12,808 -
Everything posted by Vectorworks - Admin
General non-functionality on Laptop
Vectorworks - Admin replied to Steve Clarkson's topic in General Discussion
Most likely, there may be a way to disable it there, also it may sound odd, but check the laptops documentation and make sure there isnt a hardware toggle for it, i've seen some come with physical switches or fn key combos that can change that setting as well. Dont try to disable the integrated GPU in Windows device manager though, that causes a bunch of other problems (I know from experience) -
Are you using an external monitor or is the 4K display the laptops integrated one? Did you change the default GPU by using these steps, or via a different settings pane like System or Geforce Experience? -
Could you send me another Dxdiag now that thats set please? It'll give me different info based on which one is active at the time of the report. -
A 1050 should do alright, reply back with the following from that machine please: -
If you can, pop that image prop into a file on its own and post it here, should be fixable.
Select the texture the Image Prop is using in the Resource Manager, then right click > Edit, you should be able to uncheck "Cast Shadows" in the texture edit dialog and then light wont affect it any longer.
No flat size rating that determines it, speed and memory use also have to do with what KINDS of geometry you have. Meshes and some other 3d polygonal geometry types are particularly important to keep an eye on, but theres no strict regimen to stick to.
Streamdeck integration.
Vectorworks - Admin replied to Matster's question in Wishlist - Feature and Content Requests
That'll depend on interest! The more votes this thread gets, the more likely. I'll take a look and see if the rest of icons can be pulled from elsewhere.- 113 replies
- 35
Vectorworks Significant Energy Use
Vectorworks - Admin replied to Mark Freeman's question in Troubleshooting
That GPU is only the minimum spec for what should run so that isn't too surprising. Vectorworks is a very demanding high powered application and it will use all system resources it possibly can. You MIGHT be able to reduce energy use by using Tools > Options > Vectorworks Preferences > Display > Navigation Graphics and setting it to Best Compatibility, that will reduce GPU usage, but performance will suffer. -
Vectorworks Library Disappeared
Vectorworks - Admin replied to michael john williams's topic in General Discussion
Do you happen to have any TrendMicro security products on that machine? I've had a few reports of their security suite attacking some of our application guts recently. -
If you're on a Mac, you should be able to get at them directly, the "2x" ones are the ones for high res displays: Macintosh HD ▸ Applications ▸ Vectorworks 2019 ▸ (Show Package Contents on 2019 app) ▸ Contents ▸ Resources ▸ Vectorworks.vwr ▸ Images However I've attached a zip of that folder in case any Windows users need them, as I think its harder to get at them from that OS. The naming and folder structure wasn't meant to be user friendly, but searching for a tool name within this zip should find what you need. Images.zip -
Memory usage can also be dramatically affected by how large your file is in conjunction with how many Undo operations you have set in Vectorworks Preferences. I believe he default is 20 operations, but many people increase this to 100 which can spike memory use significantly. We are also tracking our RAM and VRAM usage footprints and have some upgrades planned that should reduce how much memory Vectorworks and the VGM need to perform the same amount of work.
Shading not showing up in cross section
Vectorworks - Admin replied to ffloid's question in Troubleshooting
You may need to select the Section Viewport, and then under Advanced Properties > Attributes, make sure that Sepearate Cross Sections is selected and that "Use Attributes of Original Objects" is checked, I think it will default to a solid grey or red section plane color. Screenshot included in case the German version has dramatically different names for the settings: -
If youre rendering on the design layer, then yes reducing screen res (or reducing anti aliasing) will reduce the effective resolution that it renders at.
If you resize the palette by grabbing and stretching the bottom right corner of that palette, do the tools appear, or flicker, or stay grey? This is 2019 Service Pack 3 you've installed? (I can tell this from the name of the installer download you used if you arent sure.)
You can create a custom Renderworks style for this that is faster than the default modes. I cover this for a different reason here, but the same knowledge applies:
Student License Extension Request
Vectorworks - Admin replied to Polina Bouli's topic in General Discussion
We can, but you will have to request the extension here first: https://student.myvectorworks.net Once you do, we can approve it directly. -
Changing of laptop and licence conflict
Vectorworks - Admin replied to Eugene Merkulov's question in Troubleshooting
Apologies, if there was an attachment I did not see it. -
This is now working again for me on 2019 SP3 on macOS 10.14, I am able to scroll by dragging to the edge not only in single view but also multiview, both were broken for me in prior releases and I had been able to reproduce it there. Does this happen in all files for you? Does it behave the same when drawing as well as drag/dropping objects?
- 3 replies
- mac
- window scroll
(and 1 more)
Tagged with:
This should be corrected shortly. -
What error message specifically? There are a few related to licensing with difference causes. -
Vectorworks 2019 "not optimized"
Vectorworks - Admin replied to Marconi's question in Troubleshooting
This is just an overly sensitive alert in Mojave. It's been chiming in on some other of my major apps as well. It has to do with the OpenGL engine we use, there is a discussion on it here if you're interested in the details: -
Service Pack 3 for Vectorworks 2019 released
Vectorworks - Admin replied to Vectorworks - Admin's topic in News You Need
This is only half to help people workaround the issue. The other half of myself and a lot of other employees asking about this setting is that in Best Performance, pretty much all graphical glitches would be the fault of the VGM and significantly narrow down what the core problem is and what team needs to work on it. If the issue happens in Best Compatibility but NOT Best Performance, it means its a bug of the old graphic system and not as much of a priority. If it happens in ALL modes, it means that the issue will likely be much harder to track down, but that it is much more urgent that we do so than in the previous example. Eventually users won't have control over this and it'll only kick in the Compatibility modes when launched on weak hardware and the user will be alerted to this fact. Kind of like a Safe Mode, but that could be awhile off as we are still transitioning systems into the VGM. -
Does it render as wireframe or as a black/white rectangle? Does the same thing happen in other files or just this one? Same issue after restarting?
We have LOTS of good stuff on the way. Keep an eye out. (Not going to jinx it!)
