Steve McQueen
    6
Everything posted by Steve McQueen
  1. That makes since. I used to have designer than my money downgraded me to just spotlight. I used to have them. Not anymore. And yes, seems silly with simple outlets like DMX and Edison outlets. He’ll even stage pin should be in spotlight.
  2. I have Spotlight, and am drawing out a church and would like the standard arch symbols like quad, duplex, ethernet, DMX, XLR jack/port symbols to add, but I can't seem to find them. Is it only on other versions, or is there a download of these simple symbols, thanks.
  3. So It also does the same with the data jumper chain. You can see in the screenshot that it worked with one run. Anytime I try any other instruments, I get one big arrow that always ends up in the same spot.
  4. I'm having an issue with the Jumper Cable Chain. I select my instruments, then click away to make the chain, and it draws one big cable no where near the lights. I have erased the Position of the instruments, thinking it thought the instruments where on a different batten then they really are. I recently trashed my preferences and ever since then, Error Loading Visions Library shows up at launch. Not sure if that is related. Thanks v2019 SP 2, 2016 MacBook Pro
  5. I had luck trashing my preferences, lags just a tad now, but works.
  6. I am having the same exact issue. Running VW 2019 SP2 on a 2016 MacBook Pro on Mojave.
