angelojoseph
23 -
Everything posted by angelojoseph
we went m1 Max 64GB across the board in our office. We've played this game before, and when you project the cost across the projected viability for your work, I would be surprised if you don't land on the same conclusion. It's particularly important now that EVERYthing is integrated to the chip. I projected about 3 good years of usability with the m1 pro (~$75/mo/lifespan), and 5.5years with m1 max ($56/mo/lifespan).
Vectorworks 2022 and 2021 Mac 16" M1 Max
angelojoseph replied to Eric Chase's question in Troubleshooting
Same issue. I have many files in the office that we have all been working on. Everyone upgraded to 16" MBP M1 Max 64GB and VW22. Almost every old file we load crashes or hangs VW indefinitely. Also, when we do get something to load, it converts symbols to shapes, and does not allow us to select them without using the Force Select command. we cannot use the object selection tool to select them or to move them. SUPER annoying. Otherwise I have noticed marked improvements over our i7-based imacs with the radeon r9. (mid-2015) -
any possibility of these files and links being restored? resources for vectorworks are pretty poor, and these threads offered at least a modicum of assistance (when working)
Hey Benso, any chance you could reupload this file? I am curious to the techniques you suggest. Thanks so much!
VW 2018 - "The file save operation failed" when saving to network
angelojoseph replied to sbutler's question in Troubleshooting
This issue is happening on my PC install -
Yes. There are no issues through any other software or accessing and/or editing files in those folders. -
angelojoseph replied to angelojoseph's question in Troubleshooting
can a mod please change the title to reflect 2020? I can't seem to edit it -
angelojoseph posted a question in Troubleshooting
This was posted under the 2018 thread, but I am having the issue on 2020 VW Designer. I have been having this issue now for several weeks. Updated to 2020 and it did not solve the problem. I get "(failure to attempt to write to file)" in a window 4 times in a row. That is, clicking ok only brings the warning up again four times. Then a final message box that says: "An error occurred while saving this file. This file is now corrupt on disk. Try saving this file to a different location. If you close this file before you successfully save it, it will be completely lost" I am the only one with the issue in the office. I have no other issues saving to the sharepoint in other software I can save the file to my hard drive and then drag it to the shared folder with no issues. -
I agree. And I actually think there could be creative ways to make the other functions remain clean. Lumion has some nice symbols that depict complex ideas that are only whit on grey (as tshelton effectively created above - kudos to him). And those marketing videos always grind my gears. SOMEONE understands that creative professionals want this interface took beautiful, unfortunately it's marketing and not the UI/UX team.
I have been having this issue now for several weeks. Updated last week to 2020 and it did not solve the problem. I get "(failure to attempt to write to file)" in a window 4 times in a row. That is, clicking ok only brings the warning up again four times. Then a final message box that says: "An error occurred while saving this file. This file is now corrupt on disk. Try saving this file to a different location. If you close this file before you successfully save it, it will be completely lost" I am the only one with the issue in the office. I have no other issues saving to the sharepoint in other software -
Russ, you've laid it out quite succinctly. One thing of note, as I am currently dealing with this, is that VW is very easy to train on due to it being GUI-based, with intuitive hot keys. Daftsmen are quickly trained due to the core elements being so intuitive. I had a new grad drafting in 2 days, and with the standardized templates and class system being wrapped up in the office this winter, that process should be done in a day. The designer functions are the trickier items, but there is always going to be an on-boarding process due to ACADs need for plug-ins, workarounds, or convoluted processes to achieve a firm's particular style. Anyway, your original post was spot on, as you were here. I don't think it comes off as petty. I think VW must recognize this as well, due to the high visual design of their marketing material and their stylized representation of functions within. I thought it very telling that those were the videos you show to sell the software, as does VW. 😉
There was a post here that seems to have since been deleted from @RussU that I think was interesting regarding the look and being results driven. I totally understand that point of view, but for anyone having an outward-facing design business, perception is very important. Looking the part is important to instilling confidence, as well as reinforcing perceived competence. I'd like to be able to share my screen and not have someone think I'm working on a fresh copy of "DIY Homebuilder Pro" from Home Depot. Appearances are important, no matter how little stock engineers hold in them... sorry, i couldn't resist. 😉
use polyline; freehand; or, draw a circle and 3-sided poly, add the faces, then clip at appropriate space to mirror a heart
If I remember correctly, that has to do with setting visibilities of detail at scale
Completely agree. GUI is becoming really cumbersome, visually. I had this exact thought of embarassment when sharing my screen duringg a conf. meeting. It just looks really unprofessional. The palettes, iconography, and organization could really use an overhaul.
What do you mean by the second question? Do you mean through scripting, or are you just trying to change them?
You can request a dongle-style activation. Just contact your sales rep.
I'm having this issue. Folder working on colleague's Landmark 2020, but after directing to same folder in my 2020 Designer, it is not showing up, even after multiple restart and refresh
Any verdict?
I'm the creative director for a Landscape Architecture firm in Chicago, and we need a few good designers and/or project managers. We are a high-end boutique firm working on highly specialized residential projects, and encourage anyone interested in unique projects with high-touch detailing to message me for more information. We are not looking for anyone looking to work remotely. We are a workshop-style studio, and are highly collaborative, requiring office time. Thanks!
Thanks for sharing! Sorry if I wasn’t clear. I’ve been flying drones and doing photogrammetry for years, as well as developing terrain and contextual models for even longer, so I’m quite familiar with the process. However, I hate ReCap, And there are plenty of great photogrammetry softwares for developing georeferenced dense point clouds (plus textural surface meshes, visual analyses, etc, etc). My questions are related to vectorworks. I love the software and would love if I could process and stitch DPCs in the same software I’m using to do all my other technical design work. TL;DR: I’ve been doing photogrammetry a long time, though in many other software. I’m exploring VWs service and seeing who else is as well. I haven’t found a gourd workflow yet and wonder if anyone has, and I’m generally interested in how Seriously VW is taking this service for technical professionals like myself.
Hey, all I'm new to the forum, though not new to VW. I'm curious who's processing photogrammetry through VW Cloud Services. I've been running some samples and have mixed results. It seems apparent that exif data is not being used, including any telemetry or GPS, as my DPCs come in a weird orientation and placed on the origin (whereas geoTIFFs import relative to it). So here are my questions: -Who's using it, and how useful have you found it in comparison to other services or software? -Is this a Beta service? maybe a proof of concept or showcase piece? -Is the intention for this to become a core component of Cloud Services? (I would love if this were the case, and continually developed to compete with the likes of Pix4D/Zephyr/etc) -Is anyone working on a way to gereference or retain/reintroduce geospatial data to the point cloud? -Any chance of PCS support in the future? I have a million more questions, but I'll let this begin the conversation to see if anyone is even interested. Thanks!
In 2018 you could turn the point cloud into 3d loci, it just wasn't as straight forward. Also, I think it was called something different, like "convert to 3d points" or something. Anyway, to the question at hand, you can decimate the point cloud when generating the 3d loci based on a percentage. though the better thing is to start by cleaning it up and filtering outliers and then decimating. However, ~800,000 points is a pretty light-weight point cloud (which is probably fine for a terrain mesh), so I don't get why it would be lagging on your computer. I have some dense scans of about 7MM points that load pretty darn quickly (relative) and have next to no lag while navigationg on my MS surfacebook 2 i7
