chaz
    52
Everything posted by chaz
  1. We have the same issue except our files are on Dropbox rather than Google Drive, but they are all sync'ed to be available locally. I had hoped VW24 would help but it seems to make the files take even longer to open.
  2. We had the same issue with a Project File and multiple users. File would eventually open but would take 30 or more minutes.
  3. I downloaded the 23 viewer but it appears to just be the VW23 installer. Is this correct? I already have VW23 installed and want to test out the viewer before I give it to some of my coworkers. I wanted to check that it works with a Project File.
  4. Using VW2021 and having this issue, 3 days before I fly and this project starts becoming reality. None of the work arounds suggested work. I am the lead designer and admin on the project and running out of time on a project that cannot be delayed. I spent a long time yesterday and traced the error to resizing a rectangle. But now I'm in completely different layers and none of them will commit. Very disappointing that no one from VW has commented here. VW doesn't really seem to be ready for Project Sharing, always have big issues. I'll probably move us to using referencing more in the future and rely a lot less on Project Sharing, just don't need the headaches when facing deadlines.
  5. Did you get this straightened out?
  6. I had this problem in VW2020 and now I have it again in VW2021. I'm on a Mac.
  7. My floor is just an extruded rectangle. But, I just tried selecting from below and it works! Also tried selecting the drape from the backside and that works. I checked and "two-sided" is on.
  8. I'm having a problem with exporting using the Datasmith plug in, I can't select some of the objects in TM, usually the floor. I click on it and it selects the starting ground, which is below my floor, also click on it with the eyedropper and it picks up the starting ground. I can select other objects in my scene. I can't drag textures to the floor either. I have pipe and drape, I can select the pipe but not the drape. This has happened on multiple files. If I export/import in C4D format, I don't have this issue. I have service pack 3.1 on a Mac. VW says there is an update but all I get is a message saying the updater needs to be refreshed so I hit "update", it runs through a progress bar and then disappears. Trying again to update just runs through the same thing again and again.
  9. I'm curious how you have the lighting set-up. I think you have some spots pointing straight up at your circular light fixtures due to the shadows and round light spots. But how are you preventing the sunlight that falls where the walls meeting the ceiling and what are you using for overall lighting in the room? It looks like you do have a few windows but not enough to light the room (?)
  10. I'm really on the fence about continuing with TM or not due to the changes in interior lighting in TM2020. I would like to stick with TM but if they have no intention of fixing interior lighting, it is a dead end for me. It is really frustrating, I still get much better results out of 2019, I've tried all kinds of things in 20 but with mostly unacceptable results and a lot of wasted time. This is a much bigger concern for me than a direct link with VW at this point. I'm starting to learn C4D, which is what a couple of our other designers use. But regardless, I really need a new computer and pretty sure I'll go PC for the first time in 32 years. It may not be the best time to be asking for an expensive new computer but I am past due with our company policy and my Macbook Pro just doesn't cut it on these programs.
  11. What advantages are you gaining in terms of modifying in TM? Are you just talking about being better organized in the Scenegraph? Have you found advantages of using FBX instead of C4D?
  12. I just export C4D Sort by Textures, no need to do a lot of extra work in classes. And then import into TM as Collapse by material. The import update button works fine.
  13. Sadly, I blame Apple with their on again off again approach to the pro market. I'm leaning toward switching to a PC after 32 years being Mac only.
  14. Thanks, I submitted two items under "submit ideas". I think they are really missing out with the difficulties of creating interior scenes, with the sun bleeding into 100% enclosed spaces with no windows and lights that don't function properly that were introduced in 2020. They are really limiting their market to architecture. I still find 2019 much better for most of my work but I wonder if it is a dead end if the software is going to stay so limiting.
  15. Well, I've been struggling with this same issue the last two days. Had a file I've been working on for over a week and suddenly, when I go to update the C4D file, I would get nothing; even what was already imported would disappear. This was in TM2019. I was able to open the 2019 file in 2020 but when I tried to update the C4D file, it would go for awhile and then lock up. I went back to a back up file and same thing, even when using a back up C4D file. I tried downloading and reinstalling 19, trashing my user library, etc, etc. I found I couldn't even import a simple cube into a new TM file. Lots of googling and I finally came across this: Hi. On re-installing the apps on my Macbook Pro I have discovered the conflict (which is now back again!) as unfortunately it is a piece of software required for Remote Access to the office which I use regularly - Namely GlobalProtect version 4.1.7 -18 by Palo Alto Networks. As soon as this is installed Twinmotion will not import files. I didn't even remember that I had installed it but on a call Monday, we were reminded that we needed to use it to be able to remote access in to change our password if it was expiring (I had 5 days left) so I had downloaded it. Now I'm trying to get our IT dept to uninstall it so I can get my work done.
  16. TM2020 has an automatic back-up option so I would use it! Doesn't seem like it makes a lot of sense transferring 2019 files to 2020; all of the lighting and people have to be redone. But I guess that isn't a big deal if the sun is your only light source. I'm working on an outdoor scene and wow, is it easy with only one light source! I experimented with some 2019 files and the people get swapped out and don't even maintain their pose; I had people who were standing changed to sitting and vice versa. Now 2019 just crashed on me twice.
  17. @rb-arch Last night I re-exported from VW and updated the import in TM. I realized I had some layers off in VW and went back and turned them on and re-exported. When I updated TM again, I lost the textures that had been on layers that were missing on the last update. So I closed TM without saving, reopened it and then updated the import so that it had the accurate update without the inaccurate one. Normally I set up VW with all the layers and classes I need on in TM and save a View so that I can always go to that View before I update the C4D export and avoid exports missing things. I'm still using TM19 at this point. I've found 2020 will hang when trying to import a lot of my files while 2019 can successfully import.
  18. @rb-arch I use the same settings as you. Most of the time TM keeps the new textures but I have occasionally seen it revert back to the VW textures when I do an update. You're losing all of your replaced textures? VW export to C4D via textures, final renderworks.
  19. I don't think Enscape can animate people, cars, etc. , if that's important to you. Picked up a few good tips on the TwinMotion webinar this morning. Here a link in case you missed it:
  20. Ok, thanks, I'll try that. I tried using like 0.01% glow and it would blow out but I didn't have the texture in both color and glow channels. Nice work everyone.
  21. When you say "I can activate a texture with glow and have it emit light" is it a texture or a material? In 2019, I can place a screen image texture on a screen and then adjust the glow to "backlight" the screen and make it realistic rather than dark. If I do this in 2020, it just blows out to a pure white, even with just a fraction of a percentage of glow. Same thing with a color, blows out to white immediately.
  22. I found a discussion on the Epic Games website with others having problems with the lights and several users going back to TM19. It seems interior lights don't work unless it is nighttime. I think Epic Games is just focused on architectural renderings (granted which is the primary market) and have changed the program so it doesn't work well for interior work unless it is mostly lit by daylight. Meanwhile, Enscape has a PC only beta plugin for VW. Looks like they don't have the animated people. I may have to look at Enscape and Lumion; I've already been thinking about asking for a PC workstation as sadly, Apple isn't keeping up.
  23. Anyone else having major problems with 2020? Besides the ones I listed earlier, (sunlight appears in a room enclosed on all 6 sides with no windows as before but previously I could turn the sun all the way down and crank up ambient light but now ambient is tied to sun exposure; and glow immediately blows out to pure white). I've got three VW files I've exported as C4D and successfully imported into TM19 but if I try to import into TM2020, it locks up the program. Using a MacBook Pro 2.7 GHz Intel Core i7 16 GB 2133 MHz LPDDR3 10.14.6 Last week I had a big project and went back to TM19. I hacked in video to play on the screens and it worked great and I produced some impressive fly throughs. But I'm getting really close to giving up on TwinMotion if I can't get 2020 to work for me; I don't want to continue if it is a dead end. My company is soon looking to standardize on rendering software and I can't even suggest TM at this point, despite the great results I got on the project last week. A couple of our other designers use C4D. Here's the room with no openings but sunlight still shine in:
  24. I'm still struggling with the new version. The Glow function now just completely blows out any texture map or color to just be 100% white, even at less than 1%. I used to use this to lighten up monitor screens but now I can't. But I see colored lights in the reveal video that they seem to indicate using glow so I'm not sure why mine immediately blow out. And I'm still struggling with the lighting on interiors that have no exterior lighting, it seems the sun leaks in even without windows and ambient lighting it now dependent on sunlight so I can't just turn the sun all the way down like I used to. I tried making it midnight and cloudy, which is a lot more trouble, but still having problems. I went back to the old version and it felt a lot more zippy on my MacBook Pro. One new feature that they have barely mentioned is displaying video, though I think that may have been possible in the old version but not as obvious.
  25. No, I received an email from unreal and followed the instructions for downloading: To install your copy of Twinmotion 2020, open the Epic Games launcher and log in with your Epic account. Select the Twinmotion page in the Unreal Engine tab, and click Install above Twinmotion 2020.1. Follow the prompts to complete the process.
