206 -
Everything posted by fuberator
hi @Alex Sagatov yes, I see it, also while zooming in and out I have seen other "shards" that led me to believe that is was a failed boolean operation. I have spent a lot of time tracking those down to see if they "pointed" at anything, but they do not. and as @bjoerka points out, 3D is not needed of course, and it is 2D. But in the documentation/presentation/planning of this I have components mounted on the back of this plate and they are 3d. In conclusion, I extruded a copy of the shape to 3mm and that looks clean in the openGL views, confirming that this is some kind of bug or limitation to how the display in plan view handles this. It also makes me feel that the 2d lines I am sending to the manufacturing are not confused. Thanks
Hi I am doing a lot of surface clipping because I am preparing an aluminum laser cut. Lots of small and big shapes. Inevitably after a certain amount of "clips", I get what looks like a problem. I can only see it in open GL by looking at the fill and the selection. I have tested all individual shapes and none of them seem untight or cause problems on their own. It's risky to send it off to the laser company before I know that my model is "tight" so I want to try to get to the bottom of this. Thanks for any ideas Fubbi Plan view: Open GL view with weird selection markup:
ok I will try that, thank you
I understand now. Never noticed there were three preferences. A bit confusing with two already 🙂 Also I had not clicked in the scene graph, sorry. Now i get the fps. Empty document, nothing except chrome running: I do not have the tool selection bug on my laptop which is also running catalina. It must be specific to my system on that 6,1 machine. Vectorworks is also giving me grief on the same machine which I have detailed in another post Time for a wipe perhaps
Hi I tried both letter o and zero, none of them spawn a fps counter for me. Interestingly enough, the preference bug is back, I get the same window (the one without haze settings) in both menus. Made a recording... Screen Recording 2020-06-17 at 15.05.54.mov
I tried to open a new file, set the haze to low - still the same behaviour
HI I am running sp3, I had my hopes up when sp3 came, but it's something deeper. If you experience this too, maybe you are more qualified to report the bug in a constructive way? ps. to close the about box I clicked ok exactly 6 times before it "took"
Hi I tried it, and them immediately made a screen recording Screen Recording 2020-06-16 at 14.01.18.mov
I have a PC built for Vision and it works like a charm, but on my mac osx catalina — trashcan 6 core — d500 — 32gb, its always been less capable. Thats ok, its an old machine. However, at the moment I cant use it all because its bugging out. I think the last time I successfully used vision on mac was the 2019 version, which is of course also before i updated to catalina. Thats ok, I don't expect to crank the settings on this machine. I just open MVR/ESC components to check them as I build them. I can only do some quick viewing with ctrl-middle mouse, after that I close the document because its pointless to try to do anything beyond that without fixing the basic functionality. I am adding a small screen recording of the tool selection phenomena. It was definitely giving me the same prefs window on both separate menu commands. A wipe and reinstall of Vision fixed that particular mystery. NDI is its own little beast, I should not have mentioned that in this context... ps. added the same recording twice by mistake, sorry Screen Recording 2020-06-16 at 13.52.32.mov Screen Recording 2020-06-16 at 13.52.32.mov
Hi I have tried extensively to track this down. I suspect it happens if I "edit report" in a worksheet that was initially "placed on drawing". When I close the editing of the report I see the pointer turning into a crosshair briefly, which is the behaviour for the initial placing on the drawing, It's a really a bummer. I use a lot of worksheets and when I edit them I am left with the dead windows taking up screen space and forcing me to regularly restart VW.
Hi I am freshly updated to latest Vision 2020 (25.0.3 SP3) on osx Catalina. Its currently impossible for me to use vision at the moment. Tried uninstalling and reinstalling. -The tools get selected (but not activated, just a selection box), but not deselected. If i click the tools one by one from top to bottom, they are all selected as opposed to the last one clicked. -its almost impossible to close a dialog (prefs, options, save). I can kind of get it closed if I hit escape several times or click ok several times, - The application prefs and vision prefs are now the same, I can no longer access the preferences for haze, normals, etc. Only the one with graphics, interactive and session. -NDI shows up in the video input select preview, but not on my surface. This might of course be some scale/offset settings and not an error, don't know yet. I guess it's catalina making problems, is this known to be true and if so is there an update coming? Cheers
hi, cam?
Hi You might not need to destroy the symbol. There are three values you can modify, tilt of the screen, tilt of the projector and the vertical position set to specific shift. By massaging these three values you should be able to hang at any angle including "projecting on the floor" Hope that helps
Hi I will try to figure out the sequence of events, in the meantime I work around it thank you
Hi I am using a ton of extruded rectangles and I would like to create a worksheet to list the total area (to calculate cost). Is there any way to get to the width and depth of an extrusion, or the rectangle within? cheerio
Hi How can I merge two worksheets? The append to existing worksheet is no longer an option when editing an existing worksheet report cheerio
Mac os 10.15.4 | VW 2020 sp3.1 Sometimes when I am working with worksheets in my documents I can not close the worksheet editor. This image is from having worked in and closed 2 separate documents, each of them having got stuck once. I can still move the windows out of the way, and after a restart of VW they are gone. But there is no closing them.
that worked wonders, thank you
hi I just converted it to nurbs, edited it slightly and then made a symbol
Hi I imported step files and they were drawn very fast in openGL. I had to convert them to get rid of some geometry so i chose nurbs. Now they are very slow to update. I have to watch as face after face is drawn. How can I convert them back to something less clunky? thank you
yep that was it for the sum. thank you! Still no luck with the concat command. I cant seem to get it accepted as a formula
Hi, That does not give me the individual subtotals, i dont understand the result at all. Am i doing it in the wrong place (directly in the selected header)?
Hi 1. Is it possible to dynamically calculate a subtotal (count*price) for each of my summarised items? 2. How can I add a string to my sums, something like: =SUM(D2) + "total $ " and =SUM(E2) + "total lbs "
