436 -
Posts posted by Ethan R.
Hi Gerard ..
Isn't this the opposite of what Symbols are meant to do ???
ugh
- 1
Thanks Pat !
I'll check that out!
I"ve missed that since 2008! Go figureThanks
Ethan
Truthfully "workshets" are such a great concept .. but the usability is so piss poor that - IMO - you really have to invest a lot of time to get them right.
To this day, there is not an easy way to know what parameters are called.
Calling parameters inside the sheet is a hit or miss whack-a-mole
I usually have to create a report with ALL parameters and then sift through to find the ones I need.
Then I have to create a new report (or delete a lot of columns) to get the report correct.
Also - if you rename - i think it was layer names? - you have to go back into the report and re-call them?
This entire system - like much else - needs a re-write.
I'll say it again ... NO NEW FEATURES --- FIX THE ONES WE HAVE !!!
5 hours ago, Kevin McAllister said:
I might have a potential solution for this. Select all of the stacked viewports with the OpenGL background and click on the Lighting Options button in the OIP. Under ambient info turn up the brightness to 100%. In my test file it washes out all of the shadows. You wouldn't normally want this but because you're only using the OpenGL portion as fill it doesn't really matter.
Kevin
This is the technique we use to get hidden line as well !
Kevin beat me to it
- 3
Thanks Jim - yes that was it - the filelname was long and convoluted !
appreciate it.
I'm getting this error on DWG export?
anyone find a solve?
Copy that - explains a lot.
Thanks Rob - Found them!
Its bit odd as some are in the Service Select folders and others in the libraries folders.
Question - once downloaded - is there a way to integrate them into the OIP Pallets?
ie. if I download the new Espon Projectors or Meyer Speakers - can I use the Spotlight tools to insert them into my drawings?
Thank you
copy - think it is an error
Hi Jim,
That is what I thought - but some of the libraries (like the ETC Power Library or SquareLED) were not there - I had to go to the Service Select Portal and download them.
Is this correct - or is something not connecting on my side?
Thanks
Question - aren't the subscription libraires supposed to be available via the Resource browser>VectorWorks Libraries ?
Do you actually have to download them?
If I have a large 3D Model of a venue in my drawing.
Are you saying it Is better to ex-ref the 3D Model?
Lower file size and faster performance?
E
Question on webview.
When I create the webview via the cloud services - it generates a sharable link.
Is there a way to get that link anytime afterwards? Or is this the one and only opportunity?
E
-- Update --
I realize that as I continue to work on my file and navigate around- the view-port is obviously knocked out of the correct rotation.
So I have to go back to a "Saved View" Prior to exporting each time?
Is that the workaround? To confirm that I'm always in the correct orientation for my design layer / sheet layer viewports to pick up the correct view?
(Sorry - tired , I'm not sure if that made any sense!"
Thank you - this method is a great workaround.
I agree - simply turning the clip cube into a view-port would cut out many of these steps.
I guess it would require 'instances' of clip cube - similar to view-port cameras?
Seems a great tool though
Thanks M_
Trying these out.
I'd like to see an 'official' version for 2018.
It seems this should be something updated since 2014?
Thank you
Ethan
- 1
Man- it really feels as if .VWX is being left behind on many fronts
Thank you
Hello all
Is there a 'definitive' recommended settings for nVidia GeForce Graphics Cards?
I'm back to the PC and have not found any good answer.
I"m having a decent amount of performance issues that I don't believe I should be having; as my new PC is epically superior to my 2012 MBP - yet my performance has not significantly improved; and in many cases has regressed.
Help please!
Ethan
Seems this should be stock somewhere in vwx !
I see that Maxwell works with ArchiCAD and Cinema4D - does it allay with VectorWorks?
What would be the workflow ?
I'm on a Gigabyte Aero15x - decent enough - they are coming out with a new model in the next months that will probably be way better
Current has the 1070 Max-Q
But the new ones will have the new chips and probably fix a keyboard issue that is annoying.
Christmas came early
in General Discussion
Posted
I use the 2 side buttons for layer-up and layer-down
The wheel button as command-O to bring up the layer/class/etc.. properites window
the Top button I have set to various Layer / Class views (Active Only, Gray Others, etc ..)
my middle mouse is still set to pan -- think I'll change to something else
Mabye Orbit
