59 -
Gaëtan Dechancé started following David Dauphin
Hi, To update my LED panel library to the new 2026 tool "LED Wall Tool" : - I attached all my LED Panel symbols to the new "Video LED Wall Panel" record (and "Video LED Wall Accessory" for stackers and bumpers) - I have an Excel file with all informations for each Panel and stacker and bumper. In this Excel I've got the symbol name in a column, so this could be the link with VWX library. How can I populate records files in the symbols with this external Excel file ? Instead of wrting one by one manually in each symbol of my librairies... (I don't need to update my Excel file with symbol data or record after this step)
Hi, I’ve got questions about EntEquipUniversal : Is this record automatically populate when using spotlight device ? I created in my template a custom EntEquipUniversal because I would have more fields and then may be able to mix with more facility some fiels in worksheet. By example, if I want a worksheet with truss, hoist, speakers, lights, video, … I can’t have a simple and direct «weight» field because each device has his own field with different name (weight, weight imperial, weight metric, …)and different unit (g, lb, kg). Then formulas becoming very very complexed ! If this new EntEquipUniversal record is automatically populate by spotlight instruments, how can I reproduce it with my own EntEquipUniversal_Novelty ? Here is my custom EntEquipUniversal :
Speaker and Speaker-Array Tools VERY VERY important improvements
David Dauphin replied to David Dauphin's topic in Roadmap
yes it's really the bigger issue of this tool 😞 -
I got some of my symbols in 3 positions like yours. Same problem with z0. It will be very very netter if speakers would work as good as Lighting device 😉 -
Hi Ben, I use stand as lighting accessory. Just need to draw your stand upside down. then when you rotate the lighting device 180° X or Y, then stand is in the correct way. Hope my english is good enough to be clear... -
Hi Christiano. No solution for me. Sorry -
Bonjour, Dans le cadre de renforcer notre bureau d'études, nous recherchons : Pour notre entité soit à Paris (7ème), soit à Longjumeau (91) (au choix) : un ingénieur en structure et charpente, ou un diplômé de BTS/BUT en génie mécanique/construction. Pour notre entité à Nice : un ingénieur en structure et charpente, ou un diplômé de BTS/BUT en génie mécanique/construction. Le principal du travail portera sur des projets scéniques, majoritairement en poutres treillis, mais pas que. Nous assurerons une formation apprentissage des logiciels RStab et RWind sur lesquels nous simulons nos structures. Pour plus de renseignements, me contacter en MP.
Hello, We use speaker and speaker-array tools every day with more than 100 users. We've got many restrictions with those 2 tools, mainly when using with symbols instead catalog mode. Symbols are really important to have correct geometry. Here are our problems with those tools : Speaker-array tools is unworkable with symbols. When array is populated, then you can't easily move array, or do anything else, because it seems hat this tools draw new 2D geometry permanently. A solution will be to don't use 2D and use only 3D when speakers inside array are angled. Like Truss tools. You can have hundreds of truss angled and easy to move Speaker array files are too much big. Here attached files example. One set with 4 configurations : Speaker-Array-Catalog no populated = 17,1Mo, catalog populated = 17,8Mo, speaker-array symbols no populated = 123,1Mo, symbols populated = 1,79Go (I can't upload it, too big) !!!! We need to have our yoke, with correct geometry, and with real insert point. Now, the insert point is systematically at the center of the speaker, but that's not right in many real speakers. There is usually a Y/Z shift. Real yoke is very important to have corect geometry with scenography, decoration, ... Same thing, we need to put our correct tripod with real geometry sometimes we need to have specific shift between speakers in array When a speaker is used with a yoke, the weight doesn't change. It will be very important for braceworks calculation when we will able to put our correct yoke with symbol Speaker-Array tool is limiting global angle to 90°. We often use array with more than 90° Many often we have a second bumper in line-array but not the same than the first. Actually the tool is limited to 1 sort of bumper. I have a tip, I duplicated all my bumper and modified them as speakers. So I can insert them between 2 speakers in array (but then limited to 2 sort of speakers instead of 3). We need to have more than one bumper sort in an array. A tip to have correct yoke is to use speaker-array instead speaker for one speaker+yoke. But then when you angle the speaker, the alignment with the yoke is moving. So that tip isn't efficient.
Hi, same issue with Lit Fog acroos objects/textures,...
Ben3B started following David Dauphin
Bonjour à tous, Nous sommes à la recherche de 2 ou 3 dessinateurs, de préférence sur Vectorworks, mais tout novice provenant d'Autocad, Sketchup ou autre est le bienvenu. Principales missions : plans d'installation de structure scénique, plans de conception, calcul de charges, plan de fabrication de pièces sur-mesure. Localisation : France. L'idéal serait des dessinateurs sur Paris mais nous avons des agences à plusieurs endroits (Nantes, Bordeaux, Caen, Toulouse, Nice, Lyon, Longjumeau, Roissy, Gonnesse, Paris) qui peuvent servir de point de rattachement à une personne qui serait en province, voir en télé-travail une partie du mois. Nous recherchons aussi un ingénieur structure et charpentes métalliques dont la mission sera de calculer des résistance de structure, les lestes nécessaires à leur stabilisation au sol, la résistance au vent, au basculement, ... Ainsi que le dimensionnement des matériaux pour les fabrication de pièces sur-mesure. Pour plus de précisions, envoyez moi un téléphone par MP.Merci.
toto started following David Dauphin
Schematic Views cannot be Pasted without the Model Object they are Based On
David Dauphin replied to pfalvi's question in Troubleshooting
Hi, Same bug with SP3.1 on OS X 12.4 -
VW 2022 SP2 Menu Bar not working
David Dauphin replied to Dennis Moore Jr.'s question in Troubleshooting
Hi ! Still got this issue with las VWX2022 SP2.1 and OS X 12.1. A colleague of mine has got the same issue on his MacBook Pro. To fix it momentarily, as I do, he had to change resolution of the scree, without closing VWX. Others colleague with Macbookpro, OS X 12.1 and VWX SP2.1 don't have this issue. We are only 2 with this issue, and we got same extension and our Mac to control screen : SwitchResX !!! Maybe this is the reason of the issue? Others users with this issue, have you got too this SwitchResX extension or similar one ? -
Another precision : I quite VWx, then I start it again without change the display lower resolution. And then menu bar issue running again. I change again resolution with my previous highest resolution and then menu bar works. Trick seems to change resolution not especially for a smallest one. -
Hello, I've got the same issue. Not everytime. Lan's trick seems to work, but hat's not a great solution for me, I used to work with highest resolution, and with this trick I had to smallert my display 😞 Here my configuration : VWX 2022 SP2.1 27.0.2 (627588) OS X Montereu 12.1 MacBook Pro (15-inch, 2018) / 2,6 GHz Intel Core i7 6 cœurs / RAM 16 Go 2400 MHz DDR4 / Radeon Pro 560X 4 Go Issue with 1900x1200 resolution. Seems to wrok with standart resolution 1680x1050 -
Tip: Changing height of multiple Truss Systems at once
David Dauphin replied to Peter Neufeld's topic in Braceworks
Hi again Peter, I have just re-install VWX 2020, and I can confirm that your tip is working great with 2020 but no longer works with 2021 😞 I post a bug issue.
