JohnWW
    11
Reputation
0 Neutral
Personal Information
  • Location
    Australia
Recent Profile Visitors
  1. Thanks for the reply Nikolay. Yes, it was an orientation problem. This leads to my next question about my project: How do I see more options in the advanced customization Label Style drop-down menu? Where is it pulling these options from? Resource Manager?
  2. Hello Conrad I have developed the concept of having network switcher and router horizontal with LAN ports. Problem is then when I run the contact tool it always wants to offsite the cable on the horizontal. See attached picture. Yes I can move the cable with the reshape tool but this add time to the procuess. Is there I can do to get the start of the connect cable to not offsite Horizontally? Thanks
  3. Hello Brain What was the fix for this one? I am having trouble get my head around the workflow with adding equipment to slots? Thanks
  4. @Conrad Preen This is going to be the same problem with audio amplifiers racks and something like a Nuetrik NL8 speakon connector. How we do we model for signal flow and inventory records? The entertainment industry uses lots multipin connectors that normally get split at a connector to tails. Is there a plan to include this?
  5. Hi Tim Have worked out a way of showing LC to Quadcore opticons? Thanks John
  6. Thanks for the reply Nikolay Not really. Is there a simple way off moving the text on the end of the cable? Thanks John
  7. Hi @Nikolay Zhelyazkov Is there any online resources/ manuals that covers changing the text (placement,font,size) on a circuit? I am trying to change the size of the connector type tags on the circuits. Thanks John W
  8. Hello Folks I am tiring to draw some metal boxes that I need to get made. Try to show a flat plan of the sheet metal with details and then a folded 3d view of the job. I thought there was a simple 3d fold tool in VW19 which would allow me to fold a item at a line. Thanks JW
  9. Thanks Marissa That Works....
  10. Hello Folks Have a issue when I try to create a viewport in front view in VW19 spotlight. When I use the rectangle tool like I do in Top/Plan view to create the viewport in front view (or any view apart from top/plan) I don't get the pop up asking if I want to use the object as a viewport. It goes to the create viewport pop up. When It creates the sheet layer the whole drawing is displayed in the viewport. I cant edit the crop in the sheet layer. What I am I doing wrong ? Thanks JW
