Hi guys,
I am trying to trace over this plan using bitmap (this is actually my first time doing this) I need to red-draw the plan at scale 1:50 which is now to scale.
I have uploaded the PDF and re-scaled to size. So far so good. Now I tried to go to Modify --> Trace Bitmap and this pop up comes up "A Bitmap object must be selected".
Can you please help why I am doing wrong?
Thank you for your help.
Hi guys,
I am a little stuck here as I am trying to draw a plan which is roughly over 20000mm in width and it won't fit on my VW sheet (see screenshot). I already have that plan at a scale of 1:100 on a large printed paper which I need to re-draw at a scale of 1:50 and then should be be printed out on a A2 sheet. Can you please advise?
The size of the plan does not seem to fit as the width is only 4850mm (?)
Thanks in advance for your help.
Hello,
I am drawing a one-point perspective drawing and need to render the floor - see picture. If I use the image from attribute (wood) the default direction of the woodboard will be vertical but I would like it to be horizontal. How can I do this? If I select the image and chose rotate this will rotate the whole object not the actual image of the wooden floor. Same goes if I want to scale the object if I want the floor to appear bigger in foreground and smaller in background. Even If I flip horizontally but nothing doing...Can anyone advise please ?
No this is not a scale model. @@bcd - thanks for the message though. I have the measurements for height, width and depth but this is it. It sounds like NURBS and Lofts and converting to Sub-D might be the best approach for an elevation drawing. In fact I wanted to draw it in 2D in elevation first and then use an isometric view with a 45 degree angle afterwards.
Thank you @kevin@Kevin Allen, I'll give it a try and thanks also @@Benson Shaw for the detailed explanation, I quite like the way you do it. That chair is not the most comfy I would say but it is all about the design!
Hi, can someone help me to design a spiral chair in elevation? I can't get my head drawing the attached chair. I have used NURBS curve but not sure if this the right approach. Any advice would be much appreciated. Thank you.
I have drawn this Y-shape floor lamp and the two curved lines going up are NURBS curves, the other lines are polygon lines.
I am trying to have the floor lamp covering the corner of the window as if it was sent to front but it does not do anything. I thought of using attribute to color fill white but this does not work either. In fact I don't know how to color fill the base as they are NURBS curves. Can you please advise?
And I need to have this Y shape lamp in front hence covering part of window so would much appreciate your help as I am surely doing something wrong! Thank you for your help.
