Hi,
I am deploying vectorworks 2019 using sccm and the deployment fails . The install starts and install directory stuck as picture 1 attached and failed to timeout . anyone tried to install vectorworks using sccm ?
Using commandline as
$scriptPath = .\resources\installer\Install-Vectorworks2019.exe --mode unattended --unattendedmodeui none --UserName "User" --CompName "Compname" --Serial XXXX-XXX-XXX-XXX--installdir "C:\Program Files\Vectorworks 2019" | Out-Null
+++ Application not discovered. [AppDT Id: ScopeId_6E8F8258-883B-4E1F-9960-3885F19C3671/DeploymentType_26dc66ad-b807-4441-8f83-a5fdf423497c, Revision: 12] AppEnforce 11/12/2018 1:38:54 PM 8744 (0x2228)
App enforcement environment:
Context: Machine
Command line: powershell -executionpolicy bypass -file "install_x64.ps1"
Allow user interaction: No
UI mode: 0
User token: null
Session Id: 4294967295
Content path: C:\WINDOWS\ccmcache\1x
Working directory: AppEnforce 11/12/2018 1:38:54 PM 8744 (0x2228)
Prepared working directory: C:\WINDOWS\ccmcache\1x AppEnforce 11/12/2018 1:38:54 PM 8744 (0x2228)
Found executable file powershell with complete path C:\WINDOWS\System32\WindowsPowerShell\v1.0\powershell.exe AppEnforce 11/12/2018 1:38:54 PM 8744 (0x2228)
Prepared command line: "C:\WINDOWS\System32\WindowsPowerShell\v1.0\powershell.exe" -executionpolicy bypass -file "install_x64.ps1" AppEnforce 11/12/2018 1:38:54 PM 8744 (0x2228)
Executing Command line: "C:\WINDOWS\System32\WindowsPowerShell\v1.0\powershell.exe" -executionpolicy bypass -file "install_x64.ps1" with system context AppEnforce 11/12/2018 1:38:54 PM 8744 (0x2228)
Working directory C:\WINDOWS\ccmcache\1x AppEnforce 11/12/2018 1:38:54 PM 8744 (0x2228)
Post install behavior is BasedOnExitCode AppEnforce 11/12/2018 1:38:54 PM 8744 (0x2228)
Waiting for process 5688 to finish. Timeout = 120 minutes. AppEnforce 11/12/2018 1:38:54 PM 8744 (0x2228)
Process 5688 terminated with exitcode: 1 AppEnforce 11/12/2018 2:05:09 PM 8744 (0x2228)
Looking for exit code 1 in exit codes table... AppEnforce 11/12/2018 2:05:09 PM 8744 (0x2228)
Unmatched exit code (1) is considered an execution failure. AppEnforce 11/12/2018 2:05:09 PM 8744 (0x2228)
++++++ App enforcement completed (1575 seconds) for App DT "Vectorworks2019" [ScopeId_6E8F8258-883B-4E1F-9960-3885F19C3671/DeploymentType_26dc66ad-b807-4441-8f83-a5fdf423497c], Revision: 12, User SID: ] ++++++ AppEnforce 11/12/2018 2:05:09 PM 8744 (0x2228)
+++ Starting Install enforcement for App DT "Vectorworks2019" ApplicationDeliveryType - ScopeId_6E8F8258-883B-4E1F-9960-3885F19C3671/DeploymentType_26dc66ad-b807-4441-8f83-a5fdf423497c, Revision - 12, ContentPath - C:\WINDOWS\ccmcache\1x, Execution Context - System AppEnforce 11/12/2018 2:05:35 PM 8744 (0x2228)
A user is logged on to the system. AppEnforce 11/12/2018 2:05:35 PM 8744 (0x2228)
Performing detection of app deployment type Vectorworks2019(ScopeId_6E8F8258-883B-4E1F-9960-3885F19C3671/DeploymentType_26dc66ad-b807-4441-8f83-a5fdf423497c, revision 12) for system. AppEnforce 11/12/2018 2:05:35 PM 8744 (0x2228)
+++ Application not discovered. [AppDT Id: ScopeId_6E8F8258-883B-4E1F-9960-3885F19C3671/DeploymentType_26dc66ad-b807-4441-8f83-a5fdf423497c, Revision: 12] AppEnforce 11/12/2018 2:05:35 PM 8744 (0x2228)
Context: Machine
UI mode: 0
User token: null
Session Id: 2
Working directory: AppEnforce 11/12/2018 2:05:35 PM 8744 (0x2228)
Prepared working directory: C:\WINDOWS\ccmcache\1x AppEnforce 11/12/2018 2:05:35 PM 8744 (0x2228)
Found executable file powershell with complete path C:\WINDOWS\System32\WindowsPowerShell\v1.0\powershell.exe AppEnforce 11/12/2018 2:05:35 PM 8744 (0x2228)
Prepared command line: "C:\WINDOWS\System32\WindowsPowerShell\v1.0\powershell.exe" -executionpolicy bypass -file "install_x64.ps1" AppEnforce 11/12/2018 2:05:35 PM 8744 (0x2228)
Executing Command line: "C:\WINDOWS\System32\WindowsPowerShell\v1.0\powershell.exe" -executionpolicy bypass -file "install_x64.ps1" with user context AppEnforce 11/12/2018 2:05:35 PM 8744 (0x2228)
Working directory C:\WINDOWS\ccmcache\1x AppEnforce 11/12/2018 2:05:35 PM 8744 (0x2228)
Post install behavior is BasedOnExitCode AppEnforce 11/12/2018 2:05:35 PM 8744 (0x2228)
Waiting for process 7604 to finish. Timeout = 120 minutes. AppEnforce 11/12/2018 2:05:35 PM 8744 (0x2228)
Process 7604 terminated with exitcode: 0 AppEnforce 11/12/2018 2:15:02 PM 8744 (0x2228)
Looking for exit code 0 in exit codes table... AppEnforce 11/12/2018 2:15:02 PM 8744 (0x2228)
Matched exit code 0 to a Success entry in exit codes table. AppEnforce 11/12/2018 2:15:02 PM 8744 (0x2228)
Performing detection of app deployment type Vectorworks2019(ScopeId_6E8F8258-883B-4E1F-9960-3885F19C3671/DeploymentType_26dc66ad-b807-4441-8f83-a5fdf423497c, revision 12) for system. AppEnforce 11/12/2018 2:15:02 PM 8744 (0x2228)
+++ Discovered application [AppDT Id: ScopeId_6E8F8258-883B-4E1F-9960-3885F19C3671/DeploymentType_26dc66ad-b807-4441-8f83-a5fdf423497c, Revision: 12] AppEnforce 11/12/2018 2:15:03 PM 8744 (0x2228)
++++++ App enforcement completed (568 seconds) for App DT "Vectorworks2019" [ScopeId_6E8F8258-883B-4E1F-9960-3885F19C3671/DeploymentType_26dc66ad-b807-4441-8f83-a5fdf423497c], Revision: 12, User SID: ] ++++++ AppEnforce 11/12/2018 2:15:03 PM 8744 (0x2228)
+++ Starting Install enforcement for App DT "Vectorworks2019" ApplicationDeliveryType - ScopeId_6E8F8258-883B-4E1F-9960-3885F19C3671/DeploymentType_26dc66ad-b807-4441-8f83-a5fdf423497c, Revision - 12, ContentPath - C:\WINDOWS\ccmcache\1x, Execution Context - System AppEnforce 11/12/2018 2:38:39 PM 6064 (0x17B0)
A user is logged on to the system. AppEnforce 11/12/2018 2:38:39 PM 6064 (0x17B0)
Performing detection of app deployment type Vectorworks2019(ScopeId_6E8F8258-883B-4E1F-9960-3885F19C3671/DeploymentType_26dc66ad-b807-4441-8f83-a5fdf423497c, revision 12) for system. AppEnforce 11/12/2018 2:38:39 PM 6064 (0x17B0)
