The Hamma
  • Content Count
    162
Posts posted by The Hamma
  1. Raymond:
    I think you are right.  I guess there is no way to run a script that calls another script and lets it finish then finishes the script that called it. The only other option I suppose is to have three scripts. One to turn off Auto DC, this script, and one script to turn it back on.  It wouldn't be a problem if it was just the confirmation message you get at the end of the script.  The issue is that some of the labels do not display correctly after modifying the number and you have to edit the annotations and move them so they refresh.  And since the issue arises after the script I can't fix them in the script.  I could possibly right a script to refresh the Drawing labels that could be run after this script.
  2. In this instance 1=true and 0=false.  This simple script will turn if off the Automatic Drawing Coordination.
    vs.SetPref(544, 0)
    This one will turn it on.
    vs.SetPref(544, 1)
    If I run the first script prior to running the script mentioned in the previous post I have no issue but if I try to disable it during the script it does not register as being off.
  3. Thanks that was it but for some reason when I turn it off in the script it still acts like it is on.  I checked and it is setting the preference off and then back to the prescript state at the end.
    #script to renumber drawing labels contained within VP annotations in order picked by mouse.
    autocoord = vs.GetPref(544)
    vs.SetPref(544, 0)
    hVP = []
    numberStr = vs.StrDialog('Enter and INTEGER to start numbering:','1')
    vs.Message('Click in empty space to end Label Numbering')
    h = 1
    while h != 0:
    	click = False
    	while not(click):
    		click, pt = vs.MouseDown()
    	h = vs.PickObject(pt)
    	anno = vs.GetVPGroup(h, 2)
    	h1 = vs.FInGroup(anno)
    	objs = [h1]
    	h1 = vs.NextObj(h1)
    	while h1 != vs.Handle(0):
    		if vs.GetObjectVariableString(h1, 1166) == 'Drawing Label':
    			hVP.append(h1)
    		h1 = vs.NextObj(h1)
    for DL in hVP:
    	vs.SetRField(DL,'Drawing Label','Drawing',numberStr)
    	vpNumber = vs.Str2Num(numberStr) # {convert number string to number}
    	numberStr = vs.Num2Str(0, vpNumber + 1) #{increment number then convert number to string}
    vs.SetPref(544, autocoord)
    vs.ClrMessage()
  4. Great Idea.  Now I can isolate it and now I can get it to run in sheet layers or veiwport annotations if they are the active layer.
    This script assigns selected objects to class "1_Exist-(original class)" and set Construction Phase to 'EXISTING TO REMAIN'.
    If a in wall object is selected without selecting the wall the script will only change those in wall objects.
    If a wall is selected it will change the wall and all objects inserted in that wall.
    If New class does not exist objects original class is duplicated to retain class attributes.
    To take full advantage of this script use "Data Visualization" to display the "Construction Phase"
      record objects as desired.
         1. Set "Data Visualization" to modify drawings per "Construction Phase" record
         2. To make a "Construction Phase" invisible set the attributes of that phase to:
               Line settings to Fill "Solid White" and Line weight "0"
    This Python Script may be freely distributed. No warranty provided.
    Use at your own risk.
    Vectorworks bug does not show changes to symbols inserted in wall until either:
       Drawing is saved and reopened.
       Setting in Data Visualization dialog is changed.
       Symbol is removed from wall, can then be reinserted
    David Hamer, 2020
    # Modifications to any objects happen here
    def assign(h):
        CName = vs.GetClass(h)
        CLen = vs.Len(CName)
        CNameE = vs.Copy(CName, 1, 8)  # Grab First 8 letters of handle's class
        CNameD = vs.Copy(CName, 1, 7)  # Grab First 7 letters of handle's class
        if CNameD == '2_Demo-':  # Check if first 7 letters equal '2_Demo-'
            CName = vs.Copy(CName, 8, CLen)  # if true grab root name of class
        # check if the class is new, if so delete new class and duplicate objects class and rename.
        if CNameE == '1_Exist-':
            CNameN = CName
        else:
            CNameN = vs.Concat('1_Exist-', CName)  # If not add '1_Exist-' to name
        ClassCount = vs.ClassNum()  # determine number of classes in drawing
        vs.NameClass(CNameN)  # set the name of the class to be applied to handle if new class will be created
        if ClassCount + 1 == vs.ClassNum():  # check if the class is new and if delete new class and duplicate source
            vs.ReDraw()
            vs.DelClass(CNameN)  # Delete new class
            CHandle = vs.GetObject(CName)  # get handle to source class
            NDCHandle = vs.CreateDuplicateObject(CHandle, vs.GetParent(CHandle))  # duplicate source class
            vs.SetName(NDCHandle, CNameN)  # rename duplicate class to name to be applied to handle
            vs.ResetObject(NDCHandle)
            vs.ResetObject(h)
        vs.SetClass(h, CNameN)  # name handle's class
        vs.SetRecord(h, 'Construction Phase')  # add record to inserted object
        vs.SetRField(h, 'Construction Phase', 'Phase', 'EXISTING TO REMAIN')  # modify record to inserted object
    # Passes Handle to "def assign(h):" of PIO or Symbol selected
    def pio_processing(h):
        global container  # declare global variable to be retained
        if vs.GetObjectVariableInt(vs.GetLayer(h), 154) == activetype:
            assign(h)  # Runs "def assign(h):"
            hParent = vs.GetParent(h)  # Get Parent handle
            itParent = vs.GetTypeN(hParent)  # Get Parent type
            if itParent != []:
                if itParent == 68:  # If Parent type is a wall set container to state PIOinwallwasdetected
                    container = 'PIOinwallwasdetected'
                if itParent == 89:  # If Parent type is a round wall set container to state PIOinwallwasdetected
    # Passes Handle to "def assign(h):" of every object except PIO and Symbols outside walls selected
    def object_processing(h):
    		h1 = vs.FIn3D(h)
    		while h1 != []:
    			if vs.GetObjectVariableInt(vs.GetLayer(h1), 154) == activetype:
    				if vs.GetTypeN(h1) == 15:
    					assign(h1)  # Runs "def assign(h):" on symbol inserted
    				if vs.GetTypeN(h1) == 86:
    					assign(h1)  # Runs "def assign(h):" on PIO inserted
    			h1 = vs.NextObj(h1)
    def sl_processing(h): # Omit's Viewports in Sheet Layers
    	if vs.GetTypeN(h) != 122:
    		assign(h)
    activetype = 1
    container = 'none'  # Declare container var
    ACName = vs.ActiveClass()  # Record name of active class
    if vs.GetObject('Construction Phase') == ():  # Creates "Construction Phase" record if not present
    	vs.NewField('Construction Phase', 'Phase', '<none>', 4, 0)
    if vs.GetObjectVariableInt(vs.ActLayer(), 154) == 2:
    	activetype = 2
    	vs.ForEachObjectInLayer(sl_processing, 2, 0, 0)
    else:
        # Passes Handle to "def pio_processing(h):" of PIO and Symbols selected
        vs.ForEachObject(pio_processing, "((((T=PLUGINOBJECT)|(T=SYMBOL)) & (V) & (SEL=TRUE)))")
        # Passes Handle to "def object_processing(h):" of objects selected except PIO and Symbols outside walls selected
        # Skipped if PIO or Symbol selected was in wall
        if container != 'PIOinwallwasdetected':
            vs.ForEachObject(object_processing, "(((T<>PLUGINOBJECT)&(T<>SYMBOL)&(T<>VIEWPORT) & (V) & (VSEL=TRUE)))")
    vs.NameClass(ACName)  # Return active class
  5. I need some help.  Apparently this script is editing objects that are selected on sheet layers even though the sheet layer is not active.  Does anyone know how to limit the selection to just the viewable and editable layers.  I thought about using ForEachObjectInLayer but it does not work for symbols and PIO in walls.
    David Hamer, 2020
    def assign(h):
            CNameN = CName
        else:
            vs.ReDraw()
            vs.ResetObject(h)
        if itParent != []:
        h1 = vs.FIn3D(h)
        while h1 != []:
            h1 = vs.NextObj(h1)
        vs.ForEachObject(object_processing, "(((T<>PLUGINOBJECT)&(T<>SYMBOL) & (V) & (VSEL=TRUE)))")
  6. Script has been modified to detect if Design Layers or Sheet Layer is active and Isolate modifications to the active layer type.  Also added the ability to modify objects within a Sheet Layer or Sheet Layer VP annotations.  Note that classes will need to be enabled in VP dialog after running script in VP annotations otherwise they may be hidden.  Only works on objects inserted in walls when design layer is active.
    David Hamer, 2020 revision 07-15-2020
    def assign(h):
            CNameN = CName
        else:
            vs.ReDraw()
            vs.ResetObject(h)
            if itParent != []:
    		h1 = vs.FIn3D(h)
    		while h1 != []:
    			h1 = vs.NextObj(h1)
    		assign(h)
    activetype = 1
    	activetype = 2
    else:
  7. """
    This script identifies the name of a texture in the drawing and creates a new class with identified
    texture assigned to the newly created class.
    This is useful so that objects can be textured by assigning them to the appropriate class.
    If the name of the texture and the prefix exceeds 63 characters the class name will be shortened to 63
    characters.  This is a Vectorworks class name limitation.
    David Hamer, 2020
    ClassPrefix ='I-FNSH-' #Newly created classes prefix
    TextureList, NumItems = vs.BuildResourceList(97, 0, '')
    while NumItems != 0:
    	TextureName = vs.GetNameFromResourceList(TextureList, NumItems)
    	TextureClassNameW = vs.Concat(ClassPrefix,TextureName)
    	TextureClassName = vs.Copy(TextureClassNameW, 1, 63)
    	vs.NameClass(TextureClassName)
    	vs.SetClFillFore(TextureClassName,0,0,0)
    	vs.SetClFillBack(TextureClassName,0,0,0)
    	vs.SetClPenFore(TextureClassName,65535,65535,65535)
    	vs.SetClPenBack(TextureClassName,65535,65535,65535)
    	vs.SetClFPat(TextureClassName,1)
    	vs.SetClLSN(TextureClassName,2)
    	vs.SetClLW(TextureClassName,10)
    	vs.EnableCLDropShadow(TextureClassName,False)
    	vs.SetClUseGraphic(TextureClassName,True)
    	TextureIndex = vs.Name2Index(TextureName)
    	vs.SetClTextureC(TextureClassName, TextureIndex)
    	vs.SetClTextureD(TextureClassName, TextureIndex)
    	vs.SetClTextureG(TextureClassName, TextureIndex)
    	vs.SetClTextureL(TextureClassName, TextureIndex)
    	vs.SetClTextureR(TextureClassName, TextureIndex)
    	vs.SetClTextureT(TextureClassName, TextureIndex)
    	vs.SetClUseTexture(TextureClassName, True)
    	NumItems = NumItems -1
  8. Revised 08-13-2020
        See revision note in new comments
    Attached are scripts that I wrote to help with renovation projects.
    These scripts edit the classing and add a construction phase record to every item selected.
    PIO's that are inserted in walls can be selected with out selecting the containing wall and the script will only affect those PIO's selected.  If the wall is selected it will modify the wall and the PIO's that are contained with in that wall.
    SCRIPT                              CLASS MODIFICATION                                   CONSTRUCTION PHASE RECORD
    1 Existing Object              1_Exist- (Prefix)                                                 EXISTING TO REMAIN
    2 Demo Object                  2_Demo- (Prefix)                                               DEMOLISH EXISTING
    3 New Object                    No change or return to original Class            NEW CONSTRUCTION
    4 NIC Object                      No change or return to original Class           NOT IN CONTRACT
    5 Remove Phase Record  No change or return to original Class          REMOVES RECORD FROM SELECTED OBJECTS  (ADDED)
    With the use of the scripts and data visualization you can create viewports that show the construction phases as desired.
    Attached to this post is a demonstration Video, the two files used in that video, and the four scripts.  I added the script to my selected object context menu so when I right click on an object I can access the scripts from there.
    Construction Phase Demo Unmodified Plan.vwx Construction Phase Demo.vwx
    1 Existing Object.vsm 2 Demo Object.vsm 3 New Object.vsm 4 NIC Object.vsm 5 Remove Phase Record.vsm
    • Like 3
  9. Is there an equivalent way to achieve this in vectoworks worksheets?
    I would like to just display the finish material code and not the material in the finish schedule.
    In excel I would create a blank column to the right column C and add this formula =LEFT(C5,FIND("]",C5)+1)
    See attached image
  10. 56 minutes ago, Pat Stanford said:
    And what would you like this option to do?
    The current options in "Draw All Other Objects" are "Normally" and "Grayed".  I would like "Hidden" to be added to those options so that objects not modified by Data Visualization properties would not display in the selected Data Visualization.
    • Like 1
  11. On 12/5/2018 at 11:40 AM, Marissa Farrell said:
    The following script will leave out Drawing Labels if they only have the default records added to them, which is how they are inserted by default. Extra logic would need to be added in order to check if multiple records are attached to the drawing labels.
    Marissa:
    I understand why you collected the handles of the Viewports before processing the actions but I was wondering why you collected the handles of the drawing labels before not deleting them.  Would it be more efficient code to delete objects as you detect them?
  12. Below are the final results:
    Three scripts to assigns selected objects to class "1_Exist-(original class)", "2_Demo-(original class)" , or original class and set Construction Phase Existing, Demo, or New
    This script assigns selected objects to class "1_Exist-(original class)" and set Construction Phase to Existing.
    David Hamer, 2020
    def assign(h):
            CNameN = CName
        else:
            vs.ReDraw()
            vs.ResetObject(h)
        vs.SetRField(h, 'Construction Phase', 'Phase', 'Existing')  # modify record to inserted object
        if itParent != ():
        h1 = vs.FIn3D(h)
        while h1 != ():
            h1 = vs.NextObj(h1)
        vs.ForEachObject(object_processing, "(((T<>PLUGINOBJECT)&(T<>SYMBOL) & (V) & (SEL=TRUE)))")
    This script assigns selected objects to class "2_Demo-(original class)" and set Construction Phase to Demo.
    David Hamer, 2020
    def assign(h):
        if CNameE == '1_Exist-':  # Check if first 8 letters equal '1_Exist-'
            CName = vs.Copy(CName, 9, CLen)  # if true grab root name of class
        if CNameD == '2_Demo-':  # Check if first 7 letters equal '2_Demo-' if so retain name
            CNameN = CName
        else:
            CNameN = vs.Concat('2_Demo-', CName)  # If not add '2_Demo-' to name
            vs.ReDraw()
            vs.ResetObject(h)
        vs.SetClass(h, CNameN);  # name handle's class
        vs.SetRField(h, 'Construction Phase', 'Phase', 'Demo')  # modify record to inserted object
        if itParent != ():
        h1 = vs.FIn3D(h)
        while h1 != ():
            h1 = vs.NextObj(h1)
    This script assigns selected objects to class "(original class)" and set Construction Phase to New
    David Hamer, 2020
    #Modifications to any objects happen here
    def assign(h):
    	CName=vs.GetClass(h)
    	CLen=vs.Len(CName)
    	CNameN = CName
    	CNameE=vs.Copy(CName,1,8) #Grab First 8 letters of handle's class
    	CNameD=vs.Copy(CName,1,7) #Grab First 7 letters of handle's class
    	if CNameD=='2_Demo-': #Check if first 7 letters equal '2_Demo-'
    		CNameN=vs.Copy(CName,8,CLen) # if true grab root name of class
    	if CNameE=='1_Exist-': #Check if first 8 letters equal '1_Exist-'
    		CNameN=vs.Copy(CName,9,CLen) # if true grab root name of class
    	ClassCount = vs.ClassNum() #determine number of classes in drawing
    	vs.NameClass(CNameN) #set the name of the class to be applied to handle if new class will be created
    	if ClassCount+1 == vs.ClassNum(): # check if the class is new and if delete new class and duplicate source
    		vs.ReDraw()
    		vs.DelClass(CNameN) #Delete new class
    		CHandle = vs.GetObject(CName) #get handle to source class
    		NDCHandle = vs.CreateDuplicateObject(CHandle,vs.GetParent(CHandle)) #duplicate source class
    		vs.SetName(NDCHandle,CNameN) #rename duplicate class to name to be applied to handle
    		vs.ResetObject(h)
    	vs.SetClass(h,CNameN) #name handle's class
    	vs.SetRecord(h,'Construction Phase') #add record to inserted object
    	vs.SetRField(h,'Construction Phase','Phase', 'New') #modify record to inserted object
        if itParent != ():
        h1 = vs.FIn3D(h)
        while h1 != ():
            h1 = vs.NextObj(h1)
    DataVisualizationsInfo.vwx
  13.
    13 hours ago, Pat Stanford said:
    You need to change the FSActLayer to a loop that will step through each wall and do the FIn3D on each wall.
    LOL or just change FSActLayer to h.  I didn't even stop to think about that.  I was assuming that FSActLayer was passing the handle from :
    def SetAttribute(h):
    container = 'none' #set global variable
    phase = 'Demo'
    def SetPIOAttribute(h):
    		global container #declare global variable to be retained
    		vs.SetRField(h,'Construction Phase','Phase', phase) #modify record to inserted object
    		itChild = vs.GetTypeN(h) #Get Child type (not necessary)
    		hParent = vs.GetParent(h) #Get Parent handle
    		itParent = vs.GetTypeN(hParent) #Get Parent type
    		#If Parent type is a wall set container to state PIOinwallwasdetected
    		if itParent == 68:
    #Add and change record of wall and PIO or symbols inserted in wall
    	h1 = vs.FIn3D(h)
    	while h1 != ():
    			vs.SetRecord(h1,'Construction Phase')
    			vs.SetRField(h1,'Construction Phase','Phase', phase)
    		h1=vs.NextObj(h1)
    vs.ForEachObject(SetPIOAttribute, "((NOTINDLVP & NOTINREFDLVP & ((PON='Door')|(T=SYMBOL)|(PON='Window')) & (V) & (SEL=TRUE)))")
    #If PIO was selected and wall was not then container var PIOinwallwasdetected is true then script will end if not then wall was selected and script will continue to def SetAttribute
    	vs.ForEachObject(SetAttribute, "((NOTINDLVP & NOTINREFDLVP & (V) & (SEL=TRUE)))")
  14. I thought it was working perfectly but it does if I select one wall at a time.  In that instance it will change the wall and all the PIO objects within but If I select several walls it does not edit all of the PIO objects, it only edits the PIO in the first item selected.
    phase = 'Existing'
    		if itParent == 68:
    #Add and change record of wall and inserted items (only changes wall at this time)
    	h1 = vs.FIn3D(vs.FSActLayer())
    	while h1 != ():
    		h1=vs.NextObj(h1)
  15. Not inserting the symbol in the wall or using PIO seems to be the best course of action.  The symbols visualization works fine if is not nested in a wall.  If it is nested I can remove it and re-nest it and the visualization works fine.   I still think this is a glitch since it just takes some sort of refresh to make it work.  That being said vs.redrawall() does not work (it actually causes every item changed not to refresh).  For the most part I think I can work around it but it a bit aggravating.
  16. 19 hours ago, Pat Stanford said:
    Just to make this more fun, I am going to throw some Vectorscript in here. 😉
    I added your script to mine and it works great but I think I found a Vectorworks bug.
    This is a view of a wall with objects after running the script on the symbol in the wall.  As you can see in the record the phase has been changed to Existing but the appearance still shows as New.
    Now if I change the Object Criteria in the Data Visualization or close and reopen the drawing the symbol in wall will appear correctly.  I have set my graphic settings up and down with no change.  PIO object change fine, I only have this issue with symbols in wall and the issue is not isolated to the script.  If I change the phase manually I have the same issue.
    phase = 'Existing'
    		if itParent == 68:
    	while h1 != ():
    		h1=vs.NextObj(h1)
  17. I made this script to apply a record to items selected.  The goal is the following:
    If object in wall is selected add and change record to the object in the wall only. (works as designed)
    If wall is selected add and change record to the wall and all objects inserted in the wall. (Only changes the wall not the inserted objects)
    container = 'none'
    		vs.SetRField(h,'Construction Phase','Phase','New') #modify record to inserted object
    		itParent = vs.GetTypeN(hParent)#Get Parent type
    		if itParent == 68: #If Parent type is a wall set container to state PIOinwallwasdetected
