chogb
  • Content Count
    4
    Never
Community Reputation
0 Neutral
About chogb
  • Rank
    Greenhorn
Personal Information
  • Occupation
    architect
  • Homepage
    www.rundellassociates.com
  • Location
    london
  1. good thinking. thank you very much! chog.
  2. hi just upgraded from 9.5 - 11.5. have been looking into the batch convert tool. so far so good. have run some tests and it converts files fine and workgroup references are maintained. i am about to try and convert a project folder with 3-400 vw files. is there a way to convert the files 'in place' - ie the converter overwrites the original file rather than puts them into a new directory. our file structure is such that certain folders contain both VW files and other types of file. the converter recreates the directory structure in the destination folder, but it doesnot copy non VW files. so i will be left with a copy of the directory structure containing newly converted VW files, but without all the other work files!! as it stands i will then have to move the VW files/folders back into place overwriting the old ones. i would rather backup the project folder and then convert in place if this is possible. any suggestions? thanks, Chog.
  3. hi, am in the process of setting up work group referencing in our office. when archiving drawing sets, i am planning to remove all references from drawings, but keep the referenced layers within the drawing. is it possible to set this up as a batch command to do all ref'd layers in a series of drawings? if so, how? is it time to get out the vectorScript manual ..... thanks chog.
  4. hi, am in the process of setting up work group referencing in our office. when archiving drawing sets, i am planning to remove all references from drawings, but keep the referenced layers within the drawing. is it possible to set this up as a batch command to do all ref'd layers in a series of drawings? if so, how? is it time to get out the vectorScript manual ..... thanks chog.
