Dendecko
128 -
Posts posted by Dendecko
Will there be any ConnectCad based sessions during Design Summit 2022?
Will there be any Marionette based sessions during the design summit in November?
Yep, that was all that had to happen. When I read the node descriptions it didn't connect in my head. For some reason I thought the hTool meant you told the node which tool to use or modified which one was used. Anyway thank you.
@Marissa Farrell Sure I can do that. My general assumption is I'm doing something silly and just don't realize it but next time it happens I will do that. Thanks!
That was it. ConnectCad workspace is missing that command. Thanks.
I am trying to figure out why I cannot find the import sketchup command. Working in vwx 2022 and have not had this issue in the past but suddenly it is missing.
I look at file/import/ however the option is not present. I have tried a restart and looked at 3 different files. Can anyone advise as to why that is missing?
after a reboot it has not been occuring. If it happens again I will send over the file. It may have been a hardware situation rather than a software situation. I was curious if other have had that happen though.
I did try doing a zoom but it did not fix it at the time I will have to try the double click with pan (will try that next time). The computer I have does have decent specs but wouldn't put it past the graphics card tanking on me.
- 1
Anyone know why ConnectCad devices would be showing like this? suddenly shifted midway through working on a file and I can't quite figure out why but the text of the device is cut in half, shows correctly when it prints and when I click into the device itself but outside of the device it returns to half life.
Yes I am. I have been working in 2021 without issue for a while now. Only since the changeover to 2022 have I started having the first issue.
I've always had random crashes from moving nodes to new locations, even on small files which was why I figured I'd ask if there are things people know about that I may be inadvertently doing.
I've had a sudden moment in 2022 where nodes will simply stop connecting. I cannot make the wire connection pull from the circles. If I click a node it just moves the x, y coordinates instead. When this happens I can copy and paste into a new file and they work again, I can close a wrapper and reopen it and they start working again. But I have to do something to reset the nodes or else they stop working. I have had it happen in 3 files and cannot see any correlation to the tools I'm using, layer or class based causes. Trying to figure out if there is something I'm doing to cause this.
Second, roughly once a day I have a moment where trying to move a connection from between 2 nodes will cause the spinning pinwheel of doom to go off for longer than I'm willing to wait, usually 5+ minutes before I give up, close and pull an autosave up to restore most of my work but I have to redo a little bit each time and I find that quite frustrating. Are there methods of stopping the pinwheel of doom or workflows that stop this from happening?
Thanks for any and all thoughts.
I know the Solid Boolean is for 3d subtraction, but I can't seem to figure out how to clip 2d geometry, I thought it was the planar boolean tool but I can't seem to get it to work, is there a different tool that does that? any tips?
I have not had this happen on my second monitor using vwx 2022 with a professional license. is it just shrinking to a bar or totally disappearing? you can lock it open using the plus sign.
@Dave Donley Renderworks also went black. because of the issues with new files I did a full dump and reloaded the software. Currently has stopped. so far have not been able to replicate it going black but will reply if it happens again. Previously I had manually constructed some architecture and then when I imported a dwg everything went black. the weirdest part was other files also going black and the restart not working but if I copied all, deleted it, and then pasted in place it went back to normal.
- 1
So found 1 solution, which was kind of weird but if every object in the file was copied deleted and then pasted in place then I could see them again. Weird. If anyone has additional thoughts I'm super down to use a method that doesn't require deletion and repasting.
@zoomer Are you saying you have had the same issue? were you able to solve it?
Hello,
I am not sure what's going on. In 2022 all vectorworks 3d geometry has turned black. I have tested multiple files and everything is black and stays black. I was working all morning on a file, went to lunch and came back. After inserting a dwg into one file everything is just black. opened different files and the same thing happened to them so I am suspicious that some setting get adjusted but really don't know how. I have tried restarting but no luck. any help?
This has been brought up before and approached in a couple different ways I'm aware of. One was to reorder based on a list which sometimes works. Or if you are able to output the individual symbols then you can use the forward function which I believe was made by @m.graf
Are there any Vectorworks troubleshooting or learning based discords or live streaming channels?
Question about VWX 2022 Freezing.
Is there a way to make vectorworks stop a process that has caused it to freeze in 2022? I have had 2 situations today where I have performed a simple task such as duplicating text that has caused it to freeze and lose work. I use autosave so not too much work but still these are very simple processes in a relatively small file.
Thanks for any help.
@markdd I did not know that it was that limited. Thanks for the info!
I've recently had an issue where when I render in shaded only some of my lights are rendering as "on". When some stop functioning all new instruments that are inserted also refuse to turn "on". Many of the instruments have been copied and pasted from already working lights and placed in new locations. Is this a known issue or does anyone know what might cause this? I've had it happen in 3 different drawings.
Okay..... Tried the stupid thing.... I restarted vectorworks. worked after I did that.
- 1
Design Summit 2022
in Marionette
Posted
Wonderful, Thanks for all your efforts and time Marissa!
