rvanhees
38 -
Everything posted by rvanhees
Hi, Is it possible to make a worksheet from the active class / viewport only? Now he adds everything together .. (See fig 1) Is it possible to determine the order yourself in the worksheet? VW does it in data visualization.
@TomWhiteLight Yes it works, thanks a lot! Uncheck save vgm cache was enough, I had the latest service pack. Can I leave it uncheckt?
@isyme Yes I made of the truss by modify a symbol and than i get this. See Fig 9. (But the attributes is always there)
No does not help... Now I also have it by a circle (fig5) as i go to class and simplified on than i see them (fig6) but nog in GL. @isyme were can find this? I do not see any difference between the FD44-300 (fig7) and FD44-X (fig8).
Hi, I made a drawing in VW201. In Top/plan -2D plan I see the truss corner FD44-X (fig1), when I then switch to 3D Gl the FD44-X is not visible (fig2). When I select the FD44 with my mouse, it is there (fig3) Also if i simplified the truss. (fig4) All truss is in the same layer / class. Does anyone know how to fix this?
Hi, This is the original record. The red circles were to clarify what I meant. It is final Quality Render, and i have no ceiling.
Hi, When I make a rendering via renderworks camera tools and then create vieuwpoort with a number of spots, I get a kind of reflection on the floor. The texture Tile granite is in front of the floor in Render. How can I get it out? / What am I doing wrong?
Hello, Just started with Vision ... If I transfer my drawing from VW2020 to Vision2020, the lamps go to a zero point. I have already found this on the forum. Is there a way to rotate or aim the lights in Vision without a lighting desk on it? Or another easy way to aim the lamp, for me its now just for the visualisation. Tnx
Hmm very strange, I open now my file again and its gone .... Think it's a bug ...
Hello, For some reason I have a 2d laptop in my drawing that I can't get removed ... It is in the None class, if i put the visibility off it is gone. (tried all other classes) In Open Gl you see the 2d version. (I think it was created after adding the laptops at the reception desk, 2D plan you don't see them ) How can I remove it?
Hi, I'm using the Tool set > Table and chairs. There is no option (Shape) to choose: round. Is there a easy way to get round dinner table?
Who can help? Amateur user of VW2019 Spotlight. My worksheet does not display the correct number. I made several designs, and most of the time he did well on recalculation. If this did not go well, it would have been resolved to create a new worksheet. Now I have a design where recalculating and recreating a worksheet doesn't work. I'm curious what I have to look at to solve it. In design 15 objects in sheet 16 objects. In this case VW counts 4 x FD34 200 but there are only 3 in drawing. Thanks in advance. Rob. G-3-333.vwx
Hello, Is there a way to make a report of only the viewport? Now the report gets everything of the design.
@JustinVH Hi Justin, i don't get it, try everthing put ratio 1:100, have made different sizes .... Also strange if i put the VW Colorbars 1x1.89 is works perfect. Try to find out wat size it is, try to copy it ...
@JBenghiat Hi Tnx for the answer, it works.
Hello, I made a floor in VW2019 for a stand. From Top/Plan: 1) Rectangle tool 2) spotlight- architactual - floor 3) tab render - texture - wood The problem is het puts the texture under see picture 3 I tried flip / rotate etc ... Is there a easy way, or what did i do wrong?
@JustinVH Hello, i dont see the check boxes "repeat vertically" and " repeat Horizontally" ..... and set by image does not work. See the file. 4006223 - BOOM - EMS.vwx
Hello, I want to put a logo on a screen, but whatever I try, whatever dimensions, he continues to publish in the box. What do I wrong or what should I do?
@JustinVH Other question. How can I turn the doughty, I have tried everything (I think ...) flip, rotate and rotate tool Thanks.
@JustinVH YES it works, very nice. thanks to you! See the picture. A detail, now the FD44 CS1-DC10 is also square and in real he is round. Can you explain to me how you do that, how you make those symbols like you did that with the BOB. A video would be nice. Many thanks.
@JustinVH Many thanks and the video makes so much clear, that helps me a lot! If i set the bold-on in render open Gl they stay in square, is it possible to get them round? (When you have time to spare, would you like to make a video about how you made the symbols?)
@JustinVH Many thanks for it and your speed for helping me. I'm not yet an expert so i don't get it. I see the new symbols but still don't get them right ... sorry. Can you make a video .. ?
TNX, but the client wanted HD44 (now i am using FD44 because there is no library of HD44..) I looking forward to you answer.
@JustinVH, that would be very helpfull, last time you made a nice video so I understand complete what you did. I made a new file, above you see a part of the imported DWG sketup file, i wanna build the same in VW. The blue is Sketup and yellow VW. TNX !! Example VW Corner.vwx
