Carl Burnett
51 -
Everything posted by Carl Burnett
Vision 'No Ambient light"
Carl Burnett replied to Carl Burnett's topic in Vision and Previsualization
Hi Kevin, Yes!!!!! That was it, I updated to SP3 all good now. Thank you very much Carl -
Thank you for the options Bbudzon, Apologies for delay in getting back to you. I tried the default in both preference boxes to no affect, I did try the background could change and the did show the lamps but other objects were missing please see attached screen shots. first screen shot is with background colour change, the second screen shot is the same drawing saved as VW 2021 then exported as MVR. Please also find original VW 2022 file attached. Thank you Ann Wilson June 2022.vwx -
Hi Tom, thank you for your answer. I have tried to adjust the ambient light level in this folder with no affect. Please see attached screen shots -
I am exporting from VW 2022 to MVR, ESC I have also tried send to vision. (exporting to Vision 2022) When vision opens there is no ambient light including at 100%! there are lamps there as I have randomly clicked and found some. I have saved the VW file as a VW 2021 and exported to Vision MVR and all works fine. Any ideas or solutions gratefully received.
Hello, I have used the lighting pipe tool to create floor stands, How do I add a texture/colour to them? They show up as white, I have tried to render texture in the Object info Pallet I have also tried changing the colour in the attribute pallet. See screen shot attached, What am I missing? Thank you for any help. Carl
Hello All, I hope you can help me with an issue. I have 12 x GLP X4 bar 20's in my plot 6 x 2 as per the first screen shot from VW. when I export in ESC or MVR the bars are as screenshot 2 & 3. when I rotate on the Y or the Z they rotate as screen shot 4. this image has 6 bars with the Y at 90 degree and 6 with the Z at 90 Degree. Any idea how I can rotate them so they face forward? Thank you all in advance for whatever help you can give. Carl
Hello all, I have created a stage using the decking tool, I want to make the black floor reflective how do i achieve that? I have tried editing the vsBLKtexture but has soon as I add reflectivity the colour disappears. I would be grateful for any help to point me in the right direction. Thanks in advance Carl
Hello All, I have a capture card that works with vision, I am having no problem using it with my Mac Book Pro. There is a problem when I try to use it with My Mac Pro (2.7 GHz 12-core Intel Xeon E5, 40 gig Ram, AMD Firepro D700 6GB) Vision and the file open fine with the select Video Source window open, when I press OK Vision quits!! Using same file and capture card I have no problems with my MacBook. I have updated to latest software on both machines. Any ideas would be appreciated. Carl
Video Screen Sizing/Scaling
Thanks bbudzon, MVR? not sure what the is, so i guess I'm not using it 🙂 Im just exporting straight out of VW to Vision. Thanks again for responding Carl -
Hello All, I have finally sorted a capture card that works with vision. I now want to know how I size or scale the screen or image so it doesn't duplicate as in the picture attached, you can see that the bottom of the image also appears at the top. Any help is appreciated. Thank you Carl
Hello all, I have posted this in the entertainment part of the forum, thought it worth looking here. I am using GLP Impression X4 20's in my design. I position them in VW (1st pic) then when I export to vision (2nd Pic) this happens. I have found a work round which, is to rotate them in Vision. The problem with that is if I have to modify the VW file i'm back to square one! I am using 50 X4's so it takes a while. Is there a permanent fix? I also have issues with some instruments being upside down etc but that's not such an issue. any solutions/help appreciated. Carl
Hey Gaspar, that worked, so it's a good work round, but if I make any mods to the VW file I'm back to square one. Thanks for the solution carl
Thanks, i’ll give it a go tomorrow and let you know. appreciate your help. Carl
Really? i have tried rotating by 90 degrees, is that what you mean?
Hi everyone, Wondered if anyone had a solution to this orientation issue. I really need to start programming and this is obviously an issue! Thanks for your help. Carl
Hi Paulo, sorry for delay been caught up in other stuff. Only in this project, I think. If change my background it makes it more visible but seems a bit weird I would need to do that. Thank youCarl
Hello, I have my instrument summary (pic 1) create Viewport (pic 2) print to pdf and this happens (pic 3) why is this happening? how do I rectify the issue? If I exit view ports and go back to drawing if I click on plane/ Layer/screen it restores to complete summary. Thanks for any help?
Hello Franco, It was in the Vectorworks Libraries in resource browser. if not it will be in VSS library. Carl
Hello, What have I switch off? or done wrong? Drawing is fine as soon as I fo to open GL or fast render the drawing goes into darkness apart from the glowing grass. The light options in view is at 100% Any ideas please? Thank you
Hi Klinzey, It is the GLP X4 Bar 20, 20 Channel
Hello, Why is this happening? how can I rectify it? So I have GLP X4's I position them correctly in VW when I export to Vision they seem to position themselves randomly as you can see by the attached photos. I tried turning them by 90 degrees in VW you can again see how Vision positions them. VW and Vision are both 2019 SP3 Any ideas please? Thank you
Hi, I am trying to render in Style or fast render. I render in openGl and everything looks fine, from there render in a style or fast render and lots os stuff goes missing.Please see attached. What am I doing wrong? I'm sure its simple but i'm lost. Thanks for any help
Thats great thank you. Guess I should have remembered to save my prefs when I updated. duh
Hello, I have just updated to SP3, where as the Lighting Pipe tool gone? it looks like VW has gone back to default settings is that part of my not seeing the pipe tool? Thank you
