212 -
Posts posted by fuberator
Hi
Thanks for all your answers. I do want my geometry to stay on so hiding the fixtures is not an option.
F
1
Hi
Is there a way to switch all lighting fixture illumination off in shaded mode. While modeling I would prefer the default light.
I do realise I can edit every single light and switch them off, but I guess I am looking for the master switch.
Thank you
Hi
That would be great. I have sent you a DM
Thank you
Sorry to report that I am having the same issue, Vision crashes instantly upon import or merge.
I have tried both MVR and ESC and also just exporting a few fixtures and no geometry.
Tried on a m1 and an intel laptop.
v2023 with everything up to date.
How can I proceed to address this?
Thank you
Hello
i am exporting a mvr for grand ma3. Should it be possible to retain the orientation of the fixtures? I am using foucs points but when i import on the ma3 everything is just pointing down.
I tried to open the MVR in Vision as well, no fixture focus made it over there either, everything is pointing straight down. This is also true for "send to vision"
thank you for any ideas
20 hours ago, Dave Donley said:
Thanks I'll get in contact when we have something to try out.
sign me up!
1
Reposted this to an better thread:
Hi
[I posted this in the wrong thread, moving it here]
In spotlight, the lit fog light beams from all fixtures shine through objects like extrudes, walls and slabs.
I have tried all manner of textures and shadow settings, but I can not seem to stop the beams from shining through.
Grateful for any ideas
1
Hi
I am struggling with getting the total weight of all lighting devices in a column. I only get the total count when I sum values.
=sum(2.1..2.31) with the database row numbers does not work for me either.
Thankful for any advice
Hello
I am loving that fixture beams are now visible in shaded mode with lit fog. However, I cant seem to enable gobos. I am using the robe megapointe and in the OIP>edit fixture I can pick a gobo but the gobo is not applied and the selection does not stick.
What am I doing wrong?
Thank you
Hi
This ancient VisiCalc stuff has got to go! Please make sheets compatible with google sheets/excel/numbers. It is crazy to me that I work with those tools every day and when I come to VW do my worksheets I have to go and google how to do a sum on on some cells. And the whole interface feels like 1998. Making a cell text bold is takes a minute of menus and tabs, it just seems like a priority graveyard to me.
Or at least please explain
Thank you
1
Hi
You are right, there were non tube objects on the sheet that had the record attached, I would never have looked there. The tip about selecting 2.3 in an unsummarised list was really great. Found all bugs now.
Thank you!
2
Hi
I have a worksheet where I list all Rectangular Tube 3D instances in a design. I use a record to tell what part of the frame the tube belongs to and get the length.
There are ghost instances of the categories B and VBOT that are 0mm/52mm long. After thorough investigation I am 99% sure that they do not not exist.
In any case, how do I go about tracing this to its source?
Is there a way to search for objects that have a record entry (in spotlight)?
Thank you
On 6/20/2022 at 7:49 PM, AnthWhite said:
The truss shows up as blocks
The truss has a sub class called "simplified" that makes a box around the complex geometry. Just turn it off
Hi
I Am wondering how to apply the shadow catcher in shaded mode.
Atm I am applying the the shadow catcher texture to a thin extruded plane and the shadows look great, but are only visible if I give the plane a fill, which makes it gray when catching the light. This is what I would like to avoid.
I am lighting with a default heliodon.
Grateful for any advice
it gets rid of it completely. I realised this after posting. Consider facepalm slapped and apologies
1
possibly stating the obvious: With the viewport(s) selected: choose "none" in the data visualisation popup in the OIP and it disappears
Script to turn off the lights
in Vectorscript
Posted · Edited by fuberator
Hi
I would like to find out how to make a palette with a few functions.
A lot of times I want to work in shaded mode and I need to disable light fixtures temporarily to work in the default light, and then turn them back on to visualise what they are doing.
To Quickly compose looks it would be marvellous to have a floating window/palette with everything that can be found in the render section of Lighting Device→OIP: EDIT dialogue
Lighting Device → OIP: Edit → Tab: Light Information → Section: Render
How would I go about this. Is there an example of a custom window/palette that I could try to build from?
Thank you
