quote:
Originally posted by Brian O:
Six:
Are you using the Scale Objects tool, under the Tool Menu, selecting Scale Text and Entire Drawing? This should allow you to scale all objects in a percentile fashion.
I.e., if you need to reduce the size of your plan by 15%, scale your objects to .85000 of the current size. Remember, it is of the current size, not the original size. So if you reduce by .5 the first time, .80 scale would reduce the size of the drawing an additional 20% rather than increasing it to 80% of the original drawing.
Brian O
Thank you for your reply, actually I needed a quick answer and I still have tech support by phone so I figured I would give that a shot too since I didn't know if anyone would actually get back to me (I've never used a bulletin board before) The problem was that during the import (the file was a .dxf import) some things didn't show up but still existed. Phone support had me do a select all then a fit to screen and I found that the object was aprox. 800' wide when it was supposed to be 60' wide this threw it clear outside the layer scale and Vectorworks would not let it scale. Anyhow thank you for your response apparently these things do work!
