georgebpnz
Content Count
4 -
Community Reputation
0 NeutralAbout georgebpnz
Rank
Greenhorn
Personal Information
Location
New Zealand
Recent Profile Visitors
I am deploying a new version of VW2021 to our student's machines. by default, the VW settings are stored under the users profile(AppData\Roaming\Nemetschek\Vectorworks\2021). Is there any possibility we can redirect that to Onedrive using VW settings for each user when they start the VW program?
vectorworks 2019 silent install using sccm as application deployment
georgebpnz replied to georgebpnz's question in Troubleshooting
in my case ccmcache folder exclusion made a lot of progress and moving the installer to root folder -
I did below changes and seems working my VectWrk 2020 deployment as required deployment. give a try and let me know if its helps. I have added the exclusion of below folders in my Antivirus exclusion path settings. I did move the installer from resources\installer to root folder and run the install from there using script. Powershell script I use .\Install-Vectorworks2020.exe --mode unattended --unattendedmodeui none --UserName "xxxx" --CompName "xxxx" --Serial "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx" --installdir "C:\Program Files\Vectorworks 2020" |Out-Null Start-Sleep -Seconds 300 Detection method I used in my environment -
Hi, I am deploying vectorworks 2019 using sccm and the deployment fails . The install starts and install directory stuck as picture 1 attached and failed to timeout . anyone tried to install vectorworks using sccm ? Using commandline as $scriptPath = .\resources\installer\Install-Vectorworks2019.exe --mode unattended --unattendedmodeui none --UserName "User" --CompName "Compname" --Serial XXXX-XXX-XXX-XXX--installdir "C:\Program Files\Vectorworks 2019" | Out-Null +++ Application not discovered. [AppDT Id: ScopeId_6E8F8258-883B-4E1F-9960-3885F19C3671/DeploymentType_26dc66ad-b807-4441-8f83-a5fdf423497c, Revision: 12] AppEnforce 11/12/2018 1:38:54 PM 8744 (0x2228) App enforcement environment: Context: Machine Command line: powershell -executionpolicy bypass -file "install_x64.ps1" Allow user interaction: No UI mode: 0 User token: null Session Id: 4294967295 Content path: C:\WINDOWS\ccmcache\1x Working directory: AppEnforce 11/12/2018 1:38:54 PM 8744 (0x2228) Prepared working directory: C:\WINDOWS\ccmcache\1x AppEnforce 11/12/2018 1:38:54 PM 8744 (0x2228) Found executable file powershell with complete path C:\WINDOWS\System32\WindowsPowerShell\v1.0\powershell.exe AppEnforce 11/12/2018 1:38:54 PM 8744 (0x2228) Prepared command line: "C:\WINDOWS\System32\WindowsPowerShell\v1.0\powershell.exe" -executionpolicy bypass -file "install_x64.ps1" AppEnforce 11/12/2018 1:38:54 PM 8744 (0x2228) Executing Command line: "C:\WINDOWS\System32\WindowsPowerShell\v1.0\powershell.exe" -executionpolicy bypass -file "install_x64.ps1" with system context AppEnforce 11/12/2018 1:38:54 PM 8744 (0x2228) Working directory C:\WINDOWS\ccmcache\1x AppEnforce 11/12/2018 1:38:54 PM 8744 (0x2228) Post install behavior is BasedOnExitCode AppEnforce 11/12/2018 1:38:54 PM 8744 (0x2228) Waiting for process 5688 to finish. Timeout = 120 minutes. AppEnforce 11/12/2018 1:38:54 PM 8744 (0x2228) Process 5688 terminated with exitcode: 1 AppEnforce 11/12/2018 2:05:09 PM 8744 (0x2228) Looking for exit code 1 in exit codes table... AppEnforce 11/12/2018 2:05:09 PM 8744 (0x2228) Unmatched exit code (1) is considered an execution failure. AppEnforce 11/12/2018 2:05:09 PM 8744 (0x2228) ++++++ App enforcement completed (1575 seconds) for App DT "Vectorworks2019" [ScopeId_6E8F8258-883B-4E1F-9960-3885F19C3671/DeploymentType_26dc66ad-b807-4441-8f83-a5fdf423497c], Revision: 12, User SID: ] ++++++ AppEnforce 11/12/2018 2:05:09 PM 8744 (0x2228) +++ Starting Install enforcement for App DT "Vectorworks2019" ApplicationDeliveryType - ScopeId_6E8F8258-883B-4E1F-9960-3885F19C3671/DeploymentType_26dc66ad-b807-4441-8f83-a5fdf423497c, Revision - 12, ContentPath - C:\WINDOWS\ccmcache\1x, Execution Context - System AppEnforce 11/12/2018 2:05:35 PM 8744 (0x2228) A user is logged on to the system. AppEnforce 11/12/2018 2:05:35 PM 8744 (0x2228) Performing detection of app deployment type Vectorworks2019(ScopeId_6E8F8258-883B-4E1F-9960-3885F19C3671/DeploymentType_26dc66ad-b807-4441-8f83-a5fdf423497c, revision 12) for system. AppEnforce 11/12/2018 2:05:35 PM 8744 (0x2228) +++ Application not discovered. [AppDT Id: ScopeId_6E8F8258-883B-4E1F-9960-3885F19C3671/DeploymentType_26dc66ad-b807-4441-8f83-a5fdf423497c, Revision: 12] AppEnforce 11/12/2018 2:05:35 PM 8744 (0x2228) App enforcement environment: Context: Machine Command line: powershell -executionpolicy bypass -file "install_x64.ps1" Allow user interaction: No UI mode: 0 User token: null Session Id: 2 Content path: C:\WINDOWS\ccmcache\1x Working directory: AppEnforce 11/12/2018 2:05:35 PM 8744 (0x2228) Prepared working directory: C:\WINDOWS\ccmcache\1x AppEnforce 11/12/2018 2:05:35 PM 8744 (0x2228) Found executable file powershell with complete path C:\WINDOWS\System32\WindowsPowerShell\v1.0\powershell.exe AppEnforce 11/12/2018 2:05:35 PM 8744 (0x2228) Prepared command line: "C:\WINDOWS\System32\WindowsPowerShell\v1.0\powershell.exe" -executionpolicy bypass -file "install_x64.ps1" AppEnforce 11/12/2018 2:05:35 PM 8744 (0x2228) Executing Command line: "C:\WINDOWS\System32\WindowsPowerShell\v1.0\powershell.exe" -executionpolicy bypass -file "install_x64.ps1" with user context AppEnforce 11/12/2018 2:05:35 PM 8744 (0x2228) Working directory C:\WINDOWS\ccmcache\1x AppEnforce 11/12/2018 2:05:35 PM 8744 (0x2228) Post install behavior is BasedOnExitCode AppEnforce 11/12/2018 2:05:35 PM 8744 (0x2228) Waiting for process 7604 to finish. Timeout = 120 minutes. AppEnforce 11/12/2018 2:05:35 PM 8744 (0x2228) Process 7604 terminated with exitcode: 0 AppEnforce 11/12/2018 2:15:02 PM 8744 (0x2228) Looking for exit code 0 in exit codes table... AppEnforce 11/12/2018 2:15:02 PM 8744 (0x2228) Matched exit code 0 to a Success entry in exit codes table. AppEnforce 11/12/2018 2:15:02 PM 8744 (0x2228) Performing detection of app deployment type Vectorworks2019(ScopeId_6E8F8258-883B-4E1F-9960-3885F19C3671/DeploymentType_26dc66ad-b807-4441-8f83-a5fdf423497c, revision 12) for system. AppEnforce 11/12/2018 2:15:02 PM 8744 (0x2228) +++ Discovered application [AppDT Id: ScopeId_6E8F8258-883B-4E1F-9960-3885F19C3671/DeploymentType_26dc66ad-b807-4441-8f83-a5fdf423497c, Revision: 12] AppEnforce 11/12/2018 2:15:03 PM 8744 (0x2228) ++++++ App enforcement completed (568 seconds) for App DT "Vectorworks2019" [ScopeId_6E8F8258-883B-4E1F-9960-3885F19C3671/DeploymentType_26dc66ad-b807-4441-8f83-a5fdf423497c], Revision: 12, User SID: ] ++++++ AppEnforce 11/12/2018 2:15:03 PM 8744 (0x2228) +++ Starting Install enforcement for App DT "Vectorworks2019" ApplicationDeliveryType - ScopeId_6E8F8258-883B-4E1F-9960-3885F19C3671/DeploymentType_26dc66ad-b807-4441-8f83-a5fdf423497c, Revision - 12, ContentPath - C:\WINDOWS\ccmcache\1x, Execution Context - System AppEnforce 11/12/2018 2:38:39 PM 6064 (0x17B0) A user is logged on to the system. AppEnforce 11/12/2018 2:38:39 PM 6064 (0x17B0) Performing detection of app deployment type Vectorworks2019(ScopeId_6E8F8258-883B-4E1F-9960-3885F19C3671/DeploymentType_26dc66ad-b807-4441-8f83-a5fdf423497c, revision 12) for system. AppEnforce 11/12/2018 2:38:39 PM 6064 (0x17B0)
