ericjms
    23
Posts posted by ericjms
  1. I've been attempting to build an instrument with a fixture head that moves when I set the focus point. The references I've found online are great for building the rest of the fixture / instrument but haven't been able to create a pivoting point with the 3D loci.
    I've found a reference to this on Youtube but it's the 2015  or older versions and I can't seem to find the "custom yoke" option.
    I'll attempt to dig a little further but I thought I would put it out on this to see if anyone has any tips.
    Regards,
    References: 2015
    Reference 2010:
  2. Our company has a project that has a horizontal seam option be placed in the drape. We are making an attempt to have minimal seams in the shootable area by having the seam out of the frame.
    Key Notes:
    • Lowering the Green screen to accommodate the seam isn't an option.
    • "Drape over the Cyc" wall was attempted but it wasn't quite right
    • By using a combination of Nurbs curves & loft surface [Birail mode] I was able to rough in something that I would like the "soft goods" tool to do but I couldn't figure out how to put a "subtle" line in the surface
    While the creation of the drape technically is possible I've noticed 2 isssues with attempting to render:
    1. The "soft Goods" tool does not have an option to create a horizontal seam
    2. The "Soft Goods" tool does not allow for independent top and bottom angle adjustments.
    • When adjusting the vertex points either top or bottom it adjusts the entire element ; This does not work when attempting to Drape along on a angle.
    Anyone have something to answer this?
  3. Hi Hivemind,
    I've been working on a project in VW 21 and I've noticed that 3D symbols often "phase out" *example attached. I've created a work around in which you have "edit" the 3D symbol then "ungroup" and  change something about it to refresh it. In some cases I had to copy existing parts of the object then paste them in the same spot for them to show up. Is there a way to "refresh" a 3D symbol?
    Thanks,
    Eric
    *please ignore the blue bar
  4. Hey Online!
    I was wondering why I was having issues with lining up a simple stick of truss to a generated floor when you change the hanging angle by 90 degrees?
    The center point of the truss seems to be the starting point of the drawn truss.
    In one pic from the 2D planview you can see it clearly not placed on the floor. In the other in the 3D view you see it lined up.
    Is there a way of having the rotating truss to take the centerpoint of the truss while vertical instead of the starting point?
  5. I'm learning from the "Creating a basic lighting plot" PDF and it mentions the function "Convert to light position".  ( Modify>convert> ?)  It doesn't seem to exist. I'm going to go ahead and assume that I believe is no longer relevant with the recent software updates?
  6. Has anyone else had issues with trying to assign  "Alt + Shift + 'letter' " to a shortcut?
    For example:
    I want to assign "Alt+shift+x" to the function of "Hanging position".
    If I assign this combination in the Workspace editor it will only trigger as if you programmed it as "Alt + X" which will tab you into the "Text" menu.
    Same with "Alt+shift+V" it will only act as "Alt + V" which is the View menu.
    I'm creating functions this complex to work with the 3D connexion radial menus.
    Thoughts?
  7. Hi Vectorworks hivemind,
    I'm attempting to follow the Creating Surface Array video verbatim (making sure that I'm using 2D locus with 2D objects and 3D locus points with 3D objects this time) and I'm running into the "illegal extrude or sweep issue". I've created a dome 3D object and an extruded 2D object = no go. I've created a 2D sweep object for a surface with an extruded 2D object = no go.
    It mentions that solids, sweeps, extrudes, meshes 3D polys and 2D objects are all considered viable array objects but I keep getting an error?
  8. I'm having trouble adding a locus point to the rotation axis of a 2D object. I've followed the video instructions to "add a locus point" and have both the 2D object created with both nurbs curves and simple shapes and the the point and I keep getting:
    "There were objects selected that were illegal in extrudes and sweeps. They have been deselected" And it deselects the locus point?
    Something I'm missing?
