countertops. Why??? Because do you like preparing food on the floor?? 🙂
  23. @hollister design Studio use standard 2D poly to shape the countertop. use any shape to create the hole or holes. Extrude shape. This allows for easy manipulation of original geometry and addition or subtraction of any shape to the countertop. As a note I then create auto hybrid. and create a symbol. Just my workflow.
  24. If you place it on a site model it will be fine.
