Carl Burnett
51 -
Everything posted by Carl Burnett
Ok!! Got it. silly question, how do I de-sellect an object? Thank you
Hi Kevin, Thank you for that. How do I do that? I haven't done anything with vision except use it to visualise VW. I have made a sphere in VW and exported to Vision. I'm trying to do a test run first. Thanks again for your help CB
Hi Rob, I ment, how do I go about putting the genieric glow spheres in to my vision file? CB
Hi Rob, thanks for this. I have only really use Vision as a pre vis for VW, I have added any Vision instruments is that easy to do? Also: is there and way of putting a mirror ball in vision? i'm guessing I would need to make it emit light rather that reflect it. Thanks again for your help. CB
Hello I'm experiencing problems using SGM LB 100 led balls. when I make a string of them (52 ball) it takes forever to do anything with them (move, copy etc) I have tried modifying the symbol to take out everything other than the sphere to retain the lamp properties. I still have the same issue. What am I doing wrong? Is there another way to show a RGB festoon that will work in VW & Vision? thanks for any help CB
Thanks for that. CB
Spoke too soon! the lamp issue is sorted, still have the zoom thing going on. Thanks CB
Thanks Jim, Thats fixed both my issues...until I manage to stumble into another. Yeah, I updated to SP3 and forgot to save prefs. DUH. Thanks CB
When creating a viewport I get this result. Lots of coloured arrows etc. ( the lights are off in the visualisation window. Any ideas how i messed up this time? CB
Hello All, here's a stupid one. When I change view to Sheet layer the plot is zoomed out (its very small) then when I go back to design layer its zoomed all the way in. What am i doing wrong? how can I fix this? Thgank you
Hello I'm experiencing problems using SGM LB 100 led balls. when I make a string of them (52 ball) it takes forever to do anything with them (move, copy etc) I have tried modifying the symbol to take out everything other than the sphere to retain the lamp properties. I still have the same issue. What am I doing wrong? Is there another way to show a RGB festoon that will work in Vision? thanks for any help CB
Hello, I have managed to open multiple view ports by accident, how do I close them again? Thank you. CB
Hi thanks for that. i have 2 symbols that are very similar so, I want to make the outline of one of them a different colour. thanks again CB
Hello, I have used the drum kit symbol from VW library how do I change the colour of the kit? the only kit I could find is red. also: in plan view how do I change the colour of a lighting fixture? Thank you you for your help CB
Thats great! I was confused. Thank you so much for taking the time to help out the bewildered CB
OK, I don't want to turn it off or go to grey, I'm trying to get it to look like truss instead of a solid box. I see that it turns into truss when in grey, but not really what I'm looking for. Thank you
Thanks Kevin, Where do I find that? Thanks CB
Hello, Am I missing something (wouldn't be the first time). How can I make Tyler Truss look like truss instead of this (see attached screen shots) Thanks for any help Carl
Jim Wilson, you're a diamond!! that's the trick I needed. Thanks for your help everyone. Carl
Ok, thank you Here is my issue: I can see the gobo but the beam is solid, Please see attached screen shot. I'm expecting to see the breakup in the beam. is this possible? thank you Carl
Thanks for your help, I now have gobo's in my lamps. Is it possible to see the beam shape? I can see the image when it hits a surface but the beam appears solid. Thanks again for any help Carl
Hello, I have Thomas 4 lites in my drawing, I am unable to get light out of them I have tried various Fixture Modes. The 4 lites don't work in Vision either. All other instruments work fine. Any ideas? Thank you
Thanks for the info. I thought I had done that Please see attached screen shot. Am I doing something wrong? Thanks for your help.
Hello, I am working with renders in VW Spotlight, using Viper Profiles. Is there a way for the gobos to show in the render? Thanks for any help. Carl
Hi, thanks for your help with this. I'm waiting to receive the (hopefully) compatible capture device then Ill try again.
